Going Intel, Need Help With Build
Discussion in 'System Builder's Advice' started by TricksterMatt, Sep 10, 2009.
  1. TricksterMatt
    TricksterMatt
    Mar 21, 2009
    262 (0.12/day)
    3
    Hey guys, I'm going to upgrade to Intel build soon, need help with build, I am mostly using it for gaming and video editing and encoding... I'm going with an i7 920 processor, I have no clue about intel motherboards or builds or anything at all, I've been AMD in my life... So could you give me a really decent cheap intel motherboard for i7 920 processor, also I'm getting a GTX 260 and 6GB DDR3, no need for any SLI or Xfire or anything like that. This is what I had in mind :
    Budget = £600ish
    Motherboard =ASUS P6T SE iX58 Socket 1366 8 Channel Audio ATX Motherboard = http://www.ebuyer.com/product/161061
    Processor = Intel Core i7 920 D0 2.66GHz Socket 1366 8MB Cache Retail Boxed Processor = http://www.ebuyer.com/product/151477
    RAM = Corsair 6GB (3x2GB) DDR3 1600MHz XMS3 Dominator Memory CL8(8-8-8--24) for i7 Motherboards = http://www.ebuyer.com/product/152641
    GPU = 896MB XFX GTX 260 Black 55nm, 2000MHz GDDR3, GPU 680MHz, Shader 1440 MHz, 216 Cores, + 3D/Batman = http://www.scan.co.uk/Products/896M...666MHz-216-Cores-2xDL-DVI-I-HDTV-plus-FarCry2
  2. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,482 (2.14/day)
    2,421
    S.E. Virginia
    Crunching for Team TPU
  3. marsey99
    marsey99
    Jul 18, 2007
    1,799 (0.65/day)
    392
    i would look at the Gigabyte GA-EX58-UD3R and save a couple of quid.
    also i would look on aria.co.uk as they are cheap (ish and if you ask nicley they will price match :D) and very good with rma.
  4. rickss69
    Aug 23, 2009
    2,431 (1.21/day)
    604
    Rockvale TN (Not Australia)
  5. TricksterMatt
    TricksterMatt
    Mar 21, 2009
    262 (0.12/day)
    3
    wats the mobo like the one i linked? is it bad?
  6. marsey99
    marsey99
    Jul 18, 2007
    1,799 (0.65/day)
    392
    its a good one, if overspeced for what you want and you asked for advice on a good cheap mobo :)
  7. TricksterMatt
    TricksterMatt
    Mar 21, 2009
    262 (0.12/day)
    3
    yeah, is my other parts alright? And is the gigabyte one you said be the best one for my parts? and I'm only overclocking my i7 920 to around 3.2 ghz on air
  8. marsey99
    marsey99
    Jul 18, 2007
    1,799 (0.65/day)
    392
    well no, the best one will be the most expensive one with all the bells and whistles bolted on to it, just you said you dont need sli/xfire so getting one with 4 pci-e slots (for eg) would just be wasting your cash on features you dont want or need.
    the ud3r clocks quite well, looks quite nice (moreso for a giga mobo as they normally fugly) and isnt that expensive, which seems to be what your looking for.
  9. DrOctopus
    DrOctopus New Member
    Apr 7, 2009
    81 (0.04/day)
    7
    Melbourne, Australia
    if you do save some money on getting a cheaper mobo, you should consider going for a 4890 or gtx275. considering your only gonna use one card, either of these are a good step up.
Share This Page
