GPU-Z 0.6.4 layout issue and goes into power-save
Discussion in 'GPU-Z' started by slyphnier, Aug 10, 2012.
  1. slyphnier New Member
    Feb 1, 2011
    1 (0.00/day)
    0
    hello everyone
    i download and try new version today
    and i found out the layout seems not right, default clock and bottom info on "graphic card" tab not visible (screenshot on the attachment)
    as GPU-Z not resize-able i dunno how to fix it
    another issue happened is
    i tried previous version (0.6.2)... i run it while 0.6.4 running on background
    suddenly GPU goes into sleep/screen goes to power-save.... and no way to recover beside restart my pc with reset button
    is that normal behaviour ? i mean only 1 GPU-Z can run at once ?
    if that is, isn't it better put detection, if there another GPU-Z running, GPU-Z will instead pop back the running, or kill the running one to avoid conflict?
    thanks in advance
      File size:
      21.2 KB
      114
Share This Page
