Help building a comp, selecting parts
Discussion in 'General Hardware' started by Vario, Jan 20, 2008.
  1. Vario
    Vario
    Oct 21, 2005
    3,049 (0.92/day)
    993
    My friend asked me to select parts for him so he can build a comp, and I was wondering if all of this stuff matches up okay, I wouldnt want him buying the wrong components for the wrong parts. I havent paid much attention to computers in awhile but I think these parts will work together okay...
    MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131030&Tpk=N82E16813131030
    2xGPU's: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130318&Tpk=N82E16814130318
    CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819117127&Tpk=N82E16819117127
    RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820227199&Tpk=N82E16820227199
    HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148231&Tpk=N82E16822148231
    Do those components seem okay? I wouldn't want to pick anything that is not compatible.
  2. ShadowFold
    ShadowFold New Member
    Dec 23, 2007
    16,921 (6.70/day)
    1,644
    Omaha, NE
    that mobo doesnt have two PCi-e slots.... and even if I wouldnt get two 8800gt's if you want to go dual card get two HD 3870's or wait for the HD 3870X2
  3. kwchang007
    kwchang007 New Member
    Jan 27, 2007
    3,979 (1.39/day)
    185
    Severn, MD, USA.
    You need a 780i board to run those cards together.
  4. Paulieg
    Paulieg The Mad Moderator Staff Member
    Feb 19, 2007
    11,914 (4.20/day)
    2,979
    Wherever I can find the iron.
    Why? The 3870's performance is currently inferior, and they are the same price.
  5. asb2106
    asb2106 New Member
    Jan 8, 2008
    1,940 (0.77/day)
    149
    kTOwN WI!!
  6. asb2106
    asb2106 New Member
    Jan 8, 2008
    1,940 (0.77/day)
    149
    kTOwN WI!!
    and 2 3870s scale higher than 8800 anythings, the 3870s are very powerful and a great card!
  7. ShadowFold
    Dec 23, 2007
    16,921 (6.70/day)
    1,644
    Omaha, NE
    Two HD 3870's beat two 8800GT's cause crossfire scales a hella lot beter
  8. FatForester New Member
    Mar 14, 2007
    971 (0.35/day)
    151
    Take away one of the video cards and use that money for a better hard drive and mobo. At least get a P35 and a bigger hard drive. The hard drives in the 60-110 dollar range are the best bang for your buck.
    Here's a good one:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
    He'll use and need the space A LOT more than a second video card.
  9. kwchang007
    Jan 27, 2007
    3,979 (1.39/day)
    185
    Severn, MD, USA.
    Woops haha, I meant 680i XD. But yeah either of those three would work.
  10. asb2106
    asb2106 New Member
    Jan 8, 2008
    1,940 (0.77/day)
    149
    kTOwN WI!!
    :laugh: ahh thats good, for the Nvidia side of things I really liked the 680. But it still wasnt good enough to bring me to that side, I just have to stick intel(I just love to OC the hell out of my proc)
  11. asb2106
    asb2106 New Member
    Jan 8, 2008
    1,940 (0.77/day)
    149
    kTOwN WI!!
    a p35 wont work with SLI
  12. asb2106
    asb2106 New Member
    Jan 8, 2008
    1,940 (0.77/day)
    149
    kTOwN WI!!
    hey and that hard drive is perfect, I have 3 of them in a RAID and I love them, quiet, fast and very good!!!!!! definitly recommend it
  13. jds21
    jds21 New Member
    Jan 12, 2008
    178 (0.07/day)
    2
    Melbourne, Australia
    The fact that you wish to get 2 8800GT's would say to me that your friend is a gamer am I right?
    First thing would be to upgrade to bigger HDD and switch to a WD one as they perform better and are cheaper (and quieter apparantly)
    Second, If you want a dual GPU setup... definately go for crossfire.. it does scale much better than Nvidia SLI, Nvidia are better for single card setups not SLI... or wait for the ATI HD3870X2... it is 2 GPUs in one and is set to be out sometime in the first term of this year
    If you want a dual card setup, go get an Intel X38 board for crossfire or a 780i for Nvidia, if you want max performance to completely utalise the cards to their full ability. Just beware of the 680i... there have been a lot of problems and they do run very hot but you should be OK if you want to save a few bucks. if you decide to go for a single card setup.... go for the Intel P35 chipset
    I'm no expert on the topic as well but I always thought that Xeon processors were designed for servers.... just what I have heard
    I suppose it all depends on budget but the main things are upgrading the HDD (or get a 2 of them) and reconsidering your GPU setup and Mobo
  14. asb2106
    asb2106 New Member
    Jan 8, 2008
    1,940 (0.77/day)
    149
    kTOwN WI!!
