Geforce 4 problems, not an old card.
Discussion in 'Graphics Cards' started by Joshmcmillan, Mar 15, 2007.
  1. Joshmcmillan
    Joshmcmillan New Member
    Feb 7, 2007
    892 (0.31/day)
    63
    Australia, NSW,Mid North Coast.
    I have a Geforce 4 MX 440 and it's not very old, was bought for AUD$60 a year or so ago, palet brand, no fan just a heat sink that's stock, never overclocked. The thing is in games there is corruption and the picture is messed up, It done this when it was new but I just reinstalled driver and it worked. But now i'v tried taking card out and reinstalling driver and nothing helps. Any suggestions?
  2. Zalmann
    Zalmann New Member
    Feb 25, 2007
    910 (0.32/day)
    3
    Perth, Australia
    Josh, even the MX440 would need a heatsink if it doesn't have one. The ones used for the MX440 would probably be the smaller type (similar to that used on some MB northbridges).
  3. Joshmcmillan
    Feb 7, 2007
    892 (0.31/day)
    63
    I said "it doesn't have a fan, just a heatsink", which means it does have a heat sink. Any suggestions for a way to fix the corruption? By the way it's the newer type of MX440, the worse one.
  4. Zalmann
    Zalmann New Member
    Feb 25, 2007
    910 (0.32/day)
    3
    Perth, Australia
    Just do a clean install. Use some sort of utility program to remove ALL existing drivers, and install the latest forceware from NVIDIA.
  5. hat
    hat Maximum Overclocker
    Nov 20, 2006
    16,991 (5.76/day)
    2,085
    Ohio
    try a PCI slot fan?
    Crunching for Team TPU 5 Million points folded for TPU
  6. zekrahminator
    zekrahminator McLovin
    Jan 29, 2006
    9,113 (2.81/day)
    321
    My house.
    If you're getting in-game corruption but 2D things like Windows are not affected, then you need new cooling for that card. If you're getting 2D corruption, time for a new graphics card. However, a GF4 MX is simply a GF2 with extra overclocking, so....why not use this corruption as an excuse to upgrade? :).
  7. Dippyskoodlez
    Jul 1, 2005
    5,095 (1.47/day)
    238
    Kansas City, KS
    No, 99% of MX cards were sold without a heatsink.
    Sounds like he has a PCI card right beside the card giving it little to no airflow, or a poorly designed case.
    Give it some airflow, it should be fine. My gainward MX440 managed nearly a 50% overclock, completely passive.
  8. Joshmcmillan
    Feb 7, 2007
    892 (0.31/day)
    63
    It's an agp mx440. It has a heatsink. It has worked in same case for years, only started doing this after a format of hd.
Share This Page
