!!HELP!! 32" HD-TV not running at 1366*768
Greek
572 (0.09/day)
Leicester, UK
Processor AMD 64bit - Dual-Core 4200+X2 at 2.64GHz 24/7
Motherboard ASUS A8n-SLi Deluxe
Cooling Zalman AB3CL CPU Cooler with 12Cm Fan, Plus 10 Fans at 12CM lol
Memory 2GB DDR 400MHz 3-3-3-8
Video Card(s) BFG 7900GTX OC - " My Big F'N Gun "
Storage 1 x 250GB WD Caviar RE SATA-300, 1 x 250GB Maxtor IDE, 1 x 160GB Samsung Spinpoint
Display(s) 17 " Hansol TFT LCD
Case Thermaltake Kandalf VA9000SWA - Aluminium Full Tower Case
Audio Device(s) On-board 7.1
Power Supply 650WAtt Atrix
Software Vista Business
Hey guys,
well i went a bought ma self a HD Ready 32" Philips TV, main purpose was to use it as a monitor, and still is, below is the tv.
http://www.comet.co.uk/cometbrowse/product.do?sku=386790
my problem is this, i have not choice to setting the monitor on its proper resolution which is 1366*768, atm is on 1024*768 but its a bit streched and a little bit annoying, i tried creating the res ma self through nvidia control panel, no luck it failed, i tried another program called Powerstrip http://www.entechtaiwan.com/util/ps.shtm
but i created it and updated the driver file, and still no luck, i duno even if i used that program properly.
a bit doomed atm trying to figure out how to get this going, i am currently using DVI to HDMI cable, from my 7900GTX to the TV.
any1 has any solutions i would more than appreciate a post.
thank you.
1,807 (0.26/day)
Hamburg
Processor Intel I7 2600k@ 4.5
Motherboard Gigabyte p67 ud4 b3
Cooling AC Cuplex kryos Hf
Memory 8096 Exceleram 1600@ 1333 Cl9 1.35v
Video Card(s) Palit Gtx570@950/1900@1.063v
Storage Ocz Vertex 3 120gb, 2tb Seagate 7200rpm s-ata3
Display(s) Asus 24inch Lcd
Case Coolermaster Cosmos S
Audio Device(s) Creative X-fi with Teufel Magnum Power Edition
Power Supply Coolermaster 700W Silent Pro Gold
Software Linux?^^ ;P Windows 7 64bit
Are you sure your Pc detects the tv as a tv? and not as a monitor?
So normally you get then the Tv resolutions in the control panel.
Greek
572 (0.09/day)
Leicester, UK
yher it detects it as a tv
43,587 (6.72/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Does your video card support 1366x768? I have had problems with nvidia cards and HDTV's too, they just don't support alot of different resolutions... My 1950pro will spit out any resolution you want. I really don't know why this is. For example, on BF2142 no matter what the output, I get more resolution options with ATi than with my "better" 8800 where I am stuck using 1024x768 (in BF2142 options).
2,724 (0.43/day)
Blighty
Processor R7 5800x3D
Motherboard MSI x570 Tomahawk
Cooling XSPC Raystorm Edge,EK QS P420M,EK D5pwm Revo Res
Memory 32gb Corsair Vengeance RT 3600 cl16
Video Card(s) Zotac 3070ti Amp Extreme
Storage Samsung 980pro 1tb x2
Display(s) MSI MPG321QRF QD
Case Corsair 7000D
Power Supply EVGA 1000 P2
Mouse G900
Keyboard Corsair k60 RGB PRO
Software Win 11
have you tried all the different ways of changing res?, for example on my pc, not all resolutions are listed in the taskbar icons menu, but the ones that arent there are in the right click>properties>settings menu, as for the nvidia control panel, that has even more resolutions missing than the taskbar menu
Greek
572 (0.09/day)
Leicester, UK
supose nvidia are a bit gay when it comes to this then, ill just have to stick with this though, but im not even on widescreen when i change the mode on ma tv to go to hdmi it says hdmi xga, isnt that meant to be wxga? ah welll what can you do.
2,648 (0.42/day)
UK
System Name Ma Biatch
Processor i7 860
Motherboard Gigabyte GA-P55-UD3A
Cooling Noctua
Memory 8gb (4x2gb) G-Skill
Video Card(s) GTX 470
Storage WD5000aaks raid0
Display(s) Sony Bravia 37" 1080p
Case CM 690
Power Supply Corsair HX520
Software Windows 7 Ultimate
cant you right click go to properties>settings and change it from there ? and isnt it 1360x768 not 1366?
Greek
572 (0.09/day)
Leicester, UK
that res does not show on my settings tab
on the website where i brought the tv it said 1366*768 so i think thats rite
Mediocre
1,237 (0.19/day)
Processor C2D E8400 @ 3.60GHz
Motherboard ASUS P5Q-Pro w/ extra Vreg HS
Cooling Apogee GTX, 2x120mm DD, MCP-1000P Res/Pump, all 3/8" 7x80mm (4x push/pull, 2x exhaust, 1x side)
Memory 2 x 1GB Corsair Dominator DDR2 1066 @ 800 (4-3-3-6)
Video Card(s) EVGA 9800GTX+
Storage 3 x 80 GB WD SATA300 (2x RAID 0)
Display(s) Scepter x37 1080p 37" LCD & Samsung 204B
Case CoolerMaster HAF932
Power Supply Mushkin HP-580AP (C/O TPU!)
Software Vista Ultimate (32-bit)
You know its funny, after reading this thread I went in and checked my resolutions....
My old 720p TV/Monitor ran at like 1280 x 720. Not exactly 720p, but it worked and looked decent in widescreen.
/M27m running a 1080p TV/Monitor now, at 1920x1080, and can still set it back at 1280 x 720 (7800gt)
I have the same t%sues with 2142, can't set it to 1280 x 1024 wtf. I only get 8x6, 16x12, and 1024 x 768...wtf?
