Gonna By some parts for my PC .
Discussion in 'General Hardware' started by TmdRockz™, Aug 26, 2008.
  1. TmdRockz™
    TmdRockz™ New Member
    Aug 25, 2008
    236 (0.09/day)
    5
    SRI LANKA
    as the topic im gonna buy a mobo,cpu,vga,monitor,RAM
    So please tell me is this parts are better or bad ...is it good or bad any
    any comments guyz ?
    CPU - Intel Core 2 Duo E7200
    Mobo - foxconn MARS
    Monitor - Samsung 21" LCD Monitor
    RAM - 2GB (1Gbx2) Patriot 800 mhz
    VGA - Foxconn 9600 GT
    and BTW whts are the good brands of a DVD WRiter ?
  2. SerenadeRB
    SerenadeRB New Member
    Jun 30, 2008
    183 (0.07/day)
    33
    Whitestone, NY
    Liteon, I've owned a couple and all are very reliable.
    I believe Sony makes good ones too.
  3. TmdRockz™
    Aug 25, 2008
    236 (0.09/day)
    5
    SRI LANKA
    I have a Sony DRU 170c :D
  4. TmdRockz™
    Aug 25, 2008
    236 (0.09/day)
    5
    SRI LANKA
    and it doesnt read some of my DVDs which are damaged a bit :S
  5. acperience7
    Nov 26, 2007
    265 (0.09/day)
    32
    I've had my Dell for nearly 5 years and it still has it's original Samsung drives(DVD-ROM and CD/DVD burner). I've never had a single problem with either of them.
  6. TmdRockz™
    Aug 25, 2008
    236 (0.09/day)
    5
    SRI LANKA
    ok tnx guyz and wht abt the other parts
  7. SerenadeRB
    Jun 30, 2008
    183 (0.07/day)
    33
    Whitestone, NY
    What are you going to use your computer for?
    Gaming, Movies, Web Browsing, etc..
    And we can take it from there =]
  8. TmdRockz™
    Aug 25, 2008
    236 (0.09/day)
    5
    SRI LANKA
    I use it for all of the works Gaming,Web,
    And I need a stable one ...not only for games
  9. TmdRockz™
    Aug 25, 2008
    236 (0.09/day)
    5
    SRI LANKA
    EDIT _ and im willing to OC it
  10. SerenadeRB
    Jun 30, 2008
    183 (0.07/day)
    33
    Whitestone, NY
    There is an edit button for your posts :p
    And idk what your budget is, but I would recommend a little more power on the VGA end.
    If your an Nvidian then 9800, or an ATier with the 4850.
    Other than that you should be alright. What is the timings on your RAM though?
    The P35 chipset is friendly with OC'ing so no problems there.
    Also make sure you have a good power supply
    ~Evangeline
  11. TmdRockz™
    Aug 25, 2008
    236 (0.09/day)
    5
    SRI LANKA
    @serende
    it will cost a lot
    and if u give me money i can :p
  12. Katanai
    Katanai
    Mar 15, 2008
    1,020 (0.35/day)
    144
    Well imo you're good to go. That system should play anything you throw at it on max settings at a decent resolution. Don't know about that game in your avatar though...:roll:
