Fan Speed of Hyper 212 Evo
Discussion in 'Overclocking & Cooling' started by Ronarch, Nov 14, 2011.
  1. Ronarch New Member
    Oct 23, 2011
    30 (0.02/day)
    0
    Can someone please show me how to set the fan speed of Hyper 212 Evo higher than 12xx RPM?
    In UEFI I set the target CPU temp as 45c and target fan speed as the highest level (lv9).
    However, even the CPU temp I observe in HWmonitor reaches almost 70c, the "SYSFANIN" value (I think it's the CPU fan, right?) is still around 1200 RPM.
    I tried using Speedfan, but all three speeds setting are already 100%, therefore I cannot increase anymore.
    Is it weird that it shows 1200 RPM for "Sys Fan", but 0 RPM for "CPU fan" in Speedfan?
    Of course I am sure the fan of the cooler is working.
    Nevertheless, the CPU fan speed I see in UEFI page can reach 17xx RPM...
    But it just never go that high in the OS... Any suggestion please?
  2. cheesy999
    Jul 2, 2010
    4,027 (1.84/day)
    626
    UK
    'Sys Fan' is the case fan you have plugged into the motherboards first fan header
    If CPU fan isn't working in these progams it's probably because they can't read your motherboards CPU fan value
  3. Ronarch New Member
    Oct 23, 2011
    30 (0.02/day)
    0
    Ahh... What is the reason causing it? And what can I do to make that value be read
  4. Jstn7477
    Jstn7477
    Aug 30, 2009
    3,984 (1.60/day)
    1,645
    Sarasota, Florida, USA
    Interesting, my CM Hyper 212 EVO works fine on my ASRock Z68 Extreme4 Gen3 and I believe goes between 1400 and 1850 RPM with the temp threshold set to 65c and the target set to 3 (to keep it quiet while idling). You have it plugged in the 4 pin CPU_FAN1 header, right?
  5. Ronarch New Member
    Oct 23, 2011
    30 (0.02/day)
    0
    I have...
    The fan won't actually run if I haven't... right?
  6. cheesy999
    Jul 2, 2010
    4,027 (1.84/day)
    626
    UK
    no it will work on any header, even the 3 pin one's
  7. Ronarch New Member
    Oct 23, 2011
    30 (0.02/day)
    0
    I see. Good to know that
    But I have just opened the case and I am utter sure it's correctly plugged to the 4 pin CPU_FAN1 socket
    I've re-plugged it one more time to ensure that.
    Hm... but nothing changed. The fan speed is still not shown in neither Hwmonitor nor Speedfan.
    Do I have to install something? Like the mobo driver?
    I haven't install any of that actually, except the one for the audio.
  8. cheesy999
    Jul 2, 2010
    4,027 (1.84/day)
    626
    UK
    Sometimes programs just can't read sensors on motherboards, and there's not much you can do besides try and find a program that will work with it
    If your motherboard came with any overclocking software then that would normally read all the sensors on your board correctly
  9. Ronarch New Member
    Oct 23, 2011
    30 (0.02/day)
    0
    Suddenly, this time, HWMonitor can read the CPU fan value....
    But I did nothing to make that ....
    This actually worries me more than keeping unable to read the value...
    Strange, huh?
