GTX260 Amp2! zotac Strange noise, help
Discussion in 'Overclocking & Cooling' started by slyfox2151, Jan 17, 2009.
  1. slyfox2151
    slyfox2151
    Jan 14, 2009
    2,611 (1.19/day)
    525
    Brisbane, Australia
    GTX260 Amp2! zotac Strange noise, help (resolved)
    hello
    i can hear a buzz? or more of a screaching sound coming from inside my box,
    just 2 days ago i upgraded mobo/cpu/ram from a K8 athlon 3000+ to a E7300
    i first noticed the noise when i run the vista system test witch scores your system performance, the noise only happens during the areo test, i ignored it as that was the only time its ever made it, 3dmark 03 06 vantage all run flawlessly.
    however just now i was going to overclock my gpu higher using riva tuner and (ati tool for the stability test) upon opening the 3d window it makes the noise....
    any one know what this could be? its not very loud... but noticeable over my system fans all on low rpm (antec 1200)
    i cant be certain its coming from the gpu as i dont really want to keep doing it wile i listen for the noise location.
  2. slyfox2151
    slyfox2151
    Jan 14, 2009
    2,611 (1.19/day)
    525
    Brisbane, Australia
    i have resolved the problem myself with the help of google, i should have use'd that before coming here :p
    apparently its quite common to hear this sound
    http://www.hardforum.com/showthread.php?t=1382093
    its news to me so i thort id share my findings with you guys.
Share This Page
