GPU-Z not showing GPU Load % on 9800GT
NanaFreak
10 (0.00/day)
I was testing out the beta of Battle Field Bad Company 2 to see how much GPU load is actually going on as it has been reported that it is barely any...
so I opened up GPU-Z and saw that it was at 0%... which I thought was very odd because the memory had gone up ~200MB. So to test it out some more I tried some other games like Modern Warfare 2 and Counter Strike: Source, both made it be at 0% still.
I am running a Asus 9800GT Ultimate (the one based on a 8800GTS, not 8800GT), Windows 7 x64 (Build 7600), E7300 CPU...
If you need any more information, please just ask!
Question: Should I submit a Validation so that you guys can have all the information you need?
Thanks,
NanaFreak
2,632 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01 w/Alphacool Apex RAM X4 Water Cooler and Core DDR5-RAM Module
Video Card(s) MSI Suprim SOC w/Alphacool Core Geforce RTX 5080 Suprim + Vanguard with Backplate
Storage Samsung 990 PRO 1TB M.2
Display(s) MSI 321URX
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
Try using the 196.34 BETA Forceware?
NanaFreak
10 (0.00/day)
actually I am using the BETA drivers... Should I try rolling back to the stable drivers to test this out?
NanaFreak
10 (0.00/day)
ok, I tried rolling back the drivers... and no help... still 0% GPU load...
355 (0.06/day)
Canberra Australia
Processor i5 750 4.2ghz 1.4V
Motherboard Gigabyte P55-UD4P
Cooling Corsair H70
Memory 2X2G Gskill @2140 8-11-8-28-1T
Video Card(s) 2xGainward Phantom3 570@860/4200
Storage 2xWD 500G AAKS Raid0 + 2XWD 1T Green in Raid0
Display(s) 24" HP w2408h+23" HP w2338h
Case SilverStone Raven2E-B
Audio Device(s) onboard for now
Power Supply Antec 1000W Truepower quattro
Software Win7 Ultimate 64bit
try evga precision tool
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
have you ticked the 'continue refreshing' box so that you're actually getting readings?
^ that one at the bottom
NanaFreak
10 (0.00/day)
@gaximodo - thanks, i will check out evga precision tool now...
@Mussels - yes that option is on, all the other information is being filled (actually its GPU Load, Memory Controller Load, Video Engine Load... so all 'Loads' are not working)
Mussels
58,412 (7.78/day)
Oystralia
alright, it was worth checking.
It may well just be incompatible with the driver you're using - i did hear about a recent WHQL driver breaking all these OC'ing/information tools.
NanaFreak
10 (0.00/day)
ok, I just tried the evga precision tool, with no success... during the Counter Strike: Source stress test, no GPU usage was recorded
Mussels
58,412 (7.78/day)
Oystralia
try another video card driver. either older WHQL, or newer beta.
NanaFreak
10 (0.00/day)
ok im going to try out the 195.62 WHQL drivers... and if that doesnt work, 191.07 WHQL...
NanaFreak
10 (0.00/day)
(Sorry for double posting...)
Just tried the 195.62 WHQL drivers, with no success with GPU-Z, somehow i dont think that 191.07 will work...
i might try the latest Asus drivers that i can find for the card though...
Mussels
58,412 (7.78/day)
Oystralia
hmm. Perhaps your card lacks whatever sensor its being read from?
NanaFreak
10 (0.00/day)
That could be it... might as well give up trying... too much downloading for my Australian internet (only 20GB onpeak downloads!!) ]=
Mussels
58,412 (7.78/day)
Oystralia
meh, i get 20GB on peak as well. but its almost midnight, well into offpeak for me.
355 (0.06/day)
Canberra Australia
Cooling Corsair H70
Lucky you:respect: offpeak starts 4 am and ends 9am for me here...
NanaFreak
10 (0.00/day)
haha mine goes from 2am - 8am (daylight savings time.. so 1am-7am right now...) and atleast i get unlimited offpeak! =D
Molotox
4 (0.00/day)
Hey, I was wondering if you ever got that problem solved? I've just plugged in my older 9800GTX+ and I have the same issue. Shows 0% GPU Load at all time, under 3d mark and even running GPU Grid.
It doesn't feel to be heating much either?
Edit: 0% usage using both GPU-Z and EVGA Precision too!
Molotox
4 (0.00/day)
Sorry for both the double post and the thread necroing. When I googled the problem, this thread came in on top. Anyone having this problem would find this page easily.
I could solve the problem by using the older EVGA Precision 1.8.1 tool and overclock the core speed from 740mhz (stock for 9800gtx+) to 760mhz. As soon as I'd do this, all versions of GPU-Z tested (3.8 and 3.9) would pickup the GPU Load %.
Cheers :toast:
W1zzard
Administrator
28,601 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
yes i hear that just changing the clock speed magically enables the gpu load sensors. can anyone confirm ?
Molotox
4 (0.00/day)
I know i went :confused::confused::confused: when I noticed the behaviour. Maybe its only my system, but heh?
BEFORE, stock settings. Excuse the french on BOINC client. :)
AFTER, just changed 740 core to 760 core in EVGA Precision.
I must precise I'm not using all latest version stuff, but thats a result of looking for a solution. I was all up to date and still having the problem. Nvidia drivers are 191.*, EVGA Precision is 1.8.1
NanaFreak
10 (0.00/day)
Wow... just changing the clock speed by 1MHz made the sensors work... in fact, after just changing the clock speed and then reverting it back it will make the sensors start working...
thanks for the info, and i hope others will benefit from this!
Molotox
4 (0.00/day)
:rockout:
