Good case for Water Cooling?
Discussion in 'Cases, Modding & Electronics' started by Paulieg, Sep 14, 2008.
  1. Paulieg
    Paulieg The Mad Moderator Staff Member
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
    Wherever I can find the iron.
    I'm going to start working on my first water cooling project. I'm looking for a good full or mid tower case that is "water cooling friendly" for mounting the rad and pump. I'm new to water cooling, so I'm looking for this to go as easy as possible, without any or not much modding. What are some good options under $125?
  2. DOM
    DOM
    May 30, 2006
    7,551 (2.13/day)
    828
    TX, USA
    what are you looking to cool ?
  3. Cold Storm
    Cold Storm Battosai
    Oct 7, 2007
    15,014 (4.93/day)
    3,002
    In a library somewhere on this earth
    another thing, are you looking to put the water cooling system fully into your computer case, like mine, or just have it?
    NZXT Blackline is a choice
  4. Paulieg
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
    I'm not sure about orientation. Whatever works best. I would prefer not to crowd the inside too much, and I don't want to have to mod the case too much. Decent case there, but i'm looking for a case that a little more subtle, and I'm not thrilled with side windows, unless the window is small.
  5. Paulieg
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
    Just the cpu.
  6. SystemViper
    SystemViper
    Dec 21, 2007
    2,500 (0.84/day)
    472
    I would try to stay with your case. if you are just starting it's best to keep it minimal and see if you like it.
    then you can plan for a bigger watercooling case if you like it, because if you like it you might start cooling northie and video cards too./././
  7. ShadowFold
    ShadowFold New Member
    Dec 23, 2007
    16,921 (5.70/day)
    1,642
    Omaha, NE
    Paulieg and SystemViper say thanks.
  8. SystemViper
    SystemViper
    Dec 21, 2007
    2,500 (0.84/day)
    472
    I have that case, i like it, it took some mods but i mounted a 360 rad on the front,
    blacked out the inside and highlighted it with dark blue metal flake, it's a sweet case and has massive airflow.
    Paulieg says thanks.
  9. Paulieg
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
    I'm having second thoughts on water cooling. Not sure I want to invest in a new case right now, and I'm not sure I have time to do modding. I'm on the fence.
  10. Cold Storm
    Cold Storm Battosai
    Oct 7, 2007
    15,014 (4.93/day)
    3,002
    I think you might like the
    Antec Gun Metal Case
    since you can take it apart, place the pump wherever and what not. 3/8" tubing will work quite nice.
  11. Paulieg
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
    Thanks for you input guys, but I think I might just stick to air cooling for now. After feeling impulsive, I'm now thinking I don't want to invest in a new case, and I've pulled out of a deal to buy some water cooling stuff (sorry systemviper). I appreciate all of the input guys.
  12. Cold Storm
    Cold Storm Battosai
    Oct 7, 2007
    15,014 (4.93/day)
    3,002
    Just think of it this way man. Even if you aren't going to get a water system, at lease you know what to look for in the future and so forth...
    Right man?
  13. WarEagleAU
    WarEagleAU Bird of Prey
    Jul 9, 2006
    10,811 (3.09/day)
    547
    Gurley, AL
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811146047
    I wasn't too sure until I Checked, but the NZXT Tempest has placed already made for water tubing. It's on the back and you can mount your rad inside or out (on top I believe). Plus it comes under the price point and has an MIR. I think you can get it cheaper on Buy.com though.
  14. HeavyH20
    HeavyH20 New Member
    Aug 26, 2005
    407 (0.11/day)
    37
    SystemViper says thanks.
    10 Year Member at TPU
  15. DOM
    DOM
    May 30, 2006
    7,551 (2.13/day)
    828
    TX, USA
    why dont you use the case you got and use a rad box and cut some holes in the back for the tubes
  16. Paulieg
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
    OK guys, because I don't want to do any modding or buy a new case, any thoughts on Coolit products, like the freezone or eliminator? I've seen mixed reviews.
  17. Cold Storm
    Cold Storm Battosai
    Oct 7, 2007
    15,014 (4.93/day)
    3,002
    Me, personally, I wouldn't say for a person to get a all ready made cooler... But, Coolit is pretty nice look... Eliminator I like myself....
  18. SystemViper
    SystemViper
    Dec 21, 2007
    2,500 (0.84/day)
    472
    WOW, that is a sweet case, i hope it comes down in price, looks like sweet airflow but some cooling potential.
    I also like the hd rack pointing towards the side opening too.
  19. DOM
    DOM
    May 30, 2006
    7,551 (2.13/day)
    828
    TX, USA
    how much are they going to cost you ? cuz dont they cost a bit
    cuz what do you need if you where to go with water ?
    rad, cpu, block, pump, tubing, etc ?
  20. SystemViper
    SystemViper
    Dec 21, 2007
    2,500 (0.84/day)
    472
    yea, i made a nice little package for him to start off.,...
    laing pump
    xspc top
    MCR240
    Swiftech storm
    and other stuff....
    But now he has passed,
  21. Paulieg
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
    The Eliminator I can get for $130, the freezone is $170. The thing I like about it, is there is no modding necessary, and it will fit in my case.
  22. SystemViper
    SystemViper
    Dec 21, 2007
    2,500 (0.84/day)
    472
    let us know if you go for it, how well they do...
    is there anybody out there using them?
    Also what is the best CPU air cooler?
  23. Paulieg
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
    Well, I know Air coolers. I've owned about 25 of them over the last 2 years. My favorite is the Zerotherm NV120. Probably the best by a couple of degrees is the TRUE. Some would say the Sunbeam CC or Xig 1283. However, I was NOT impressed by the Xig.
  24. Cold Storm
    Cold Storm Battosai
    Oct 7, 2007
    15,014 (4.93/day)
    3,002
    Coolit systems are pretty nice. If you never go to add anything else, they are good. Something I wouldn't think of one to get because of the fact you change chips... But, thats me.
    I would go with the freezone. That's a Coolit $400 set up... So, if you can get that baby for $170... Then go with it.
    As for air cooler, I would go with this SV.
    Sunbeam Core-Contact Freezer Heatpipe CPU Cooler
    They say on Frostytech that it's the best right now. But, I still go with the Xigmatek S1283
  25. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.12/day)
    3,777
    Simple solution Paul.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835108084&Tpk=radbox
    If running 1/2" tubing, all you need to do is drill 2 holes in your case for the tubes. Nothing major in the ways of modding at all.
    Do not get a CoolIt setup. Way overpriced for the performance.
