- Feb 7, 2008
- 682 (0.12/day)
- Barcelona, Catalonia, Spain
System Name | The Phoenix (rev. 3.0) |
Processor | Intel Core i9 9900K @ 4.9GHz (1.18V) |
Motherboard | ASUS TUF Z390 PRO-GAMING |
Cooling | Custom Full Loop w/EKWB & Swiftech components |
Memory | 32GB Corsair Vengeance RGB Pro 3200MHz (C15) |
Video Card(s) | MSI GTX 1080 SeaHawk X EK @ 2.15GHz/5.5GHz |
Storage | Samsung 970 EVO+ (2x500GB) + Toshiba X300 (4TB) |
Display(s) | LG 29UM65-P (2560x1080 @ 75 Hz) |
Case | Thermaltake Core V51 |
Audio Device(s) | Razer Kraken 7.1 & Scarlett 2i4 w/M-AUDIO BX5-D2 |
Power Supply | Corsair RM750 (ver. 2019) |
Mouse | Logitech G700s |
Keyboard | Razer Blackwidow Chroma V2 |
Software | MacOS 10.13.6 "High Sierra" & Windows 10 Pro x64 |
Well, hi all, this morning i lost the head for moments and after buying the OCZ ModXStream 780W i purchased the required materials for going into liquid cooling system, here's the list i've purchased:
Generic pump, not the best one, the only part i'd gone cheap.
Radiator is a Black ICE Gt Stealth 120
Waterblock is Enzotech Sapphire SCW-1 (real mirror finish, i'm impressed)
Tank is a ThermalTake Aquabay M3
Fan SilentX iXtrema Pro Series 120mm
Don't know if are the best parts but i'm sure they're not bad at all, they were recommended by the owners of the shop i use to go ... so i'm giving a chance to them. The main doubt is i don't know how to build the circuit at all ... or how to start building without blurring anything, i'm confusing in the part of inlet, outlet disposition, cpu goes to rad ... then pump and then reservoir? any guides of where should i start?
One last question, enzotech waterblock includes some Arctic Silver Ceramique compound, i have Arctic Cooling MX-2 which is supposed to be better, but since this is not air .. i'm confused, which compound should i use?
Thank you all in advance
