fan speed control?
Discussion in 'General Hardware' started by Darkgundam111, Aug 13, 2011.
  1. Darkgundam111 New Member
    Apr 19, 2009
    627 (0.25/day)
    18
    I have this fan http://www.mwave.com/mwave/SKUSearch.asp?px=DS&scriteria=AA79186
    plugged into my motherboard's 3 pin (jsfan)
    as i have googled, it requires the 4th pin before fan speed can be controlled. however, i am seeking a way to do so perhaps someone knows a way to?
    I would like to increase the speed of the fan, it seems to be spinning very slow.
  2. LordJummy
    LordJummy New Member
    May 13, 2011
    1,405 (0.81/day)
    248
    US of A
    Get a resistor cable that can lower the power output to the fan.
  3. twicksisted
    twicksisted
    Oct 4, 2007
    2,438 (0.80/day)
    350
    how would adding a resistor to lower the power to the fan increase the fan speed?
  4. mlee49
    mlee49
    Dec 27, 2007
    8,514 (2.87/day)
    2,125
    Kansas City
    The only way I would suggest getting your fan to run as fast as possible is to connect it directly to the power supply. You may need a MOLEX to 3 pin adapter, but it may also come with your fan.
    Depending on your mobo and where it's connected it may be throttled down already. The 4th pin your referring to is for PWM or Pulse Width Modulation to be a bit more active with it's powering scheme. A 3 pin power adapter can have the voltage dropped to make it run slower than rated, and some mobo 3 pin headers do that(in the BIOS).
  5. LordJummy
    May 13, 2011
    1,405 (0.81/day)
    248
    US of A
    Whoops you're right. I thought I read "Decrease". My bad bro!
    Sometimes I see or hear what I want to see or hear lol
  6. sneekypeet
    Apr 12, 2006
    22,824 (6.36/day)
    7,387
    Does the bios not offer fan control for that header?
  7. Darkgundam111 New Member
    Apr 19, 2009
    627 (0.25/day)
    18
    i am not sure where to look for the fan settings in the mobo bios actually. perhaps it is in there. i have a biostar TA790GX XE
  8. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    22,166 (5.94/day)
    8,071
    Plugging a 4-pin fan into a 3-pin header will make the fan run at full speed(assuming there isn't some setting in the BIOS that controls the fan speed via voltage). So there probably isn't a way to increase the fan speed, it is just a slow fan.
    Edit: I just looked at the manual for your board and there is something in the BIOS under the Advanced menu called Smart Fan Configuration. However, it looks like it only affects the CPU fan header, and is disabled by default. So if the fan is plugged into the jsfan header, it is getting full power, and going as fast as it will every go. The fan just isn't a high speed fan, it is built to be quiet, not fast.
    10 Year Member at TPU Crunching for Team TPU More than 25k PPD
  9. Darkgundam111 New Member
    Apr 19, 2009
    627 (0.25/day)
    18
    But looking at the fan spin seems far too slow for the specs that it has, which makes me believe that it's not running at full speed.
  10. newtekie1
    Nov 22, 2005
    22,166 (5.94/day)
    8,071
    There is a H/W monitor section of the BIOS also that shows the RPM of the fan connected to jsfan1. Go in there and see what RPM it is running at. If it isn't running at 1500RPM +/- 10% then either the fan header is busted and isn't supplying the correct voltage, or the fan is bad.
    Darkgundam111 says thanks.
  11. Darkgundam111 New Member
    Apr 19, 2009
    627 (0.25/day)
    18
    not sure what happened but i opened my case and checked the fan then closed it up and turned it on and its spinning at full speed now :) and i checked the motherboard monitor and it showed the max speed 1500 :) thanks guys
  12. Hockster
    Hockster
    Mar 30, 2010
    396 (0.18/day)
    100
  13. Darkgundam111 New Member
    Apr 19, 2009
    627 (0.25/day)
    18
    oo cool will consider getting one of these.
