[Case Gallery] GATEWAY PC SLEEPER
786 (0.11/day)
Yulee ,Florida
System Name 1080/1440 Beast
Processor Ryzen 7 5700x @4848.87Mhz
Motherboard Asus ROG Strix B550-F Gaming
Cooling Cooler Master ML240L RGB V2
Memory 64 GB 4x16 GB GSkill Trident Z Neo 3600Mhz CL16
Video Card(s) AMD Radeon™ XFX Speedster MERC 319 RX 6750 XT Black 12 GB /\ Core 2725Mhz Vram 2312 UV 1145mv
Storage WD SN850 Black 1TB M.2 OS C: / Samsung 860 evo 500GB SSD Disk 2/ Western Digital 1TB SATA3 Disk 3
Display(s) Dual Monitors Samsung G5 G55C 32" Curved 165 Hz 1440p HDR / MSI G32C4W 31.3" Curved 165Hz 1080p
Case Vetroo Mesh6
Audio Device(s) Logitech Z-2300 2.1 THX Series / RIG 800 LX Dolby Atmos
Power Supply Thermaltake Smart 700watt
Mouse Asus
Keyboard Asus
Software Windows 11 64bit Home
Benchmark Scores CB R23 15306 SuperPos. 4K 10980 CpuZ 667.3/6728.2 TimeSpy 14,090
Specs:
GATEWAY 827GM MEDIA CENTER PC///AMD ATHLON64 3500+ (NEWCASTLE)O/C @2.517 GHz/DIAMOND VIPER ATI X1300 PCIE 256MB/1 GIG PC3200 DUAL CHANNEL 256MBx4/LITE ON 16X DL DVD RW/50X CD ROM/MSI MS7093 MOBO/WINTV TUNER CARD/WESTERN DIGITAL 200GB HD@7,200 RPMS 2MB CACHE/WINDOWS XP MCE 2005/8 IN 1 CARD READER
Mods:
3 AEROCOOL XBLASTER 80mm FANS@4,000 RPMS@54 CFM/1 MASSCOOL PCI SLOT FAN@4,500 RPMS@16 CFM/1 AEROCOOL 60mm FAN@3,800 RPMS@40 CFM/DIAMOND VIPER ATI X1300 PCIE 256MB CARD/ACER AL1751 17" LCD MONITOR/LOGITECH Z-2300 THX 2.1 200 WATT RMS SPEAKERS
WHEN I BOUGHT THIS PC IN APRIL OF 2005 I ONLY HAD ENOUGH MONEY TO BUY THE TOWER ONLY SO I NEEDED TO GET THIS PC UP TO PAR BOUGHT AN ADDITIONAL 512 MB OF RAM FOR ONLY $60.NEXT I BOUGHT MY MONITOR AN ACER AL1751 MONITOR 700:1 RATIO AND 8MS DVI/VGA FOR ONLY $230 NEXT I NEEDED SOME VIDEO GOT THE X1300 PCIE FOR ONLY $99.AFTER THAT NEEDED SOME TUNES THEN FOUND THESE LOGITECH THX Z-2300 2.1 200 WATTS RMS 400 WATTS MAX NORMALLY $150 FOR $60 AT TIGER DIRECT/NOW CAME THE COOLING PART WELL BEING ON A BUDGET BEING A COLLEGE STUDENT AND ALL I BOUGHT 3 AEROCOOL XBLASTER 80mm FANS @$11 EACH 1 TO REPLACE THE EXHAUST FAN 1 TO REPLACE CPU FAN AND 1 ON MY HARD DRIVE. THEN GOT A MASSCOOL EXPANSION SLOT FAN TO COOL MY VIDEO @$7. THEN GOT A AEROCOOL 60mm FAN TO PUT IN FRONT OF MY POWER SUPPLY TO HELP MORE AIRFLOW @$5. I WANTED TO KEEP IT LOOKING STOCK BUT HAVE ENOUGH AIRFLOW WITH THE CRAPPY CASE DESIGN IT DOESNT HAVE A FRONT INTAKE SLOT FOR FRONT AIRFLOW SO I HAD TO MAKE THIS CASE MOSTLY AN EXHAUST CASE. BUT IT DOES STAY COOL AT FULL LOAD 30 CELSIUS AMBIENT 39 CELSIUS CPU AND 26 CELSIUS ON THE HARD DRIVE AT IDLE ITS 21 AMBIENT 26 CPU AND 17 HARD DRIVE. NOW JUST NEED TO REPLACE MY PSU AND CABLES AND SOME LIGHTS AND ITS SET JUST NEED TO WAIT A LITTLE WHILE.NOW WITH THE TOWER COSTING $809 AND EVERYTHING ELSE IT CAME OUT TO $1,303 NOT BAD AT ALL AND IT WORKS GREAT WITH UNREAL TOURNAMENT 2004 (USERNAME:AMD64_3500+) IF YOU WANTED TO KNOW NORMALLY PLAYING ON SERVER NETCADES MUTATORS OF DEATH. THIS IS THE BEST BANG FOR THE BUCK PC U COULD GET . ANY ?'S OR SUGGESTIONS EMAIL ME AT AMD64SKATER@YAHOO.COM
N
nine7
Here's a suggestion, never ever put a pc component of any kind on the floor, especially when it's carpet!
