Going to go water cooling and need some help .
Discussion in 'Overclocking & Cooling' started by trickson, Dec 22, 2008.
  1. trickson
    trickson OH, I have such a headache
    Dec 5, 2004
    6,494 (1.78/day)
    956
    Planet Earth.
    WOW that place has tons of cool stuff . :rockout:
  2. intel igent
    intel igent New Member
    Jun 5, 2005
    4,641 (1.34/day)
    434
    Toronto, Canada
    IIRC nozzled and bowed fuzion showed 3c-5c better temp's vs non nozzled/bowed block's on a quad core.
    i could be wrong as i haven't seen the info in a while but that's what i recall....
    Paulieg says thanks.
  3. DOM
    DOM
    May 30, 2006
    7,552 (2.43/day)
    828
    TX, USA
    my last post is on #25 ;)
    and that kit olny comes with the Swiftech Apogee™ GTZ or D-TEK FuZion v2
    might wanna ask them is its the D-TEK FuZion v2 Universal CPU Waterblock if you plan on using it on another socket
    trickson says thanks.
  4. trickson
    Dec 5, 2004
    6,494 (1.78/day)
    956
    Planet Earth.
    No just this socket for now .
  5. Breathless New Member
    Oct 6, 2007
    370 (0.14/day)
    35
    Just get this:
    http://www.crazypc.com/store/mercha...uct_Code=freezone-elite-938202&Category_Code=
    You'll have the option of silence or awesome performance or both. Yea its a little bit more money and sucks up some more power (negligible on your electric bill really), but you'll save buckets of time and it will have a nice small footprint. It will produce better temps than the best watercooling loops (albeit at high noise levels).
    "CPCMAXPC" 5% off
    $318
    Many people will say "just do your own", but there is a lot more that can go wrong with this kind of thing if you do it on your own. Plus you have to drain / refill / maintain and ya-de-ya-da. The above cooler is a sealed unit (no maintenance... this is a big plus) and leak tested at the factory (of course). Just install it and forget it.
    http://www.hardwarecanucks.com/foru...-coolit-freezone-elite-cpu-cooler-review.html
    http://www.nordichardware.com/Reviews/?skrivelse=520
    http://techgage.com/article/coolit_freezone_elite_cpu_cooler/1
    http://www.driverheaven.net/reviews.php?reviewid=546
    http://www.bcchardware.com/index.php?option=content&task=view&id=5330&Itemid=40&limit=1&limitstart=0
    http://www.bit-tech.net/modding/2008/05/14/coolit-freezone-elite/1
    It has been very highly reviewed by respected review sites. I have the Boreas MTEC Chassis and it is FANTASTIC with my QX9650.
  6. DOM
    DOM
    May 30, 2006
    7,552 (2.43/day)
    828
    TX, USA
    well its those two just so you know ;)
    idk which one ill pick the both look nice
  7. trickson
    Dec 5, 2004
    6,494 (1.78/day)
    956
    Planet Earth.
    Yeah but I do not have the money for that setup and hell they took all the fun out of it :twitch:
  8. Breathless New Member
    Oct 6, 2007
    370 (0.14/day)
    35
    No problem. To each his own. Have fun!
  9. Steevo
    Steevo
    Nov 4, 2005
    8,432 (2.55/day)
    1,253
    I used newegg to get my swiftec stuff, the only problem I have had is the availibility on it.
    Currently folding on the CPU and GPU, the temps are 31C.
    Total cost for the cooling was less than $250 with all the fittings, fans, coolant, and a box of 50 feet of the tubing from a local supplier.
    10 Million points folded for TPU
  10. trickson
    Dec 5, 2004
    6,494 (1.78/day)
    956
    Planet Earth.
  11. DOM
    DOM
    May 30, 2006
    7,552 (2.43/day)
    828
    TX, USA
    looks good but idk about that Vibration Absorption Block lol i never used one there quite pumps
    Marry Christmas :toast:
  12. trickson
    Dec 5, 2004
    6,494 (1.78/day)
    956
    Planet Earth.
    I just thought that it would help in keeping vibration down not the noise .
    Marry Christmas to all !
