[GPU-Z] Fan speed (RPM) jumps
Discussion in 'GPU-Z' started by luigimita, Feb 23, 2010.
  1. luigimita New Member
    Feb 21, 2010
    3 (0.00/day)
    0
    I wanted to report a possible bug in GPU-Z
    With the PowerColor 5850 PCS + reading speed of the fan suffers abnormal and continue changes from 900 to 2000 RPM, despite the percentage speed remain stable.
    I use Catalyst 10.2 and gpu-z 0.3.9
    Best Regards
  2. robal
    robal
    Aug 5, 2008
    485 (0.20/day)
    111
    Hampshire, UK
    It may not be GPU-Z issue.
    Sometimes fans give noisy RPM output signal (especially at low voltage / speed) and that makes the fan controller think that speed is very high.
    I've seen this behaviour on almost any CPU / GPU solution by Arctic Cooling...
    The fan is rotating at 500RPM and every now and then it reports 2000, 5000, or even more.
    Just ignore it.
    Cheers,
Share This Page
