Galaxy Intros Low-Power 9800 GT Graphics Cards
46,362 (7.68/day)
Galaxy made an addition to the increasing number of low-power GeForce 9800 GT graphics cards taking shape by several NVIDIA partners. The company introduced 512 MB and 1 GB variants. Specs-wise, the cards retain the GPU and memory configurations (112 SP, 256-bit memory interface), while cutting down on clock-speeds to 550/900 MHz (core/memory), from the reference speeds of 600/900 MHz.
The company uses the 55 nm G92 GPU (G92-283-B1), which has a smaller thermal footprint in comparison to its 65 nm variant. The result: cards that do not require auxillary power from the 6-pin PCI-E connector. The 1 GB variant comes with a full-coverage single-slot cooler, while the 512 MB one comes with a simpler radial cooler. Both cards are SLI capable. Display outputs provided on the card include DVI, D-Sub, and HDMI.
2,490 (0.40/day)
Your house.
System Name Jupiter-2
Processor Intel i3-6100
Motherboard H170I-PLUS D3
Cooling Stock
Memory 8GB Mushkin DDR3L-1600
Video Card(s) EVGA GTX 1050ti
Storage 512GB Corsair SSD
Display(s) BENQ 24in
Case Lian Li PC-Q01B Mini ITX
Power Supply Corsair 450W
Mouse Logitech Trackball
Keyboard Custom bamboo job
Benchmark Scores Finished Super PI on legendary mode in only 13 hours.
Holy crap -- 8800GT's that don't require external power. That's actually pretty impressive.
SpatialAnomaly
31 (0.01/day)
Exploring Mirkwood
Processor Intel Core 2 Duo 8400 Wolfdale @ 3.5ghz
Motherboard XFX 680i LT
Cooling Thermaltake Silent775D
Memory 4gb Crucial Ballistix Tracer Red DDR2
Video Card(s) EVGA 9800 GTX+ 512mb
Storage WD Black 500gb 32mb SATA
Display(s) ACER 17"
Case Antec 900
Audio Device(s) On board
Power Supply Ultra X-2 750watt
Software VISTA/XP Dual Boot
If they can produce the same performance as the cards that need a 6pin power plug, then it's great. Can they?
Don't think so since they reduced the clocks. Seems like putting a throttle lock on a product, but calling it the same thing as the full-power version.
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
50Mhz on the core will hardle be noticeable, and you will likely be able to overclock the cards right back to stock speeds.
nazaropeth
33 (0.01/day)
Zielona Gora, Poland
System Name Poor&Old
Processor AMD Athlon 64 2800 S754 @2260MHz HTT1000MHz
Motherboard GIGABYTE GA-K8N51GMF GF6100
Cooling Stock AMD Cooler
Memory 2x512MB RAM DDR PC3200 CL 3-3-3-8
Video Card(s) Powercolor ATI HD4650 SCS 512MN DDR2 @ 650/850MHz
Storage WD1600AAJS & ST3250301AS
Display(s) COMPAQ S710
Case Lifetec mATX
Audio Device(s) onboard Realtek ALC850 AC'97
Power Supply Mode-Com FEEL 300W
Software Windows XP Home SP3
Benchmark Scores 3DMark05 - 8652
Next card that not required external power... That's isn't good for mainboard cause extra 70W comes over the PCB... External conector has another good point, it's giving chance to extra overclock by giving more power, when the card need that.
alexp999
Staff
8,012 (1.31/day)
Dorset, UK
System Name Gaming Rig | Uni Laptop
Processor Intel Q6600 G0 (2007) @ 3.6Ghz @ 1.45625v (LLC) / 4 GHz Bench @ 1.63v | AMD Turion 64 X2 TL-62 2 GHz
Motherboard ASUS P5Q Deluxe (Intel P45) | HP 6715b
Cooling Xigmatek Dark Knight w/AC MX2 ~ Case Fans: 2 x 180mm + 1 x 120mm Silverstone Fans
Memory 4GB OCZ Platinum PC2-8000 @ 1000Mhz 5-5-5-15 2.1v | 2 x 1GB DDR2 667 MHz
Video Card(s) XFX GTX 285 1GB, Modded FTW BIOS @ 725/1512/1350 w/Accelero Xtreme GTX 280 + Scythe sinks| ATI X1250
Storage 2x WD6400AAKS 1 TB Raid 0, 140GB Raid 1 & 80GB Maxtor Basics External HDD (storage) | 160GB 2.5"
Display(s) Samsung SyncMaster SM2433BW @ 1920 x 1200 via DVI-D | 15.4" WSXGA+ (1680 x 1050 resolution)
Case Silverstone Fortress FT01B-W ~ Logitech G15 R1 / Microsoft Laser Mouse 6000
Audio Device(s) Soundmax AD2000BX Onboard Sound, via Logitech X-230 2.1 | ADI SoundMAX HD Audio
Power Supply Corsair TX650W | HP 90W
Software Windows 7 Ultimate Build 7100 x64 | Windows 7 Ultimate Build 7100 x64
Benchmark Scores 3DM06: 19519, Vantage: P16170 ~ Win7: -CPU 7.5 -MEM 7.5 -AERO 7.9 -GFX 6.0 -HDD 6.0
You'll only be able to clock these back up on a PCI-E 2.0 mobo, due to the power constraints.
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
I'm sure the 50MHz will be possible on 1.1 boards too, I think you will get better results on a 2.0 board, but taking them back to stock clocks shouldn't be an issue.
alexp999
Staff
8,012 (1.31/day)
Dorset, UK
Agree with that, I was thinking more on the proper overclock side, lol.
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
These definitely won't be great in the overclocking department, that is for sure, but there are alternatives if you want a good overclocker. These would be great in a HTPC though.
Mussels
Freshwater Moderator
58,413 (8.19/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
lowering the clocks is not what saved the power - lowering the core voltage is what saved the power.
You wont be clocking it back up very far without BIOS modding the voltage back up, and even then, you wont get far on a 1.1 board. you need to extra power of a 2.0 board, or the 6 pin power for that.
squallho1
Galaxy Representative
15 (0.00/day)
Hong Kong
This part is not designed for overclock right? For overclocking we have some other nice SKUs... :)
Kursah
Super Moderator
14,673 (2.29/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
True, but it'd be sweet to get some slightly decent clocks off of such a card. Just seeing this is a good thing in this day and age, and it shows the performance that these companies can truly fit into the smaller pcb sizes of yore. I think it's probably cheaper and easier for the larger cards, but it's good to see still competent technology get attention to the point of this. Next up is 4870's and GTX260's on pcb's this size dammit! Well, I wish...
:toast:
Mussels
58,413 (8.19/day)
Oystralia
It may not be designed for it, but that wont stop us from trying :)
2,431 (0.42/day)
System Name Dell Workstation t5810
Processor Xeon CPU's E5-2683 v4 Broadwell-E Technology
Motherboard Broadwell-E X99
Cooling Default fan System Level 3
Memory 48GB DDR4
Video Card(s) ASRock Vega 56 8GB
Storage 4 External SSD, 4 External HDD
Display(s) HP 27m LCD
Case Dell Precision 7810 Case
Audio Device(s) RealTek High Definition
Power Supply 825 Watts PSU
Mouse Soundless Black Quiet Mouse
Keyboard Dell Black
Software Windows Pro 10 x64
Interesting cards, a plus for not having to hook up anything to it.
5,250 (0.90/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
cool but seems can't overclock much , but can the mobo handle 4 of this in SLI
Mussels
58,413 (8.19/day)
Oystralia
with only one SLI bridge, its limited to 2 cards in SLI.
Pity, it woulda made a cheap, low power quad SLI solution.
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
Or even a tri-sli option, I really wish manufacturers would start to release tri-sli capable 9800GTs and 9600GTs also.
Mussels
58,413 (8.19/day)
Oystralia
two bridges works for tri and quad SLI. one bridge only works for two cards.
5,250 (0.90/day)
IRAQ-Baghdad
System Name MASTER
you right it is only have one bridge
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
I didn't think the two bridges allowed for Quad-SLi, only Tri. I thought the only way to get Quad-SLi was to buy two 9800GX2's or GTX295's.
Mussels
58,413 (8.19/day)
Oystralia
im not sure if it works with quad on single GPU cards, but look at the SLI connector.
. as long as an empty bridge lines up between teh cards, you can connect em... whether or not it works on current NV drivers, i dont know.
edit: i had little pictchas. due to them not looking right, i edited em out./