  13. spearman914
    spearman914 New Member
    Apr 14, 2008
    3,339 (1.38/day)
    502
    Brooklyn, New York 11223
    The d-tek fuzion is very quiet by itself.
  14. trickson
    Dec 5, 2004
    6,494 (1.78/day)
    956
    Planet Earth.
    I hope it cools as well as it looks . I am so sick of seeing 70C + loaded and 45c idle .
  15. spearman914
    Apr 14, 2008
    3,339 (1.38/day)
    502
    The Dtek Fuzion should get ur temps down to 20-45 c load and 5-20C idle.
  16. trickson
    Dec 5, 2004
    6,494 (1.78/day)
    956
    Planet Earth.
    That would be so very sweet !
  17. Binge
    Binge Overclocking Surrealism
    Sep 15, 2008
    6,982 (3.08/day)
    1,752
    PA, USA
  18. trickson
    Dec 5, 2004
    6,494 (1.78/day)
    956
    Planet Earth.
    This is posativly the best news .
    I tell you going to a liquid cooling setup has not been easy and thanks to all of you here I can say I am more than stoked now , I know that I made the right choice and that soon ( when they open the 29th ) I will be getting this setup and finally cooling off this nuclear reactor CPU down ! I can hardly keep my self still now !
    Thank you all for the help . I bet with the chipset cooling and CPU cooling I will get I can reach that coveted 3.8GHz finally !
    I can reach it now but it is so HOT I can not keep it there , 55-60C idle !
  19. Odin Eidolon
    Odin Eidolon New Member
    Feb 12, 2008
    921 (0.37/day)
    156
    Rockclimbing somewhere in Italy
    dont wanna bash, but thats untrue. idle temps cant go under ambient temps for the most obvious of the principles of thermodinamic. so you will get idle 0-10 C load 15-30C DELTA TEMPERATURE: means cpu teperature minus ambient temperature
  20. trickson
    Dec 5, 2004
    6,494 (1.78/day)
    956
    Planet Earth.
    Well one thing I hope to see is a drastic drop in temps boths Idle and load , This Q6600 is one hot reactor and I need some real cooling . I just hate that this thing gets 70+c loaded I have seen temps as high as 74c ! I never want to see that ever again . I have to keep things cool you know .
    and I am finding it hard to do so on air and that with a tech unit !
  21. erocker
    Jul 19, 2006
    39,901 (13.06/day)
    14,309
    Well.. It's a block, I don't think they are supposed to make noise.:ohwell:
    Idle temps can be no lower than ambient temps. Load temperature is determined by clockspeed, voltage and how well the loop will work.
    The quad core insert is a must! Two chips in the Q6600 and the quad nozzle directs the water directly over each of the chips. With the normal insert, the two cores furthest away from the water contact area will become hot.
  22. trickson
    Dec 5, 2004
    6,494 (1.78/day)
    956
    Planet Earth.
    Well as before I still have no answer on the insert I need for the water block I am getting and the Q6600 I have . I would love to get one and there was also the matter of the washer for that D-tek block I still can not seem to find them at that site .
    So for now I am stuck with just the water block unless you can help me out ..
  23. Paulieg
    Paulieg The Mad Moderator Staff Member
    Feb 19, 2007
    11,924 (4.20/day)
    3,001
    Wherever I can find the iron.
    I did some research on the insert (I have the Fusion), and there is only a 1-2c difference in temps with the insert on a Quad. Not worth the extra cash.
  24. trickson
    Dec 5, 2004
    6,494 (1.78/day)
    956
    Planet Earth.
    Well then that is good to hear thank you very much . :respect:
  25. intel igent
    Jun 5, 2005
    4,641 (1.34/day)
    434
    Toronto, Canada
    here's the link for the nozzle's/washer http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=203&HS=1 if you can't find it on petras site don't be afraid to call alex or quoc and ask, i'm shure they'll have/get it for you ;)
    are you shure? IIRC from what i saw from all of the testing at Xs the nozzled and bowed fuzion would net 3c-5c better temp's on a q6600 vs a stock fuzion. the nozzle/washer kit is no more than $7 so well worth it IMO....
    :toast:
Share This Page