floor + $pc part$ = expensive piece of nonworking hardware
165 (0.02/day)
Philadelphia, PA
System Name Heaven-Cf
Processor AMD Athlon 64 X2 5000+ BE Brisbane (215Mhz x15) 3.225Ghz 1.35v Rev BH-G2 8.5hrs prime stable
Motherboard Asus M2R32-MVP (2 PCI, 2 PCI-E x1, 2 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN, IEEE-1394)
Cooling Xigmatek HDT-S 1283 + AS5 Cpu, Stock GPU Fan, 2 80mm fans, 1 120mm 110CFM Silverstone 2 PSU fans
Memory OCZ ATI CrossFire 2GB (2 x 1GB) DDR2 800 400.3 MHz CPU/7 4-4-4-12-23 2T 1.9v
Video Card(s) POWERCOLOR AX4870 512MD5 Radeon HD 4870
Storage Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS (250 GB, 7200 RPM, SATA-II)
Display(s) Hanns-G HD191-D 2ms 700:1 16.2 million colors
Case APEVIA X-CRUISER-BK Black Steel ATX Mid Tower
Audio Device(s) Creative Sound Blaster X-Fi Titanium Fatal1ty Professional
Power Supply PC Power & Cooling Silencer 750 EPS12V EPS12V 750W
Software XP Pro Tweaked
Benchmark Scores x1950xtx: 3d Mark 03/05/06 - 18467/11383/6478 | Super Pi 32MB 27m 8.110s
Um All Caps Is Annoying Lol
Clocked
284 (0.04/day)
Toronto
System Name Evil Eye POS
Processor Intell Q6600 G0 @ 3.6Ghz
Motherboard EVGA 680i
Cooling DangerDen/SwiftTech water cooling
Memory 4GB OCZ SLI 800mhz @ 1260mhz
Video Card(s) 8800GTX x 2
Storage WD Raptor74GB in RAID/ 160GB Maxtor/ 80GB WD
Display(s) Samsung 740n 17"
Case SunBeam Evil Eye
Audio Device(s) Onboard POS
Power Supply PC Power n Cooling 1000W
Software XP Home/Vista Pro
Not really a budget build... i mean 1300... thats an arvage build... if that was a turly custom computer it would cost less then 1000
786 (0.11/day)
Yulee ,Florida
Case Vetroo Mesh6
Mouse Asus
Keyboard Asus
suggestions please!!!!
If u guys can give me some suggestions to help with this work in progress im building this pc on a really tight budget so i have to find things to make this pc better plus i will be getting more ram to make it a 4 gig rig and rounded ide cables and neons. like i said if u have a suggestion on this pc i will check and see if any ideas can be used and in my budget and i will update my pics when i have added more to this pc.
wazzledoozle
5,358 (0.71/day)
Seattle
Processor X2 3800+ @ 2.3 GHz
Motherboard DFI Lanparty SLI-DR
Cooling Zalman CNPS 9500 LED
Memory 2x1 Gb OCZ Plat. @ 3-3-2-8-1t 460 MHz
Video Card(s) HIS IceQ 4670 512Mb
Storage 640Gb & 160Gb western digital sata drives
Display(s) Hanns G 19" widescreen LCD w/ DVI 5ms
Case Thermaltake Soprano
Audio Device(s) Audigy 2 softmod@Audigy 4, Logitech X-530 5:1
Power Supply Coolermaster eXtreme Power Plus 500w
Software XP Pro
I suggest you remove the caps, and insert some grammar.
zekrahminator
McLovin
9,066 (1.29/day)
My house.
