Frame rate problems..
Discussion in 'General Hardware' started by hugz, Sep 20, 2007.
  1. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.47/day)
    573
    New York
    post back how it goes:)
  2. hugz New Member
    Sep 20, 2007
    138 (0.05/day)
    8
    give me 5-10 min to run some games and see what happens :)
  3. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.47/day)
    573
    New York
    I'm hoping to hear good newz from u;)
  4. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.47/day)
    573
    New York
    Well its been 25 minutes and you havnt posted back so your probably still gaming on that rig and the issue is gone.
  5. hugz New Member
    Sep 20, 2007
    138 (0.05/day)
    8
    oops sorry,
    well,
    N4S Carbono was running nice for more than 5 min, but I lagged a few times.
    In ET,I had 125fps stable, but 30-40fps lag was back for few times.
    This all with Avast services running. I will try right now TDU.
    edit/After 5 min playing TDU, the game crashed, but I didn't notice any lag :eek:
    gonna try HL2/E1
    ____________________________________________________________________________
    WOW! :eek: 0 lag in HL2 and ETQW stable smooth gaming! I will keep it update, but looks like my problem was just resolved :rockout:
  6. rangerone766
    rangerone766
    Aug 18, 2007
    1,036 (0.38/day)
    111
    i know the fix
    use cats 7.7
    the 7.8 and 7.9 dont work on agp boards. with my 1950pro the 7.8 or 7.9 would turn all the smartgart settings to off and run agp 4x only.
    just try the older drivers and let us know how it works,
  7. hugz New Member
    Sep 20, 2007
    138 (0.05/day)
    8
    yeah 7.8 don't work with AGP but 7.9 do pretty well, and If you wanna play ETQW you must have lastest version....
  8. rangerone766
    rangerone766
    Aug 18, 2007
    1,036 (0.38/day)
    111
    i'm running omega's
    based on the 7.4's i think and can play the quake demo fine.
    if its not the problem with 7.8 or 7.9 i have no other ideas srry.
    even 7.9 dont work on mine, runs same as 7.8 sh!tty
  9. hugz New Member
    Sep 20, 2007
    138 (0.05/day)
    8
    7.9 works fine here, but hey, my prob is already resolved :) [[looks like resolved]], I will post more later...
  10. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.47/day)
    573
    New York
    :toast:SWEET:toast:
    hugz says thanks.
  11. hugz New Member
    Sep 20, 2007
    138 (0.05/day)
    8
    this is not the end.at least with wolfenstein et. keeps doing -40 time to time.hope this is the only game where this happens.ill test more tomorrow gotta wake up soon.nows 11:50pm. :/ will try 7.7cats or omegas too
  12. hugz New Member
    Sep 20, 2007
    138 (0.05/day)
    8
    OMEGA drivers don't work, every time I install and restart the PC, windows says drivers are not installed, mabye FAST WRITE option when isntalling has something to do with?...
    I will try now 7.7
  13. Morgoth
    Morgoth
    Aug 4, 2007
    3,795 (1.39/day)
    250
    Netherlands
    1 question you have agp 4x or 8x? if u got 8x did you turned 8x on in bios and fast ride, apdative memory ect
  14. hugz New Member
    Sep 20, 2007
    138 (0.05/day)
    8
    /AGP 8x, Fast write ON with omega, but it keeps saying theres no ATI hardware.
    /Now I've 7.7 and Fast Write, AGP Write, AGP read, PCI write, PCI read ON.
    /I will check it right now. If still doesn't work good, I will try installing OMEGAS again.
  15. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,416 (6.75/day)
    4,493
    Youngstown, OH
    To me it sounds like a chipset driver or a pagefile issue. Try gaming with Fast Writes turned off first see if it helps.
  16. hugz New Member
    Sep 20, 2007
    138 (0.05/day)
    8
    ok, Im on it.
    Should I try it with avast turned off? or doesn't matter.
    Hey, some time ago I updated chipset bios with Gigabyte @BIOS utility, that could be the problem, imma update it again and install lastest drivers.
    EDIT1/This is what I have now, mobo BIOS just updated, and AGP Fast Write off, rebooting....
    EDIT2/downloading drivers from gigabyte.com
  17. JrRacinFan
    Mar 17, 2007
    19,416 (6.75/day)
    4,493
    Youngstown, OH
    Not trying to make you sound like a n00b but, chipset drivers and a motherboard bios update are 2 completely different things.
    Click here.
  18. hugz New Member
    Sep 20, 2007
    138 (0.05/day)
    8
    ROFLMAO I KNOW, but I think this problem started with BIOS update 1 or 2 months ago. you just remind me it.
    btw, Im doing High Computer Engineering :p
    /I already find that web. :D
    ok chipset driver updted, rebooting........
  19. JrRacinFan
    Mar 17, 2007
    19,416 (6.75/day)
    4,493
    Youngstown, OH
    Ahhh gotcha ;), Why did you flash a new bios? Yah know as the old saying goes " don't fix what is not broken". :p
  20. hugz New Member
    Sep 20, 2007
    138 (0.05/day)
    8
    oh lol, :nutkick: I did it several times, yeah I shouldn't have fix somehing thats not broken :rolleyes: ,hmm so what should I do :cry: ( if this is the reason of my problem )
    It keeps lagging...... after all// im short of ideas right now....
  21. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.47/day)
    573
    New York
    run Adaware (lavasoft) and then spybot(search&destroy) for pests but your task manger looked good although stuff can hide in dllhost.dll although this is unlikely.
  22. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.47/day)
    573
    New York
    also make sure the page file min and max are the same;)
  23. hugz New Member
    Sep 20, 2007
    138 (0.05/day)
    8
    [​IMG] woot.
    [​IMG]
    spybot
  24. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.47/day)
    573
    New York
    retest please :p
  25. hugz New Member
    Sep 20, 2007
    138 (0.05/day)
    8
    Just tested Need for Speed Carbono, results: 2min smooth play --- 15seconds of lag --- 2min perfect --- 15seconds unplayable.......:wtf: I can believe it :mad:
    I think, tomorrow I will try reinstalling the windows again. :banghead:
Share This Page
