Going to go water cooling and need some help .
trickson
OH, I have such a headache
7,595 (1.07/day)
Planet Earth.
System Name Ryzen TUF.
Processor AMD Ryzen7 3700X
Motherboard Asus TUF X570 Gaming Plus
Cooling Noctua
Memory Gskill RipJaws 3466MHz
Video Card(s) Asus TUF 1650 Super Clocked.
Storage CB 1T M.2 Drive.
Display(s) 73" Soney 4K.
Case Antech LanAir Pro.
Audio Device(s) Denon AVR-S750H
Power Supply Corsair TX750
Mouse Optical
Keyboard K120 Logitech
Software Windows 10 64 bit Home OEM
wolf
Performance Enthusiast
7,753 (1.25/day)
System Name MightyX
Processor Ryzen 5800X3D
Motherboard Gigabyte X570 I Aorus Pro WiFi
Cooling Scythe Fuma 2
Memory 32GB DDR4 3600 CL16
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
looks good man, should be plenty.
ive cooled a 8800GTX + 3.6Ghz dual core in 1 loop with 1 x 120mm radiator and both were cooled better than their stock coolers by a good margin, so with a dual rad doing only cpu + nb should go well
spearman914
3,338 (0.57/day)
Brooklyn, New York 11223
System Name Mine | Dad + Mom
Processor E8500 E0 Wolfdale @ 4.6GHz 1.5V | E2180 M0 Allendale @ 3.0GHz 1.3V
Motherboard Asus Maximus Formula (X48) w/ Rampage BIOS | Asus P5Q Pro (P45)
Cooling Xigmatek Rifle HDT-S1283 w/ SFF21F Fan | Arctic Cooling Freezer 7 Pro
Memory G.Skill Pi Black 2x2GB 1.02GHz CL5 | OCZ Reaper 2x2GB 1.05GHz CL5
Video Card(s) Sapphire 4870X2 2GB 820/1020MHz | Sapphire 4850 1GB 700/1100MHz
Storage WD VR 150GB 10K RPM + WD 500GB 7.2K RPM | WD 200GB 7.2K RPM
Display(s) Acer P243WAID 24" 1920x1200 LCD | Acer V193W 19" 1440x900 LCD
Case Cooler Master HAF 932 Full-Tower | Antec Twelve Hundred Mid-Tower
Audio Device(s) Fatal1ty Xtreme Gamer w/ Z-5500 5.1 | On-Board Audio w/ S-220 2.1
Power Supply PC Power and Cooling 750W Non-Modular | Corsair HX-520W Modular
Software Windows Vista Home Premium X64 | Windows Vista Home Premium X64
Benchmark Scores Not Wasting Time!
The H20-220 were meant for beginners. I highly suggest u do a custom one.
trickson
7,595 (1.07/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Well I am a beginner in the water cooling out fits and I don't need all that confusion I just want a good setup that is going to be easy and fast and do the job .
Will this do it ? I think it should I want some thing better than what I have 40c idle and 70c loaded . I sure hope that this will be enough to take the temps down .
12,453 (1.98/day)
Yankee lost in the Mountains of East TN
Processor 5800x(2)/5700g/5600x/5600g/2700x/1700x/1700
Motherboard MSI B550 Carbon (2)/ MSI z490 Unify/Asus Strix B550-F/MSI B450 Tomahawk (3)
Cooling EK AIO 360 (2)/EK AIO 240, Arctic Cooling Freezer II 280/EVGA CLC 280/Noctua D15/Cryorig M9(2)
Memory 32 GB Ballistix Elite/32 GB TridentZ/16GB Mushkin Redline Black/16 GB Dominator
Video Card(s) Asus Strix RTX3060/EVGA 970(2)/Asus 750 ti/Old Quadros
Storage Samsung 970 EVO M.2 NVMe 500GB/WD Black M.2 NVMe 500GB/Adata 500gb NVMe
Display(s) Acer 1080p 22"/ (3) Samsung 22" 1080p
Case (2) Lian Li Lancool II Mesh/Corsair 4000D /Phanteks Eclipse 500a/Be Quiet Pure Base 500/Bones of HAF
Power Supply EVGA Supernova 850G(2)/EVGA Supernova GT 650w/Phantek Amps 750w/Seasonic Focus 750w
Mouse Generic Black wireless (5)
Keyboard Generic Black wireless (5)
Software Win 10/Ubuntu
I had the 120 version of that setup for my first WC experience. I will tell you that the block/pump combo is loud, and it vibrates like crazy. It cools decent, but not nearly as well as my custom setup. I'd compare it to a better air cooler. To be honest, the custom "kits" from Petras and DD are just about as easy to set up as the swiftech kit.
trickson
7,595 (1.07/day)
Planet Earth.
Cooling Noctua
Mouse Optical
So this is a better kit ?
http://www.petrastechshop.com/pecod4.html
What water block do I get and what ChipSet cooler block do I get ?
http://www.petrastechshop.com/nowa.html
12,453 (1.98/day)
trickson
7,595 (1.07/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Yes, that is a much better kit. As far as the chipset block, I'd suggest an EK block...but there are people here with much more WC experience than me that may have an opinion.
OK that is the kit I will get but I really need a chipset water block any one please let me know what will work . I just do not know are they all universal ?
And EK there are like ten so what one really ?
trickson
7,595 (1.07/day)
Planet Earth.
Cooling Noctua
Mouse Optical
I still need your help with the chipset water block . any one ?
Odin Eidolon
920 (0.16/day)
Rockclimbing somewhere in Italy
Processor e6300 @ 3000, stock Volts
Motherboard msi p35 neo2-FIR
Cooling HDT-1283
Memory 2gb tracers 1066 micron d9GMH, cooled by a modded CoolIt Memory Cooler
Video Card(s) HIS 4850 ICEQ4
Storage WD Caviar 16 320gb WDAAKS + 640gb WDAAKS
Case CM RC-690 sligthly modded
Power Supply Bequiet darkpower PRO 850W (say overkill? :D)
Software kubuntu 8.10 + Windows XP, soon Windows 7 too
the kit you suggesteds from petra is good, but keep in mind that d4 pumps are damn loud. h20-220 is an excellent kit for the money, and you can do a simple upgrade when you want, adding a new cpu block and a pump top for the apogee drive (which basically is a mcp350, one of the quitest pumps around)
as for the nb, why you wanna watercool it? it isnt really THAT hot. if it is, put a fan over it and you will be fine. if you wanna wc it anyhow, grab a swiftech or ek waterblock, great price/perf ratio. BTW since nb dont generate that much heat, it doesnt really need a killer waterblock, any choiche will be good, not varying too much from a block to another.
trickson
7,595 (1.07/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Noise is not an issue for me at all . the NB gets to about 45c and I was just thinking with lower temps I could OC a little more .
Thank you very much for your help .
Odin Eidolon
920 (0.16/day)
Cooling HDT-1283
if noise isnt an issue, the kit from petra has very good performance, grab it! But, since noise isnt an issue, i bet that with a powerful fan over the nb you will solve the nb temp problem with much lower cost!
intel igent
4,640 (0.67/day)
Toronto, Canada
System Name old school / new school
Processor 3.0e C0 @ 3.6 / e5200
Motherboard p4p800e-dlx / p5q-DLX
Cooling custom water see sig / air
Memory 2x1g oczPC4000EbPl / 2x2g ocz2rpr1066
Video Card(s) 3850AGP / 4890vaporX
Storage 36g raptor+120g wd / wd 1001fals 1tb
Display(s) BenQ / sharpAQUOS LC-37D64U
Case modded antec plusview / generic
Audio Device(s) audigy 2zs / ASUS Xonar HDAV1.3
Power Supply fan/cable modded powerstream 520 / OCZ 700mxsp
Software Xp pro SP2 / VISTA ultimate OEM
that petra's kit is nice and very cost effective, you will be pleased with it's performance.
for chipset block i'd suggest mcw-30 or DD mpc
D4's are not loud if you mount them properly, i have two running in my case.
both pump's have over 3yrs of use on them.
trickson
7,595 (1.07/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Yeah noise is NOT an issue for me , My case is the CmStacker and well as it is now I have 7 fans blazing away in side it now it is loud and all but nothing that VOLUME doesn't take care of :laugh: . I have installed the ASUS fan on the NB chipset but it seems to be a bit hot to the touch so I think that getting a water block will cure that :) .
Thanks again every one tomorrow I will order it all and see if I can get it in 2 days maybe not since xmas is coming up but maybe after I will get it .
I can hardly wait to see the temps go down from 40c idle and 70c loaded to 20c and 40c ( I hope ) .
intel igent
4,640 (0.67/day)
Toronto, Canada
make shure you get the quad insert and washer for that D-tek block so that you can maximize it's performance ;)
trickson
7,595 (1.07/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Great advice I will do this thank you so much . :respect:
trickson
7,595 (1.07/day)
Planet Earth.
Cooling Noctua
Mouse Optical
intel igent
4,640 (0.67/day)
Toronto, Canada
trickson
7,595 (1.07/day)
Planet Earth.
Cooling Noctua
Mouse Optical
intel igent
4,640 (0.67/day)
Toronto, Canada
OK I will wait maybe you can find them for me ... Please ?
sorry don't have the time to locate part's for you but a quick call to alex or quoc at petras will answer your question :toast:
12,453 (1.98/day)
Hey Intel, how much of a temp difference does that Quad insert make?
trickson
7,595 (1.07/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Ok I will see if I can reach them . Not in a hurry for the extra parts just to get some good water cooling going right now is the goal .
trickson
7,595 (1.07/day)
Planet Earth.
Cooling Noctua
Mouse Optical
_jM
1,453 (0.25/day)
Ocala,FL
System Name The money pit v.2 (v.1 is the wife!)
Processor Core2Quad-Q9550@3.9ghz/1860mhzFSB @1.344v
Motherboard ASUS Maximus II Formula = best damn P45 OCer out there!
Cooling CoolerMster V8-- Custom WC system on the way! =]
Memory 8GB DOMINATORS @1100mhz 5-5-5-18
Video Card(s) EVGA GTX 280
Storage 150GB WesternDigital Velociraptor OS Drive/1 WD 500AAKS for Storage
Display(s) SAMSUNG 2243SWX 22" LCD
Case Cooler Master Cosmos S w/custom lighting and cable management
Audio Device(s) X-Fi Titanium (Fatality edition) - paired with RAZER Barracuda's
Power Supply CORSAIR HX1000W modular PSU
Software Windows 7 RC 7100--eats vista for breakfast lunch and dinner!
Benchmark Scores Coming to a theater near you!
try looking here for watercooling supplies. They have a HUGE selection. :D
DOM
7,628 (1.17/day)
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
Good question thank you !
for me not much im using the 6.5mm Nozzle one i use for my dual and Q temps are the same
i ran the Quad Split Nozzle with the dual also and temps are the same with the 6.5mm Nozzle
