First PC Build Finished, Thanks For The Help!!!!
Discussion in 'System Builder's Advice' started by vnhill1981, Dec 31, 2011.
  1. vnhill1981
    vnhill1981
    Dec 19, 2011
    86 (0.06/day)
    20
    Well as some of you know, I have been blowing up the threads asking questions about my first PC build (well mainly just upgrading the existing one). Anyways here's where I started:
    HP Pavillion a6442p
    Samsung 500GB Hard Drive
    Asus Benicia Motherboard
    Intel Dual Core e2200
    4 x 1GB Samsung DDR2 Memory 800MHz
    250W PSU (stock), which I changed to a Cool Master Extreme Power 600W (satisfies my needs)
    *PC was very unorganized inside (here's the before pic)
    Here's what's in it now:
    Same Hard Drive
    ASUS P8Z68-M Pro
    Intel i5 2500 (non K)
    2 x 4GB DDR3 1600 Corsair Vengeance
    600W PSU (as stated earlier)
    Galaxy GT430 (Fermi) - picked for $40 locally
    First problem was side panel had a small vented area where the air blew off of the heatsink/fan out of the case. With the new MOBO, the CPU was positioned where the air would not go to the vent, rather it would blow right into the solid portion of the side panel (marked by red X in pic below). Solution:
    1. Cut out large square on side panel
    2. By A/C floor vent cover
    3. Paint it black
    4. Cover the hole
    (plus install sticker for looks LOL, archery is my first love)
    View attachment 44969 View attachment 44970
    Being very careful, I installed all of the new hardware, along with dressing it up to be as organized as I could get it in such a small case):
    View attachment 44971 View attachment 44972
    After installing everything and turning it on, first thing I did was boot from disk using a Memtest 86 disk I created. Here's pic (it passed, so far so good)
    Then I used my Windows 7 64bit Upgrade disk to do a clean install of Windows (this way will not let you activate as I found out). Rep. from Microsoft said the upgrade key is not meant to use to do a clean install to prevent piracy. However, after 15 minutes on the phone with them they configured the key to allow me to do so (Thanks Microsoft). The next 6-7 hours was spent re-loading programs, copying files, and installing some 150+ Windows updates. Now we're cooking. First thing I did once running was Intel Burn Test. First and Second try failure at Maximum Stress. Got online and read some issues and solutions. Third try Passed (key was to make sure you run as an administrator). Next I used x264 Benchmark HD v4.0 to compare to a comparison between the two PC's:
    Original: 1st Pass - 28 FPS / 2nd Pass 5 (average over the 4 tests)
    Upgraded: 1st pass - 145 FPS / 2nd Pass 29 FPS (average over the 4 tests)
    (got excited about this)
    Next I did a real world test, as it relates to me on what I wanted my PC to do (which was my sole purpose for upgrading as I plan to put my entire DVD set on an external Hard Drive). Using Aiseesoft DVD Ripper I converted my Lost Boys DVD (by the way one of the best movies ever I think). Here's the comparison:
    Original:
    Set output as a H264 720p file - time 10.5 hours (let it run all day):(
    Upgraded:
    Set output as a H264 1080p file - time 45 minutes :D
    Then came my first fright. I installed CPUID Hardware Monitor. It gave CPU core temps in the low 30's (celsius), but my CPUTIN was mid 80's-90 (celsius). I read through some forums on line and AIDA64 Extreme Edition was listed as one of the better monitoring softwares, so I downloaded it. Here's the read out comparison:
    View attachment 44974 View attachment 44975
    Now my PC ain't smoking or blowing any hot air, so I believe I am good. I have read that the CPUTIN in some programs can be misleading, but what do you think. For what it's worth, according to AIDA64 my system idles around 28 (celsius) and goes to around mid 40's (celsius) during normal operations. The highest it got during Intel Burn Test with all cores running at 100% was 68 (celsius). All in all I think my first build went well. Sorry so long, just kinda proud of myself.
    Edit: Pics are not showing up for some, so here they are in the order they were supposed to be
  2. BrooksyX
    BrooksyX
    Jan 7, 2008
    3,947 (1.33/day)
    569
    cant see the pics.
  3. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,482 (5.99/day)
    4,522
    Youngstown, OH
  4. entropy13
    entropy13
    Mar 2, 2009
    5,034 (1.98/day)
    1,272
    That PSU you got, it's not really 600W. I know because I had that. At best it's a 450W. And a very inefficient one at that (71-77% efficient). Good thing you only got a GT 430.
  5. vnhill1981
    vnhill1981
    Dec 19, 2011
    86 (0.06/day)
    20
    Yes sir, I am aware now (after I bought it). However, don't really have buyers remorse as it supports what I need it to. Next build it will probably a Corsair Gold Platinum and definately modular (but that's a few years away).
  6. Jetster
    Jetster
    Jan 17, 2010
    7,341 (3.31/day)
    3,766
    Oregon
    Good job! Updating an HP can be a pain. They have a lot of preparatory parts that sometimes need to be modded. Now you need to update your system specs in your UserCP
  7. vnhill1981
    vnhill1981
    Dec 19, 2011
    86 (0.06/day)
    20
    Done!
  8. pantherx12
    pantherx12 New Member
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    As you case is inverted and you don't have much airflow may I suggest removing the PCI bracket blanking plates?
    Means the warm air from your GPU has somewhere to escape to.
  9. vnhill1981
    vnhill1981
    Dec 19, 2011
    86 (0.06/day)
    20
    Good suggestion, will do!
    Edit: DONE
  10. entropy13
    entropy13
    Mar 2, 2009
    5,034 (1.98/day)
    1,272
    Any info about the case fan? Size? Brand?
  11. pantherx12
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    Fast work :toast:
    There's not been a single case I've ever kept them in :laugh:
  12. vnhill1981
    vnhill1981
    Dec 19, 2011
    86 (0.06/day)
    20
    92mm x 25mm Foxconn (all I know as it came with the PC)
