Front panel audio not working
Discussion in 'General Hardware' started by Nick259, Jun 12, 2008.
  1. Nick259
    Nick259
    Apr 8, 2008
    1,034 (0.36/day)
    166
    Scotland
    Hi, i've plugged in the cable labelled audio to the HD_AUDIO header, but still no sound from the front audio port. It doesn't even register that my earphones are plugged in (though i do get a crackle sound from them). The USB ports are working, so i'm a bit confused. My mobo is an Asrock ALiveSATA2-GLAN (http://www.asrock.com/mb/overview.as...LiveSATA2-GLAN)
    All the back panel stuff is working.
    PS. How can I link a URL using words? Like having 'ALiveSATA2-GLAN' and when i click it it takes me to the web page.
    Thanks.
  2. oli_ramsay
    oli_ramsay
    Sep 22, 2007
    3,480 (1.14/day)
    568
    UK
    Check mobo manual, there's usually a jumper to switch bewtween back panel and in-case audio.
    Nick259 says thanks.
  3. ktr
    ktr
    Apr 7, 2006
    7,405 (2.06/day)
    683
    Most cases has two FP audio headers, one is the AC '97, and the other is HD-AUDIO. Try the AC'97.
  4. Namslas90 New Member
    Aug 27, 2006
    4,851 (1.41/day)
    555
    Earth
    See Your Mobo Manual Item #25 page 10, instructions on page 20, BIOS Setting > Chipset Configuration > Front Panel Audio, page 36.
  5. Nick259
    Nick259
    Apr 8, 2008
    1,034 (0.36/day)
    166
    Scotland
  6. francis511
    francis511
    Oct 16, 2006
    2,555 (0.75/day)
    272
    N.Ireland
    Check the setting below as well
      File size:
      76.6 KB
      1,526
  7. Nick259
    Nick259
    Apr 8, 2008
    1,034 (0.36/day)
    166
    Scotland
    mine only has one, which is HD
    to francis511: Isn't that the AC '97 version of the realtek hd audio manager? I have a differenet one as mine is HD.
    to modder: any chance you could give me a link to that hotfix?
    EDIT: to Namslas90: The instructions given do not work for me. I have a newer bios (whyicvh doesn't have those options) and there is no 'audio/ i/o' menu in my realek drivers.
  8. Nick259
    Nick259
    Apr 8, 2008
    1,034 (0.36/day)
    166
    Scotland
    I managed to find the connector settings menu, and i disabled front panel audio detection as francis said. IT NOW WORKS!!!! I LOVE YOU ALL! (to a certain extent!)
  9. tigger
    tigger I'm the only one
    Mar 20, 2006
    10,199 (2.83/day)
    1,416
  10. modder New Member
    Mar 1, 2008
    382 (0.13/day)
    153
    good
  11. Cold Storm
    Cold Storm Battosai
    Oct 7, 2007
    15,014 (4.93/day)
    3,002
    In a library somewhere on this earth
    as for your PS. with the web link.. Wrap the word in url codec. url= then the websites name then end it with /url. But you have to make sure to put [&] at the start of each URL type.
  12. Nick259
    Nick259
    Apr 8, 2008
    1,034 (0.36/day)
    166
    Scotland
    thanks cold storm. any chance you could post an example?
  13. Cold Storm
    Cold Storm Battosai
    Oct 7, 2007
    15,014 (4.93/day)
    3,002
    The example that I could have you do is quote me. You'll see how the Quote is set up, then just take out the word "quote" and add URL. Then after the = put the web page.
    Bending Steel
  14. Nick259
    Nick259
    Apr 8, 2008
    1,034 (0.36/day)
    166
    Scotland
    ahh i see. thanks :)
  15. Cold Storm
    Cold Storm Battosai
    Oct 7, 2007
    15,014 (4.93/day)
    3,002
    no problem man. Glad to help anyone that asks :toast:
  16. Hayder_Master
    Hayder_Master
    Apr 21, 2008
    5,203 (1.83/day)
    663
    IRAQ-Baghdad
    just like my friend oil say i think there's a jumper to switch bewtween back panel and in-case audio
  17. Nick259
    Nick259
    Apr 8, 2008
    1,034 (0.36/day)
    166
    Scotland
    Yes I think you may be right. It seems that both the speakers and earphones play at the same time. I need to switch the speakers off to use the earphones. Any idea where this jumper may be? I posted a link to the manual above.
  18. sneekypeet
    Apr 12, 2006
    22,807 (6.36/day)
    7,374
    Mine has a setting in the Realtek sound manager to diable speakers when headset is plugged in!
    Start ...control panel...Realtek HD audio....click the advanced settings in the red circle at top left...then tick the box circled in the new window.
    [​IMG]
  19. Nick259
    Nick259
    Apr 8, 2008
    1,034 (0.36/day)
    166
    Scotland
    Thanks sneekypeet but that's already enabled. It makes no differnece.
  20. sneekypeet
    Apr 12, 2006
    22,807 (6.36/day)
    7,374
    sorry , It did on mine...as soon as I plug into front audio it switches the rears right off! Hmmmm.
  21. Nick259
    Nick259
    Apr 8, 2008
    1,034 (0.36/day)
    166
    Scotland
    any advice guys?
  22. modder New Member
    Mar 1, 2008
    382 (0.13/day)
    153
    you can't use use at the same time ,back panel and front audio port (System Panel Header)
    System Panel Header =see page 2 on manual
  23. Nick259
    Nick259
    Apr 8, 2008
    1,034 (0.36/day)
    166
    Scotland
    I'm a bit of noob when it comes to all these connectors. Could you please explain.
  24. modder New Member
    Mar 1, 2008
    382 (0.13/day)
    153
    this is Front Panel Audio Header
    [​IMG]
    [​IMG]
    how are you plugged ?
  25. Nick259
    Nick259
    Apr 8, 2008
    1,034 (0.36/day)
    166
    Scotland
    In my case it's all one cable, not individual ones.
