Freezer 64 pro - installation questions:
Discussion in 'Overclocking & Cooling' started by nocrapman, Apr 18, 2006.
  1. nocrapman New Member
    Mar 5, 2006
    264 (0.08/day)
    5
    Getting rid of stock HSF - couple of questions -
    1. Is the preapplied paste any good. Should I go with AS5 anyway...
    2. While removing the old thermal compound - 99% isopropyl alcohol or just acetone(lab grade - 100% i think). I have access to both.
    3. Should I use an old cloth or some thing to do this or just a paper towel?
    Appreciate any help guys...
  2. Polaris573
    Polaris573 Senior Moderator
    Feb 26, 2005
    4,281 (1.12/day)
    718
    Little Rock, USA
    The stock paste is probably fine, but if you're going to do some overclocking it would be best to put some Arctic silver/ceramique on.
    99% and 100% Alcohol or acetone will all work great. If you want it really clean use arctic silver ArctiClean.
    Use some type of lint free cloth, definitely not a paper towl as it can leave behind debris that will reduce performance.
    Here is a nice article on applying thermal paste if you need it.
  3. xdaxxchampxx New Member
    Jan 14, 2006
    84 (0.02/day)
    0
    the compound that artic cooling uses is one of the better ones very compareable to as5 you wont notice a diffrence realy :toast:
  4. EnglishLion
    EnglishLion New Member
    Jul 17, 2005
    461 (0.13/day)
    45
    Peterborough, UK
    I used the pre-applied TIM and I got it the wrong way round, removed it and refitted without replacing the TIM and it's still great.
    My Opteron 146 is OC'd from 2 to 2.74Ghz and only just reaches 40C at full load.
    I think correctly applied TIM is a far more important factor than fancy make or type! And you can be sure pre-applied has been evenly applied!
  5. nocrapman New Member
    Mar 5, 2006
    264 (0.08/day)
    5
    Thanks guys - I am going to go with the pre-applied TIM - see how that works - then if need arises - shift to AS5.
Share This Page
