Fans pins with speed switches.
Discussion in 'Cases, Modding & Electronics' started by newfellow, Sep 25, 2009.
  1. newfellow New Member
    Aug 28, 2009
    314 (0.14/day)
    17
    Well, got quite couple. Antec 120mm's but real issue is at Thermaltake V1.
    Each comes with same setup on cables:
    3-pin -> red, black, yellow (usual connector with voltage signal)
    and
    2-pin -> red & black (this is the separated speed switch, comes as 3-state & on Thermaltake V1 it's 1080 RPM - 2200 RPM stepless)
    [​IMG]
    Now my problem is that there's an cut somewhere in the speed switch/controller cable (cable cuts on some positions) question is, if I cut the 2-pin speed switch and attach the Red<->Black from it. Will the fan spin as regular 3-pin fan (2200RPM) maxed out?
Share This Page
