Front panel audio not working with Realtek
distanthawk
2 (0.00/day)
I just put together a computer for the first time and the computer runs beautifully.
Antec P150 case
ECS 945P-A motherboard
Pentium D 920
2 Gigs memory
Nividia 6700 GT video card
160 Gig SATA drive
I am very happy with my computer, however, 2 little parts are not working.:( The front panel headphone and mic are not working.
I have tried:
-using the 10 pin connector
-hooking up the wires individually in various combinations
-used Realtek drivers from mother board CD
-removed windows XP update drivers
-installed updated drivers from Realtek
Then I contacted Realtek and Antec.
RealTek says "front panel connections must be High Definition, check with case manufacturer"
Case Manufacturer Antec says "none of our cases have High Definition audio"
note:
- have checked my BIOS and Audio is enabled
- the rear panel audio jacks work perfectly
What can I do to fix this?
Can I buy High Definition cables to replace mine?
thanks for any help you can provide
Satchmo
406 (0.06/day)
cali
Processor A64 3200+ @ 2.7ghz Venice S-939 33c idle 40c load
Motherboard MSI RD480 Neo2-FI Crossfire 200
Cooling Arctic ALPINE 64 on CPU, Arctic silencer on GPU
Memory 2x 1GB Wintec Ampo DDR450 2.5,3,3,6 T1 DualChannel
Video Card(s) X1600XT HIS @ 650core/810 44c idle 62c load
Storage HITACHI Deskstar 7K80 80GB 3.5" S-ATA@150mbps
Display(s) CRT 17" E-View
Case Spire BlueFin SP-6190U Blue/Silver
Audio Device(s) Azalia High-Defintion integrated audio
Power Supply Aspire 520 Watt W/ 35a 12v Rail
Software WindowsXP Pro SP2, 6.4 Catalyst, ATI tool .25 beta
high definition analogue 2.5mm speaker wire jacks? are they retarded theyre all the same thing, check your motherboard manual and make sure the J### plugs are set up right. if u already checked, then double check.
distanthawk
2 (0.00/day)
ya, I thought that they were BSing me.
I have spent more than 8 hours on this already, and have tried several combinations on the wires. I need to sleep on this.
shadowfly
1 (0.00/day)
i have the same problem
i updated my BIOS and it suddenly does not work.
i never touched anything inside the computer.
same as the above, audio works perfectly ony the front side audio is dead
, the USB next to it works just fine tough. i cannot find the audio settings
or hardware anywere at all. can i flash my bios back to it's old state or is that possible pc murder?
the only think we have in common however is that i have a 160 gig sataII.
for the rest the machines are completly different
