First build need help!!
Discussion in 'System Builder's Advice' started by rizla1, Jan 8, 2009.
  1. rizla1
    Oct 23, 2008
    485 (0.21/day)
    9
    ireland
    hi , i need help with my first build ,for my mother .
    i have some experience am an a+ technician in training , so am ok on that side . but i need help with wat to get.
    i have a budget of about £250 to £300
  2. WhiteLotus
    WhiteLotus
    Jul 30, 2007
    6,561 (2.40/day)
    859
    What parts are you looking for, do you already have a case it can go into or DVD drives? also do you need a monitor?
  3. ShadowFold
    ShadowFold New Member
    Dec 23, 2007
    16,921 (6.52/day)
    1,644
    Omaha, NE
    Are you gonna be gaming or just surfing the net? Can't really recommend much till I know.
  4. rizla1
    Oct 23, 2008
    485 (0.21/day)
    9
    ireland
    sorry, i seen a case on ebay with a 480 watt psu for £15 so i mite get that. and if you can recomend a cheap lcd thated be great, also she will be mostly just surfing the net nothing to difficult, so really i need help with a cheap mb ,cpu ,cddrive,hdd and ram.
    also would a 3600+ sempron completly suck ballsm as its single core
    http://cgi.ebay.co.uk/AMD-Athlon-42...14&_trkparms=72:1300|66:4|65:12|39:1|240:1318
    i was thinking along the lines of this but hopefully use could recomend something cheaper/better
  5. WhiteLotus
    WhiteLotus
    Jul 30, 2007
    6,561 (2.40/day)
    859
    If it is just for the Internet and she doesn't care that it will take a bit longer to load up when she first sticks it on, then a single core is fine.
Share This Page
