GPU-Z v0.2.8 fan speed sensor
Discussion in 'GPU-Z' started by INTEL, Sep 25, 2008.
  1. INTEL New Member
    May 25, 2008
    8 (0.00/day)
    0
    * Win. XP Pro SP3 (32 bit)
    * Admin: yes.
    * Patched: yes.
    * Maximus II Formula.
    * Core 2 Duo E6850.
    * Corsair XMS2 CM2X1024-6400.
    Fan speed sensor reports double speed.
    [​IMG][​IMG]
    v0.2.7 all OK.
    [​IMG][​IMG]
    And there is also problem when using v0.2.8 inbuilt snapshot , when Sensors window is active.
    [​IMG]
  2. INTEL New Member
    May 25, 2008
    8 (0.00/day)
    0
    GPU-Z v0.2.9 , unfortunately I still have that same small problem. (wrong fan speed)
    [​IMG][​IMG]
  3. thraxed Guest
    maybe the fan speed was being reported wrong in 2.7.... and now its fixed.. 800 does seem kinda low for fan speed
  4. W1zzard
    W1zzard Administrator Staff Member
    May 14, 2004
    15,335 (3.82/day)
    12,518
    afair the fan speed was reported wrong and it is fixed now for the majority of cards.
  5. INTEL New Member
    May 25, 2008
    8 (0.00/day)
    0
  6. INTEL New Member
    May 25, 2008
    8 (0.00/day)
    0
    Sorry, I think I was wrong. Is fan speed 50 % ~ 1600 RPM, normal RPM for that kind of cards or not ?
    Everest and gpu-z had always reporting me exactly same readings about gpu fan speeds, that is why I was thinking that gpu-z is wrong.
    Now I think everest is wrong, because RivaTuner v2.20(I never checked fan speed before, only was using for OC) reports same readings as gpu-z.
  7. W1zzard
    May 14, 2004
    15,335 (3.82/day)
    12,518
    everest, rivatuner and gpu-z authors are good friends and share lots of code, so usually you should see the same results (and bugs) there
  8. INTEL New Member
    May 25, 2008
    8 (0.00/day)
    0
    I guess things are clear now and it was EVEREST Ultimate v.4.60.1500 bug.
    EVEREST Ultimate v4.60.1547 Beta
    [​IMG]
    GPU-Z.0.3.0
    [​IMG]
    RivaTuner v2.20
    [​IMG]
    :toast:
Share This Page
