Help choose between two and why? Thanx
Discussion in 'Graphics Cards' started by JunkBear, May 18, 2014.
  1. JunkBear
    JunkBear
    Sep 16, 2013
    1,068 (1.22/day)
    468
    Canada
  2. SKL_H
    SKL_H
    Mar 6, 2014
    43 (0.06/day)
    10
    I would recommend Asus Asus EAH5450 Silent/DI/512MD2/LP with DDR2 due to its
    HDMI
    Direct X 11
    OpelGL 3.2
    0dB
    the downside it the DDR2 memory.
  3. JunkBear
    JunkBear
    Sep 16, 2013
    1,068 (1.22/day)
    468
    Canada
    Also downside is 64bits instead of 128bits. Why they power down cards like that with lower memory instead of newer ?
  4. MxPhenom 216
    MxPhenom 216 Corsair Fanboy
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    I am looking at your system specs, and shows that your current system is an HTPC? Will the new one be as well? That'll help determine what GPU to use.
  5. JunkBear
    JunkBear
    Sep 16, 2013
    1,068 (1.22/day)
    468
    Canada
    I keep this one under my avatar and switch for the better gpu. Then the gpu i currently have will be thrown into another system.
  6. joe12345
    May 12, 2014
    15 (0.02/day)
    9
    DDR2 or DDR3 play no role, because you will not game with these.
    Same goes for DX, GL whatever. Really.
    But
    HD5450(UVD2) > 8600GT(VP3)
    means with 5450 you will have video decode acceleration support for much more formats.
    Low profile and fanless add-up too.
  7. JunkBear
    JunkBear
    Sep 16, 2013
    1,068 (1.22/day)
    468
    Canada
  8. eidairaman1
    Jul 2, 2007
    14,399 (4.58/day)
    2,133
    honestly go with a 5770 or 6770, cant go wrong with either of them- especially a Sapphire Unit
  9. flmatter
    flmatter
    Feb 11, 2012
    593 (0.41/day)
    387
    Anchorage Alaska
    or a gts 450.... cheap card to throw in there and blows both doors off the 2 cards you are looking at
  10. JunkBear
    JunkBear
    Sep 16, 2013
    1,068 (1.22/day)
    468
    Canada
    I already have these two thats why i gave options with these two and stated that i have them in my possession. Why people keep telling to buy other stuff when someone offer a clear choice?
  11. Jetster
    Jetster
    Jan 17, 2010
    7,339 (3.31/day)
    3,761
    Oregon
    Because they both are crapy cards. The 5450 is ok for video play but not gaming.
    But you could try the 8600 for BF2. It will be painful but playable
  12. Devon68
    Devon68
    Jan 25, 2014
    1,395 (1.87/day)
    835
    Asus EN8600GT
    Because it is 128 bits and has DDR3 ram. While many said the 5450 would be better because it's silent I think that does not matter in a system that has a stock cooler on a CPU.
    JunkBear says thanks.
  13. Tatty_One
    Tatty_One Senior Moderator Staff Member
    Jan 18, 2006
    18,080 (4.92/day)
    3,934
    Worcestershire, UK
    To be honest, if you want any hope of playing some Battlefield 2 you will probably need to go with the 8600GT, if you check out TPU's review of the 5450 when it came out it pretty much struggled to play the origional Crysis game with little or no detail even at low res, well i say struggle, complete fail really as it couldn't get into double figured FPS!
    10 Year Member at TPU
  14. AsRock
    AsRock TPU addict
    Jun 23, 2007
    13,154 (4.17/day)
    2,915
    US
    That depends what you want the card for as in the original OP you did not say..
    If ya want the lowest power card of the 2 get a Kill A Watt. Although i would of thought that would be the 64bit card.
  15. joe12345
    May 12, 2014
    15 (0.02/day)
    9
    Hello.
    First, I was wrong. 8600GT has VP2 level, which corresponds to TrueVideo feature level A - basic.