Processor AMD Athlon 64 X2 4800+ Brisbane @ 2.8GHz (224x12.5, 1.425V)
Motherboard Gigabyte sumthin-or-another, it's got an nForce 430
Cooling Dual 120mm case fans front/rear, Arctic Cooling Freezer 64 Pro, Zalman VF-900 on GPU
Memory 2GB G.Skill DDR2 800
Video Card(s) Sapphire X850XT @ 580/600
Storage WD 160 GB SATA hard drive.
Display(s) Hanns G 19" widescreen, 5ms response time, 1440x900
Case Thermaltake Soprano (black with side window).
Audio Device(s) Soundblaster Live! 24 bit (paired with X-530 speakers).
Power Supply ThermalTake 430W TR2
Software XP Home SP2, can't wait for Vista SP1.
there were alot of mods there that usually go underappreciated...I see SOME attempt at cable management, which I know can be a pain inside a retail case of any sort. You also did a good job trying to keep your GPU cool for extra modding (but try moving that cyclone down a slot, I dont think its making direct contact with the GPU heatsink, so its not really doing your GPU too much good). replacing CPU heatsinks/fans also was a good idea.
zekrahminator
McLovin
9,066 (1.29/day)
My house.
lol 4 gigs in a budget build? 4 gigs would eat you're budget alive! Stick with one gig of RAM if you really want more then 512MB at all. and look for stuff around this area-
-Used CRT/your TV $0
-XP Home $100
-Gigabyte s478 motherboard $70
-P4 2.4ghz $120
-Cooler Master Case $50
-WD 80GB SATA $50
-1 GB RAM PC3200 $70
-DVD reader/CD burner $20
-9800SE (softmod it later) $70
-Arctic Cooling VGA Silencer (dont
softmod without this or something
like it) $20-30
-Consider an aftermarket CPU
cooler, Intel doesnt make the
northwoods anymore... $10-40
Total Cost without shipping- $580
With Estimated shipping from
Newegg.com- $640
165 (0.02/day)
Philadelphia, PA
Isnt bad if its your first time dabling with this stuff. I have been doin it for a while now.
Cheap + Insane = 90% Chance of Failure, Over 36hrs of Effort and Hardwork, Over another 36hrs of research on parts etc, and 1% Chance that it all works out and u are considered a god. Cheap in my book is under $1k.
Not to mention im working on a list should be done by end of the month for computer builds cause shortly i am going to try and setup a computer building company. The thing that seperates me from the rest of the guys is i will overclock the parts for you if you want for a price of course. I put an exhaustive amount of research into this and still alot to come.
Btw for what you spent i could do this base build Add a XFX 7800 GT $250 Change ram to 4 Gigs 2x 2GB XMS Dual Channel Kits Add $500. So for about the price you spent i have an incredible computer. And i would still have the other to use as a ftp server or somethin. But like i said i have done this for a long long time.
But believe me you could have done a lot and i mean alot worse then what you did. You should see some horror shows people have built. It also depends on ur region if ur in the Continental US u could have done what i did otherwise you did pretty good.
2,481 (0.35/day)
Not bad. But just like what everyone said, this is not a budget build. I wouldnt even consider my rig a budget build and I spent $800 on mine (6 months ago). It is very similar to what MDK listed. I personally would consider a budget build prob. $600 or less. Also, it is interesting to see these budget builds since people usually OC them and make them as good as double what they are worth.
MDK22 I am also in the business of making computers. However, I have not OC anything yet and am really interested. I spend a lot of time researching, asking questions and building PCs, its quite fun. Gotta get rdy for certification this year too which will be quite kewl. I was wondering if you could give me any tips and where to start with OCing. Figure I could try it on a cheap system (looking to build one since I got a few spare parts round and a free desk). Thanks and drop me a message some time.
Polaris573
Senior Moderator
4,268 (0.58/day)
Little Rock, USA
Processor LGA 775 Intel Q9550 2.8 Ghz
Motherboard MSI P7N Diamond - 780i Chipset
Cooling Arctic Freezer
Memory 6GB G.Skill DDRII 800 4-4-3-5
Video Card(s) Sapphire HD 7850 2 GB PCI-E
Storage 1 TB Seagate 32MB Cache, 250 GB Seagate 16MB Cache
Display(s) Acer X203w
Case Coolermaster Centurion 5
Audio Device(s) Creative Sound Blaster X-Fi Xtreme Music
Power Supply OCZ StealthXStream 600 Watt
You did a great job, but if you are going to start modding the case and adding neon lights and such you might want to consider buying a case that would do it justice. You can pick up a coolermaster centurion for around $50. They're pretty good cases.
N
nine7
I would stick with the current case and modifiy it, which is much cheaper. I'm not sure about a gateway, but you might run into a problem fitting the PSU from that case into a aftermarket one.
There are plenty of tutuorials on how to paint, cut, or whatever. For less than $50, you can give it a whole new look.
The cheapest thing you could do is take those decals/stickers off!
786 (0.11/day)
Yulee ,Florida
Case Vetroo Mesh6
Mouse Asus
Keyboard Asus
ok its not a budget build
ok its not a budget build but i am trying to make it better on a budget so i research hours on end to find things i can do to it for cheap plus anyone have any ideas on some side panel mods i can do to this i dont have tools to cut it yet but im going to get some what works best like a dremmal tool or something. also can tell me how to overclock this cpu on this board if it can be done or should i not do it dont know some one tell me
Drewstyle
Nice cpu, to be a custom rig I would ditch the gateway case and do the cables like you mentioned .
786 (0.11/day)
Yulee ,Florida
Case Vetroo Mesh6
Mouse Asus
Keyboard Asus
i like the case
i like my case i want it to appear stock but not be inside. everytime i goto lan parties they laugh at first then r like ok u got some balls in there we were wrong then i get the im sorrys and its all good after that i know i dont have the best but i dont have to worst either
786 (0.11/day)
Yulee ,Florida
Case Vetroo Mesh6
Mouse Asus
Keyboard Asus
x1300
bruins004 said:
Does the x1300 keep you back in games? Just curious how the x1300 does.
the x1300 is pretty good but the only drawback it only has 4 pipelines but it does keep up with many games like fear,ut2004,and counter strike but it does way better than my old x700 and for the price its not bad at all the x1300 can hold its own
4,667 (0.69/day)
Washington, US
System Name Rainbow
Processor Intel Core i7 8700k
Motherboard MSI MPG Z390M GAMING EDGE AC
Cooling Corsair H115i, 2x Noctua NF-A14 industrialPPC-3000 PWM
Memory G. Skill TridentZ RGB 4x8GB (F4-3600C16Q-32GTZR)
Video Card(s) ZOTAC GeForce RTX 3090 Trinity
Storage 2x Samsung 950 Pro 256GB | 2xHGST Deskstar 4TB 7.2K
Display(s) Samsung C27HG70
Case Xigmatek Aquila
Power Supply Seasonic 760W SS-760XP
Mouse Razer Deathadder 2013
Keyboard Corsair Vengeance K95
Benchmark Scores 4 trillion points in GmailMark, over 144 FPS 2K Facebook Scrolling (Extreme Quality preset)
Yeah.. I agree with most of the comments. It's not really a budget, although it is a sleeper. My machine is about 2-3 years old. Sempron 3100+, Radeon 9800 pro, DFI LanParty UT nForce3 250gb, 512mb Corsair XMS PC3200. It owned all the games out at the time. I spent less than $800. Since then, I've sold my 3100+ and bought a 3400+ and an X850 Pro for a total of about $150. HL2 maxed (no AA/AF) and I get 60+FPS average. Battlefield 2, Need For Speed, and most other games can go maxed and still be smooth.
Next time, I'd just go for a custom build. A budget build Athlon 3500+ and x1300 shouldn't cost more than $500 US.
By the way, you should have that sub at least 2 feet away from any electronics (especially storage devices) that you don't want to risk turning into paperweights. I doubt it will hurt much, but keep that in mind when you bring things around it such as credit cards, flash drives, hard drives, etc.
