Help: 4850 BIOS flash gone wrong... atiflash gives "Adapter not found"
Discussion in 'AMD / ATI' started by remmeh, Jul 1, 2008.
  1. remmeh New Member
    Jul 1, 2008
    19 (0.01/day)
    1
    I flashed my HD4850 BIOS after extracting it with GPU-Z and editing the idle clock/memory speeds with RBE. I then used Winflash (big mistake, I know now) to flash the 4850 bios.
    Reboot, and card won't post. I put atiflash and the original BIOS onto a bootable USB drive, and put in an old PCI video card to flash the BIOS back.
    When I do 'atiflash -i', it spits back, Adapter not found. I also tried 'flashrom -i', which gives me, ATI video adapter not found.
    Any ideas?... :banghead:
  2. dark2099
    dark2099
    Feb 20, 2008
    4,432 (1.52/day)
    758
    where everyone wants to be
    I would say boot into windows with the PCI card and see if winflash will find the card, if not, try returning it where you bought it.
  3. Astennu
    Astennu New Member
    Apr 7, 2005
    41 (0.01/day)
    2
    Killing a card by flashing will not fall under warranty.
    But indeed you cna try booting with a PCI card to dos or windows and use Flasrom/Winflash.
    10 Year Member at TPU
  4. WhiteLotus
    WhiteLotus
    Jul 30, 2007
    6,570 (2.11/day)
    865
  5. W1zzard
    W1zzard Administrator Staff Member
    May 14, 2004
    15,863 (3.70/day)
    13,795
    no that article is only for the 4870 with GDDR5 which has been flashed with a <128k BIOS.
    try in another pc if atiflash finds the card. telling us more about your motherboard for example would help.
  6. WhiteLotus
    WhiteLotus
    Jul 30, 2007
    6,570 (2.11/day)
    865
    yea sorry i did a bit of a typo. :slap:
  7. remmeh New Member
    Jul 1, 2008
    19 (0.01/day)
    1
    My board is a p5b-deluxe.
    I've tried booting into Windows with a Geforce 2 PCI card and then running Winflash, but it doesn't run... it just exits immediately.
    I'm at a loss... would I need to boot from a second ATI video card in order to use Winflash without it dying right away? Because that's what it's doing with nvidia cards.
  8. W1zzard
    May 14, 2004
    15,863 (3.70/day)
    13,795
    that is a possibility that winflash doesnt like nvidia cards in the system.
    winflash accepts the same command line parameters as atiflash under dos. so open a command window, go to the winflash directory and do something like atiwinflash -i
    maybe it works..
  9. remmeh New Member
    Jul 1, 2008
    19 (0.01/day)
    1
    I'll try it. thanks.
  10. remmeh New Member
    Jul 1, 2008
    19 (0.01/day)
    1
    Doesn't work. Just gonna try and RMA it.
  11. Nyte New Member
    Jan 11, 2005
    185 (0.05/day)
    34
    Toronto ON
    You have an old version of ATIFLASH. If you still need help, send me a PM and I'll provide you the info.
  12. OutCast2 New Member
    Feb 8, 2006
    23 (0.01/day)
    0
    atiflash -p -f 0 bios
  13. BennyHJ New Member
    Jul 14, 2008
    9 (0.00/day)
    0
    Hey i Flashed my 4850bios too and it wouldent start up.. then i startet win in safemode and removed all the driver stuf and the card from Device Manager.. and win startet up with standart vga and i could flash the bios again with ATIWinflash and it worked
