First time using RAID, need lots of help.
3,603 (0.69/day)
Oregon, USA
System Name GLaDOS
Processor AMD FX-9590 X8 4.7GHz
Motherboard ASUS Sabertooth 990FX
Cooling Corsair H80i v2
Memory Corsair Vengeance 24GB (2x8GB, 2x4GB) DDR3 1600 MHz
Video Card(s) ASUS ROG-STRIX-RX580-O8G-GAMINGOC
Storage WD Blue 3D NAND 1TB Internal PC SSD
Display(s) 2 Acer S231HL 23" LED backlit LCD's on a Dual LCD stand
Case Corsair iCUE 220T RGB Airflow
Audio Device(s) Onboard - Corsair Void Pro Wireless
Power Supply Corsair 850HXi 850W
Mouse Corsair Sabre RGB
Keyboard Corsair K70 LUX RGB
Software Microsoft Windows 10 Pro 64 Bit
Kreij
Senior Monkey Moderator
13,817 (2.20/day)
Cheeseland (Wisconsin, USA)
What kind of RAID? RAID 0? RAID 1?
8,519 (1.43/day)
Kansas City
System Name The Dove Box Rev 3.0
Processor i7 8700k @ 4.7GHz
Motherboard Asus Maximus X APEX
Cooling Custom water loop
Memory 16GB 3600 MHz DDR4
Video Card(s) 2x MSI 780 Ti's in SLI
Storage 500GB Samsung 850 PCIe SSD, 4TB
Display(s) 27" Asus 144Hz
Case Enermax Fulmo GT
Audio Device(s) ON BOARD FTW
Power Supply Corsair 1200W
Keyboard Logitech G510
Software Win 10 64x
It's not too hard, just follow the instructions from your motherboard manual. Here's the short version:
1) Install both drives
2) Boot into the BIOS and enable RAID
3) Reboot and enter the RAID configuration
4) Select Raid type and settings(example RAID0 w/128kb stripe :))
5) Reboot and install OS to the new drive
6) Install any Raid software(Intel Rapid Storage Manager)
7) Enjoy
3,603 (0.69/day)
Oregon, USA
System Name GLaDOS
Well, I'm not entirely sure at this point. I'm really looking for recommendations, although I hear RAID 1 is more reliable than RAID 0, which is faster. If I remember right.
Kreij
13,817 (2.20/day)
RAID 0 is striping. This writes to both HD at the same time improving performance.
RAID 1 is mirroring. This give you data redundancy (but is not a backup).
8,519 (1.43/day)
Kansas City
Software Win 10 64x
Just FYI, I've had 2 of the last 4 RAID0 array's crash on me. Pain in the arse to recover, had to use a special raid recovery tool and it took hours to recover less than 100GB of photo's and videos. It's not worth the hassle to recover a mechanical hdd Raid array than invest in a single SSD that has 20-100MB better read/write's.
Even some WD black's in RAID0 still arnt 150MB/s read/write. A single Sandforce ssd easily get's 250+ read/writes and 120GB is a good price point to start with.
2,190 (0.38/day)
Minnesota, USA
System Name TaichiTig
Processor i7 6800K
Motherboard ASRock X99 Taichi
Memory 32GB DDR4 3200
Video Card(s) RTX 4070
Storage SSD + Misc. HDDs in DrivePool
Display(s) BenQ PD3200U, Samsung C32HG70
Case Antec Twelve Hundred
Audio Device(s) Behringer UMC404HD, LSR308, Shure SRH840, AKG K612, Etymotic HF5
Power Supply Corsair 750TX
Keyboard Deck Legend Ice Tactile
Software Win10
Like Kreij said, RAID 0 is for performance and RAID 1 is for redundancy (Wikipedia RAID article). However, it is likely you will notice little or no difference in performance with RAID 0 across two drives vs a single drive—claims of amazing improvements are often exaggerated or due to placebo effect. It's also theoretically less reliable since you're using twice the drives and if either drive fails, you'll probably lose all the data stored on both drives. This is not to scare you away from using RAID—in fact I'd say go for it, if nothing else just to try it out for yourself and see what you think, as long as you've got the drives. Just don't entrust any important data to a RAID 0 array if it's not backed up elsewhere.
You might find RAID 1 handy. It's nice to know that if a hard drive fails, your data will be safe on the other drive, and that's what RAID 1 does. Some will tell you not to use RAID 1 for an OS drive because it'll drastically reduce performance. These claims, too, are often exaggerated. What I would say is, try it! See what you think and what you find useful. It sounds like you are curious and want to try something new, and that's great, even if just for the sake of learning more.
Also, to add to what mlee stated about failed arrays (NOT to disagree but to balance his experiences out with my own), I've never had a RAID array crash or in any other way fail. I've had individual drives in RAID arrays fail, and been relieved when RAID saved the data that was on them, but I've built more systems with RAID set up than I care to count and haven't had any RAID failures yet. And I'm not just talking about systems with dedicated high-end RAID cards, but also the same type of integrated RAID you're planning to use. Integrated RAID controllers are as good as any for many intents and purposes. But again, this is only to balance out what mlee stated, not to disagree: a failure can sure happen.
Try something new and have fun. :toast: You know you can count on TPU to be here and provide any help you might need.
8,202 (1.36/day)
Mouse Logitech G604s
Late in the game i know, but the link in my sig really needs to be stickied.
