First attempt at water cooling...FAIL!
Discussion in 'General Hardware' started by Dr. Spankenstein, Nov 17, 2007.
  1. Dr. Spankenstein
    Feb 15, 2007
    1,925 (0.49/day)
    280
    First attempt at water cooling...FAIL! now WINAR!!
    Well, I've done it this time!:rolleyes:
    [​IMG]
    [​IMG]
    In an attempt to slap my rig back together with my new blocks, I am met with a no-POST situation. One piece of evidence is that when it is first powered on, you can see that a signal is sent to the monitor for a split-second but it refuses to fully power-on the monitor.
    The only things I can think of are that I might have put some extreme pressure on the PCI slot and potentially broke some of the solder joints OR when I put the TIM and block on the video card something got shorted (or worse, crushed)!:eek:
    At first I thought that the backplate for the CPU block was so tall that the threaded rods and accompanying nuts were shorting to the mobo tray, but a quick aplication of electrical tape behind those areas proved that this was not the case.:confused:
    Guess I'll have to purchase a temp video card and start the process of elimination.
    Any suggestions would be appreciated.
    Cheers,
    Bryan
    10 Year Member at TPU
  2. DaMulta
    DaMulta My stars went supernova
    Aug 3, 2006
    16,159 (3.94/day)
    1,501
    Oklahoma T-Town
    You more than likly put that block on to tight on the video card. Lossen it a little bit.
    Also you don't have your 6pin installed on your video card.
    Dr. Spankenstein says thanks.
  3. Dr. Spankenstein
    Feb 15, 2007
    1,925 (0.49/day)
    280
    Hmmmm, I will try that. Thanks man!
    p.s.
    good eye, BTW!
  4. Dr. Spankenstein
    Feb 15, 2007
    1,925 (0.49/day)
    280
    That made some sense, but no luck. The 6-pin wasn't installed at the time of that picture as I was about to remove the card.
    Any more ideas?
  5. DaMulta
    Aug 3, 2006
    16,159 (3.94/day)
    1,501
    Oklahoma T-Town
    Does the PSU fire up?
  6. DaMulta
    Aug 3, 2006
    16,159 (3.94/day)
    1,501
    Oklahoma T-Town
    BTW Dr. Spankenstein you have my new blocks.......reset the Cmos?
    Install the stock cooler back on the 1k and see what happens. Did you use AS5 on the chipset>?If so how much did you use?
  7. Dr. Spankenstein
    Feb 15, 2007
    1,925 (0.49/day)
    280
    Yep. The fans on the rad, the HDDs, the DVD-ROM and the pump are all good.
    I have a feeling it probably is working with the exception of the video card not being able to start the monitor.
    I did pull the CPU block and only one edge was making contact. I'm going to try and make better contact. I don't think that would keep it from POSTing though.
  8. Dr. Spankenstein
    Feb 15, 2007
    1,925 (0.49/day)
    280
    Have reset CMOS many times.
    Switching back to stock cooling was next step I had in mind.:toast:
    I was using MX-2 on everything.
  9. Random Murderer
    Random Murderer The Anti-Midas
    Dec 6, 2006
    6,977 (1.76/day)
    1,903
    Florida, A.K.A. the Sweatbox
    mx-2 is non-conductive, you could have slathered the entire computer in it and it wouldn't short anything, so that's not an issue.
  10. DOM
    DOM
    May 30, 2006
    7,626 (1.83/day)
    863
    TX, USA
    looks nice :D someones trying to beat me in 3dm lol
    so do you get any beeps ? does you mobo even beep ? im asking cuz mine does when I turn it on
    have you tryed to boot it with one stick of ram ?
  11. Dr. Spankenstein
    Feb 15, 2007
    1,925 (0.49/day)
    280
    I should be so lucky!;) Well, who knows what could happen if I could get it working!:rolleyes:
    No beeps, which leads me to believe that the viedo card is not commuticating with the monitor. It will give me beep codes if I've gone beyond the ability of my RAM.
    No, but you can bet I'll give it a try!:D
    Thanks for all the advice! I'll keep you all aprised of the situation...
  12. JC316
    JC316 Knows what makes you tick
    Jan 24, 2006
    9,366 (2.18/day)
    993
    My best advice is to double check everything. All connectors, the works. Also, make SURE that the video card is seated, I didn't have mine pushed all the way into the PCI slot and it was doing the same thing, also, wiggle it up and down slightly, just be sure.
  13. pt
    pt not a suicide-bomber
    Mar 11, 2006
    8,956 (2.11/day)
    208
    Portugal
    don't you have a spare videocard to try?
    and what's with everyone using 1/2 tubing..., tube diameter doesn't make much difference
  14. DaMulta
    Aug 3, 2006
    16,159 (3.94/day)
    1,501
    Oklahoma T-Town
    Because it's cool:toast:'' there is more volume as well. I would like to see some 1in runs.
    I hope he finds out what happened to his machine. This is odd that this has happened.
  15. sneekypeet
    Apr 12, 2006
    24,443 (5.80/day)
    9,324
    just a quick thing that comes to mind with setting up water...no CPU fan on the header, will sometimes cause a no boot issue. Try putting any fan,RAM, AUX, whatever you got with the right (even a 3pin) connector. It has been known to cause this, but was really on 939....but what the hell its worth a go!!?!!
    Got water on my ABIt 975x chipset, but I run my Dominator RAM fan on the CPU header from the get go.
  16. Random Murderer
    Dec 6, 2006
    6,977 (1.76/day)
    1,903
    hey, spankenstein:
    [​IMG]
    sorry, saw it and couldn't resist! :roll:
  17. 3991vhtes
    3991vhtes New Member
    Apr 22, 2007
    2,785 (0.73/day)
    121
    My house.
    ^^ :laugh:
  18. panchoman
    panchoman Sold my stars!
    Jul 16, 2007
    9,595 (2.56/day)
    1,201
    no beeps from the mobo when theres no ram in it? seems like it might be the mobo chipset?? you've tried clearing the cmos right?
  19. sneekypeet
    Apr 12, 2006
    24,443 (5.80/day)
    9,324
    there is only two reasons why a mobo wont beep on post....#1 Bad MOBO...#2 no recognition of the CPU, which again leads me to think it may be the sensing wire in the CPU fan header.
  20. intel igent
    intel igent New Member
    Jun 5, 2005
    4,640 (1.03/day)
    428
    Toronto, Canada
    same thing happened to me first time i set up my loop :eek:
  21. Yin
    Yin
    Feb 19, 2006
    538 (0.13/day)
    32
    Try unplugging EVERYTHING, and plug in just the MB, CPU, RAM see if that works
  22. Random Murderer
    Dec 6, 2006
    6,977 (1.76/day)
    1,903
    ok, and how did you fix it?
  23. intel igent
    Jun 5, 2005
    4,640 (1.03/day)
    428
    Toronto, Canada
    ur obviously in quadcore heaven posting without reading again :shadedshu
    :toast:
  24. Random Murderer
    Dec 6, 2006
    6,977 (1.76/day)
    1,903
    lol, i just got owned.:banghead:
  25. imperialreign
    imperialreign New Member
    Jul 19, 2007
    7,043 (1.88/day)
    900
    Sector ZZ₉ Plural Z Alpha
    I'd like to see someone run 1" tubing in anything smaller than a full-tower! :laugh:
    seconded, on this! Even on an air cooled setup here, I had problems running my Zalman at first, because the BIOS was set for a PWM (4-pin) fan. I had to change the option to DC (3-pin) to get it to finally POST first time around. Some mobo's just won't engage if it doesn't read anything from the CPU header, or it doesn't read correctly.