    I agree here completely. I think its a great idea to go with a 3870 or even the 3870x2 when its released. And by going with a intel chipset(x38,p35) you will have great stability and oxcellent options for overclocking. Now if you go crossfire be sure to go x38 because you need the full 16x on the 2nd PCIe slot. If you go p35 then go single card, or a 3870x2. The xeons are nice, they have a higher temp threshold and they overclock alittle better. I have a q6600 G0 and Im up to 3.8 with no complaints. I think its just the Kentsfield's that rule! and again, go with the WD 500AAKS its a great HD
  15. FatForester New Member
    Mar 14, 2007
    971 (0.35/day)
    151
    Yea, that was assuming he would drop the other video card for a better mobo and hard drive.
    WD has never failed me and I've had my eyes on that drive for quite a while now... :laugh: Glad to know they're reliable!
  16. asb2106
    asb2106 New Member
    Jan 8, 2008
    1,940 (0.77/day)
    149
    kTOwN WI!!
    had all three running strong for just over 9 months 24/7 and Im sure there gonna make it a long time into the future
  17. Vario
    Vario
    Oct 21, 2005
    3,049 (0.92/day)
    993
    can't believe i didnt notice that that mobo doesnt support sli, thanks will switch to that evga one.
    My friend doesn't care about hd space 80 gigs should be fine. Hes pretty set on the 8800's.
  18. jds21
    jds21 New Member
    Jan 12, 2008
    178 (0.07/day)
    2
    I know what you mean... i was going to get 2 of them myself but I'm in Australia sn things are more expensive here so the money just didn't justify the performance.
    I am also not a huge fan of the Nvidia chipsets, I prefer the Intel ones and since Nvidia has exclusive rights to SLI, I decided to go with the Intel P35 chipset.
    I was just throwing in some opinions but just know that 80Gb is not much and after formatting and windows, you will have around 60GB left... just something to think about
    Glad I could be of help
  19. jds21
    jds21 New Member
    Jan 12, 2008
    178 (0.07/day)
    2
    Also, I think you should go witht he Q6600 processor rather than the Xeon. I've been doing some looking around and I don't think that CPU is actually compatable. It says it gives better performance in "servers" not desktops and from what I have been reading, it actually gives less performance in desktops.
    I'm not 100% sureon this but I think you should consider changing because the Xeons are not designed for desktop computers... the Q6600 is a damn good processor and it's just a bit cheaper than the Xeon
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
  20. asb2106
    asb2106 New Member
    Jan 8, 2008
    1,940 (0.77/day)
    149
    kTOwN WI!!
    Well I wish more TPU users would chime in on this, I thought the same thing, and that instance on newegg was really a fluke, almost every TPU user that Ive talked to about this subject says that the xeons are totally compatible. I guess one way to go about is talk to some users that have it. Ill look around and see what I can dig up
  21. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,414 (6.91/day)
    4,483
    Youngstown, OH
  22. asb2106
    asb2106 New Member
    Jan 8, 2008
    1,940 (0.77/day)
    149
    kTOwN WI!!
    theres no way that PS will handle dual 8800gt's, no way
  23. asb2106
    asb2106 New Member
    Jan 8, 2008
    1,940 (0.77/day)
    149
    kTOwN WI!!
  24. JrRacinFan
    Mar 17, 2007
    19,414 (6.91/day)
    4,483
    Youngstown, OH
    Crap, I thought it was single card. I better go to bed! LOL
    EDIT 850W!? 700w would be fine.
  25. asb2106
    asb2106 New Member
    Jan 8, 2008
    1,940 (0.77/day)
    149
    kTOwN WI!!
    And the quad is definitly the way to go, more and more apps are being written to use multi-threading and going with a dual core is just wasting money, cause you will be buying a quad within the end of the year.
    EDIT ** Its the way of the future, might as well jump in now
Share This Page