    5450 has full UVD2 logic, which corresponds to Fermi and up. So, for video decoding 5450 is many times better.
    Second, both cards are strictly OpenGL2, DX8 era level. Which means you are okay with titles such as Far Cry 1 (one) or Doom 3. 5450 is OpenGL3.3/DX10 level, but due to hardware (in)capabilities, its not recommended for anything more-less serious.
    Anything heavier will impose problems in performance. These card classes were not designed for it(5450 is office/htpc level)/are outdated in performance to match it(8600GT is entry level gaming card of 2007, 7 years ago).
    Third, hwcompare is incorrect site to compare performance. Something like GPUboss or even better passmark's gpu score will give better average result.
    Pay attention though, that OpenGL2, 3 and 4 (and DX8, 10 and 11) differ in scene processing, so you will be set back at functionality needed to render games correctly. Games will fallback to legacy render backends and you will not get experience.
    Fourth, if I fully understand your situation, as a real life example, I purchased HD5850 with 1Gb of gddr5 vram for 60$ from ebay. This is about performance level of HD6870 or HD7770. If you consider playing more/less modern 3d games, consider buying used GPU instead of relying on slow outdated hardware.
  16. Tatty_One
    Jan 18, 2006
    18,080 (4.92/day)
    3,934
    Worcestershire, UK
    Whilst i agree with much of what you have said regarding both cards limitations, there are one or two inaccuracies for example the 8600GT is fully DX10 compliant, the 5450 is DX11.
    joe12345 says thanks.
  17. MxPhenom 216
    Aug 31, 2010
    11,416 (5.74/day)
    3,252
    Seattle, WA
    If you are building a new rig, why not use an AMD APU? Be more powerful than both the 5450 and 8600.
  18. JunkBear
    JunkBear
    Sep 16, 2013
    1,068 (1.22/day)
    468
    Canada
    I am not. I just keep my own system and wanted to keep thebest of two cards.Then the card leftover will be reinserted in a system that i will give away to someone in need.
  19. SKL_H
    SKL_H
    Mar 6, 2014
    43 (0.06/day)
    10
    I would say choose the Asus EAH5450 it will play most game,
    plus here is a video of the review which shows the card handling world of Warcraft
    I am certain that you can play BF2 if you adjust the settings well.:oops:
  20. Jetster
    Jetster
    Jan 17, 2010
    7,339 (3.31/day)
    3,761
    Oregon
    First battle he gets into FPS will drop to 10
    flmatter says thanks.
  21. flmatter
    flmatter
    Feb 11, 2012
    593 (0.41/day)
    387
    Anchorage Alaska
    I had a 8600gt and it was horrible with BF2 and WoW was barely playable, I got rid of them as fast I got them. I ended up with 9800gtx's and gaming was much better. Hence my suggestion to buy a gts 450. Hell I even upgraded my wife's computer to a gts 450 just because it is a stout little card. The silent card should not even be considered to play games because it will hit its thermal barrier quite quickly with bf2 on any setting.
  22. joe12345
    May 12, 2014
    15 (0.02/day)
    9
    Absolutely. Unfortunately/fortunately I haven't used anything DX since my refusal to follow MS bandwagon since Vista, so my error comes not unexpected. Thanks.
  23. suraswami
    suraswami
    Apr 5, 2005
    6,454 (1.63/day)
    998
    Republic of Asia (a.k.a Irvine), CA
    Out of the 2 cards I would go with 8600GT, it will still play BF2 fine at 720P and low to medium resolution. I have the EVGA 8600GT in my media center PC since that card was released, its still doing its job for so many years. I only use the PC to record shows and watch Blu-ray content. I did try playing BF2 on big TV with 1080P, it was painful tho.
    Tatty_One says thanks.
  24. eidairaman1
    Jul 2, 2007
    14,399 (4.58/day)
    2,133
    Hmm never happened on a x1950 Pro Agp...
  25. Mr.Scott
    Mr.Scott
    Dec 25, 2012
    208 (0.18/day)
    249
    Spencerport NY
