GTX 580 Lightning cooling with 120mm fans???
treboRR
62 (0.01/day)
System Name My Rig
Processor I7 2600K @ 4.2GHz
Motherboard Gigabyte GA-Z68X-UD7 B3
Cooling Noctua NH-D14
Memory 8GB G-Skill Ripjaws X @ 1610MHz 9-9-9-24 1T
Video Card(s) 2xMSI GTX 580 Lightning @ SLI
Storage 2x HDD for data and 1xSSD OCZ Agility 3 128GB
Display(s) Benq XL2410T @ 120Hz
Case Corsair Obsidian 650D
Audio Device(s) SB Titanium OEM
Power Supply Corsair HX1050
Software Windows 7 64x
Has anyone done that??? I mean but the 2x120mm fans on that beast? (ripping off the msi metal cover and removing the 2 fans and replace them with some kind of 120mm fans???)
:toast:
I imagine it will definitely lower the temps and most importantly lower the noise:nutkick:
3,145 (0.69/day)
Processor 8700k Intel
Motherboard z370 MSI Godlike Gaming
Cooling Triple Aquacomputer AMS Copper 840 with D5
Memory TridentZ RGB G.Skill C16 3600MHz
Video Card(s) GTX 1080 Ti
Storage Crucial MX SSDs
Display(s) Dell U3011 2560x1600 + Dell 2408WFP 1200x1920 (Portrait)
Case Core P5 Thermaltake
Audio Device(s) Essence STX
Power Supply AX 1500i
Mouse Logitech
Keyboard Corsair
Software Win10
Isn't the shroud engineered to increase the air pressure on the pcb? I think you'd do worse
1,743 (0.38/day)
Asheville, North Carolina
System Name Red Giant
Processor Intel Core i7-12700K
Motherboard MSI Pro Z690
Cooling Corsair H100i elite
Memory Corsair Vengeance Pro 32GB
Video Card(s) MSI 4070TI Super
Storage 960 GB Sandisk SSD
Display(s) 27 inch Predator 144 hz 2k
Case CoolerMaster HAF X
Power Supply Corsair AX1200
Keyboard Corsair K95 Platinum
+1 it is engineered to be used with the setup being shipped it is not meant to be interchangeable in the same way as case fans or cpu coolers.
2,665 (0.45/day)
Switzerland
Processor i9 9900KS ( 5 Ghz all the time )
Motherboard Asus Maximus XI Hero Z390
Cooling EK Velocity + EK D5 pump + Alphacool full copper silver 360mm radiator
Memory 16GB Corsair Dominator GT ROG Edition 3333 Mhz
Video Card(s) ASUS TUF RTX 3080 Ti 12GB OC
Storage M.2 Samsung NVMe 970 Evo Plus 250 GB + 1TB 970 Evo Plus
Display(s) Asus PG279 IPS 1440p 165Hz G-sync
Case Cooler Master H500
Power Supply Asus ROG Thor 850W
Mouse Razer Deathadder Chroma
Keyboard Rapoo
Software Win 10 64 Bit
sounds like ghetto mod
9,899 (1.78/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
People have been saying they have magical cooler shrouds for ages.
Most of they're time they're Bullshitting.
You know what increases pressure more? A higher pressure fan. :laugh:
FreedomEclipse
~Technological Technocrat~
23,307 (3.77/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
I did a simlar thing to a 5850 once.
the Heatsink kinda looked like this:
Started off cable tying a 120mm(1300rpm) and one 80mm(3000rpm) fan on to each overhanging section of the cooler.
temps were never that great. The reason why I ripped the shroud off was because the stock fan in the picture started developing this REALLY LOUD grinding noise.
I put in an order for a Arctic Cooling Twin Turbo Pro - Waited a week, never arrived then checked on the shops website and found out that they had labled the cooler as 'Ordered upon request' which means I wouldnt see the cooler for another 2-3 weeks.
Since i originally put in an order when they said they had at least 15 units instock. I cancelled my order and proceeded to give them a right royal bollocking via email to which they never replied and i eventually ran out of breath when they refunded me.
Since the grinding noise had gotten a lot worse and was totally unbearable I ripped the shroud and the fan off and ghetto modded it.
results wasnt that awesome as the original fan in the middle was supposed to channel air between the fins but meh, the card never overheated on me which is the most important thing when ghetto modding a cooler.
my Twin Turbo Pro eventually arrived a few days later and this nightmare was finally put to rest.
/sipsmorecoffee
newtekie1
Semi-Retired Folder
28,472 (4.25/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
The fans on the GTX 580 Lightning already cover the heatsink fins from side to side, and pretty much have them entirely covered from front to back, so adding a larger fan would just have the fan sticking over the edge of the fin array and wouldn't really help any with heat dissipation.
As for the noise, you can always manually adjust the fan profile to bring the noise down a little, the card certainly has the room in temperatures to handle slowing the fans down some.
