OneMoar
There is Always Moar
- Apr 9, 2010
- 8,746 (1.71/day)
- Rochester area
System Name | RPC MK2.5 |
Processor | Ryzen 5800x |
Motherboard | Gigabyte Aorus Pro V2 |
Cooling | Enermax ETX-T50RGB |
Memory | CL16 BL2K16G36C16U4RL 3600 1:1 micron e-die |
Video Card(s) | GIGABYTE RTX 3070 Ti GAMING OC |
Storage | ADATA SX8200PRO NVME 512GB, Intel 545s 500GBSSD, ADATA SU800 SSD, 3TB Spinner |
Display(s) | LG Ultra Gear 32 1440p 165hz Dell 1440p 75hz |
Case | Phanteks P300 /w 300A front panel conversion |
Audio Device(s) | onboard |
Power Supply | SeaSonic Focus+ Platinum 750W |
Mouse | Kone burst Pro |
Keyboard | EVGA Z15 |
Software | Windows 11 +startisallback |
THIS THIS THISThe typical black fan frames and often propellers as well are made of ABS, a common form of thermoplastic that is also used in the auto industry. It resists shock and vibration fairly well. ABS is also the most common type of plastic used for plastic case parts. Often the stylized clear or translucent colored fans are made of a stiffer, more brittle plastic. One review I skimmed through on that particular fan said it wasn't all that quiet either.
brittle plastic = you will be pulling shards of fanblade out of your skin eventually
brittle plastic also tends to 'rattle' and because the blades will flex when subjected to Resistance they tend to have a lower static pressure (mostly do to them being overly light )