9,899 (1.78/day)
Essex, England
System Name My pc
200 cfm delta fans might do though :laugh: ( I know, not precisely quiet but you can get higher cfm fans then the ones they use on it that are quieter)
treboRR
62 (0.01/day)
System Name My Rig
i know what u all think about! My point is...beacause the card is cool enuff but i would like it to be more quiter than it is, beacause these fans to push air quite nice but in mean time they are loud as hell (i mean only then if i want to keep things nice and cool), but in auto it is silent, but then the temps are getting higher.
I see noone has done it here or anywhere. I will do that ghetto mod and let you guys know did it help or did it get worse. BUT THANKS ANYWAY!!
HammerON
The Watchful Moderator
8,397 (1.53/day)
Up North
System Name Threadripper
Processor 3960X
Motherboard ASUS ROG Strix TRX40-XE
Cooling XSPC Raystorm Neo (sTR4) Water Block
Memory G. Skill Trident Z Neo 64 GB 3600
Video Card(s) PNY RTX 4090
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard Corsair K70
Water cool the card:)
theonedub
habe fidem
8,025 (1.47/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Power Supply Corsair HX1000
Software Windows 10 Pro x64 || WIndows 11 Pro x64
The Lightning fans can get pretty loud, I thought they were loud @ anything over 54%. I decided to run it at the max speed that I could get away with without hearing them over my case which turned out to be 50%. Funny enough the temps didn't change much at all.
Long short, fans are loud, but the heatsink does such a good job that the fans never need to get that fast.
treboRR
62 (0.01/day)
System Name My Rig
there isn't any waterblock for lightning!!!!
i do not agree with you, my card does change trastically temps when a little change of fan speed is on order:D mby that comes from better airflow in the case??
But yeah....imho i will try do set those 120mm on it and see whats what! in series of 8800 cards, removing the plastic cover and one 120mm fan on it was a BIG temp killer - 20-30C less heat! But i would like to see if i get better result on 580 Lightning - ok ok...mby not, but i sure will get much quiter card that way and i will be satisfied if the temps remain same as with orig. fans.:rockout:
theonedub
habe fidem
8,025 (1.47/day)
Northern CA, USA
Nope, same case before and after the fan speed change- temps barely changed. The 650D is not known for great airflow, either.
Are you saying doing the same thing results in a bigger change in temps for you? Do you have a Lightning card or are you talking about the 8800 listed in your specs? If thats the case we are talking apples and oranges.
3,296 (0.56/day)
System Name Thakk
Processor i7 6700k @ 4.5Ghz
Motherboard Gigabyte G1 Z170N ITX
Cooling H55 AIO
Memory 32GB DDR4 3100 c16
Video Card(s) Zotac RTX3080 Trinity
Storage Corsair Force GT 120GB SSD / Intel 250GB SSD / Samsung Pro 512 SSD / 3TB Seagate SV32
Display(s) Acer Predator X34 100hz IPS Gsync / HTC Vive
Case QBX
Audio Device(s) Realtek ALC1150 > Creative Gigaworks T40 > AKG Q701
Power Supply Corsair SF600
Mouse Logitech G900
Keyboard Ducky Shine TKL MX Blue + Vortex PBT Doubleshots
Software Windows 10 64bit
Benchmark Scores http://www.3dmark.com/fs/12108888
Im running on stock 580 cooler overclocked to 850 core, with ambient case temps of 36c degree and gpu temp reaching 80c + degree on gaming. Been running since a year now, and so far didnt get any temp related problems. In other words, be happy with what you have right now :D
9,899 (1.78/day)
Essex, England
System Name My pc
Lower temperatures mean better over-clocking, or if you've already reached clock limit you might be able to run a lower voltage through the chip as the chip will have less voltage leakage : ]
Lower the temps the better, it's why all my heat-sinks have always been huge :laugh:
For example on my old 6870 ( this one is a dud for over-clocking) with the stock cooler it took 1.3 volt for 1000 core with after market cooling it done it with it's stock vid of 1.18 : ]
Never be happy with what you have XD always room for improvement.
By the way OP, post pictures when your done, I do love a good ghetto mod, so far there's not been a rig I've owned that doesn't have at-least one XD
treboRR
62 (0.01/day)
System Name My Rig
ohh sorry, my specs are different...i will update them:D they are old!
EDIT: and i have added alot of better fans to the 650D (even the 200mm Antec Bigboy sucking the air in to the case)
2,452 (0.41/day)
System Name PC
Processor i7 9700KF
Motherboard MSI Z390 A PRO
Cooling Noctua NH-U14S
Memory 32GB Corsair Vengeance DDR4 3000mhz
Video Card(s) PALIT RTX 4070 Dual 12Gb
Storage 2X Crucial MX500 2TB SSD, Samsung 850 pro 512gb SSD
Display(s) DELL C34H89x 34" Ultrawide
Case Corsair Obsidian 550D
Audio Device(s) Audioengine A5+ Speakers
Power Supply Corsair RM750
Mouse Logitech G403
How long have you had the card? If you can return it you should get the asus GTX580 Matrix Platinum, its really quiet even overclocked at 980mhz core, I can hear mine, only thing i hear in my setup is the corsair H100.
treboRR
62 (0.01/day)
System Name My Rig
hmm....about 2 months now, but NO WAY i'm returnig that card! I like MSI card better. And i got it about 120 € cheaper than market price.:toast:
