Help choosing motherboard and features
Status
Not open for further replies.
696 (0.17/day)
India
System Name To be ALL IN ONE MACHINE. but not yet
Processor i7 3770k
Motherboard Asus P8Z&&-V Deluxe
Cooling Thermalright Silver Arrow
Memory Gskill Ripjaws 1600Mhz 8GB *4 = 32GB
Storage Samsung pro 840 256GB, Segate 3TB and 1TB
Display(s) LG 23" Full HD LED
Case Antec LanBoy Air
Power Supply Cooler Master M2 Silent Pro 850 Watts
Software Windows 7 ulimate 64bit
Hi Guys,
Which board is best among below ?
Asus Maxumus V Formula Or Asus P8Z77-V DELUXE
Please suggest.
Thanks
1,445 (0.34/day)
Israel
Processor AMD Ryzen 7 5800X
Motherboard B550 Aorus PRO V2
Cooling Corsair H115i RGB Platinum
Memory Gskill Trident Z Neo 3600 2x16GB
Video Card(s) MSI RTX 3070 Trio X
Storage WD Blue SN550 1TB NVME/Supertalent Teranova 2x1TB
Display(s) Acer XV340CK
Case Corsair 4000D Airflow
Power Supply Corsair HX850i
Keyboard Logitech G513 Tactile
Unless you need the WiFi i would say the formula but honestly you can get cheaper boards that will perform pretty much the same.
lyndonguitar
I play games
1,878 (0.37/day)
Philippines
System Name X6 | Lyndon-ROG
Processor Intel Core i7-8700k | Intel Core i7 6700HQ
Motherboard Gigabyte Z370 Aorus Gaming 5 | Asus ROG-GL552VX
Cooling Deepcool Captain 240EX
Memory 16GB Corsair Vengeance LED | 8 GB
Video Card(s) NVIDIA GTX 1080 8 GB GDDR5X | NVIDIA GeForce GTX 950M 4GB
Storage SSDs: 500GB, HDDs: 2TB, 2TB, 3TB | SSD: 250GB, HDD: 1TB
Display(s) Samsung 49" CHG90 3840x1080@144Hz, Panasonic 32" HDTV, | 15.6"1080p
Case Cougar Panzer Max
Audio Device(s) HyperX Cloud II | Corsair Gaming H1500 7.1 | ROCCAT Kave 5.1 | Edifier M3200
Power Supply EVGA 750GQ
Mouse Logitech G403 | Razer Deathadder Chroma | Logitech G302 | Mad Catz Cyborg R.A.T. 5
Keyboard Corsair Vengeance K70 Cherry MX Red
and you would use it for? I agree with the guy above, make sure you are gonna use everything in the mobo(OC, Wifi, Dual GPU, etc) or else its a waste of money
cadaveca
My name is Dave
17,232 (2.62/day)
Unless you need the WiFi, I would say the formula
Formula has WiFi/Blutooth on add-in card.
http://www.techpowerup.com/reviews/ASUS/Maximus_V_Formula-ThunderFX/5.html
ASUS intends ROG platform for gamers/OC'ers. The P-series are mainstream products, and do not offer the same OC features, like ram timing stuff, additional voltages options, fan controls, etc. that are found on the ROG boards. They(the p-series boards) are more intended for non-OC, but can OC fairly well too.
2,132 (0.39/day)
Chicago burbs
System Name Halloween Boo!
Processor Intel Core i7 3770K
Motherboard Gigabyte Z77-Up7
Cooling Custom Water/ Thermalchill TA 120.3/ Swiftech Apogeee XT/ MCP655/ Swiftech M icrores/ XSPC RX 240
Memory 16G G.Skill trident 2400MHz
Video Card(s) 3 x Radeon 7970
Storage OCZ Revo Drive 240G
Display(s) 24 inch Viewsonic
Case Phobia WayCoolIt Test Bench
Power Supply Nexus 1100 watt
Maximus is better but to get off subject, The Maximus is overpriced and not needed unless your a hardcore overclocker. All Z77 boards CPU performance are essentially the same. If your not a hardcore overclocker, there are plenty of Z77 boards that may fit your needs such as the MSI Z77 GD65. it will overclock within 100MHz of the Maximus on water and the same on air seeing Ivy chips run hot. The GD65 retails for $160 US and is one of the Z77 best bang for the buck. The 8* series IMO are also overpriced with really no gains over the GD65. USB 3.0 speeds may be a tad faster but that's about it. You will not notice any particular advantages in performance on a day to day basis with the GD 65. gigabyte also makes some great mainstream Z77 boards as does ASRock at a lower price that overclock great.
The maximus' advantage like I said is a potential max overclock on water of about 100MHz and that is NOT guaranteed but if your doing sub zero overclocking, the Maximus has great Power Phase and a very in depth bios for sub zero and for Ram adjustments but seriously, there is not a noticable performance gain in memory overclocking anyhow. The GD65 will certainly get high end ram to 2400MHz.
1,445 (0.34/day)
Israel
The G65 is a good alternative in addition to boards such as the asrock extreme 4 and the gigabyte UD4H.
696 (0.17/day)
India
Processor i7 3770k
http://www.techpowerup.com/reviews/ASUS/Maximus_V_Formula-ThunderFX/images/wifi_top.jpg
well said....:rockout::rockout::rockout:
696 (0.17/day)
India
Processor i7 3770k
Does this onboard wifi really stream HD videos to your mobiles and Tablets smoothly?
Has anyone tried it?:confused::confused:
What about this Bluetooth 4.0 function,does it mean that we can just right and send any file from our PC to Bluetooth enabled Mobile?:confused::confused:
cadaveca
My name is Dave
17,232 (2.62/day)
WiFi:
I gamed on it with no problems. Really, it's true use is as you say, to allow the board to act as an access point, and I think both boards include software exactly for this. I could check with the formula, I do have one sitting on my shelf, but the P-series is not a product line that ASUS sent me for Z77, so I am not familiar directly with those products. I have no tried streaming video to devices as my network is already built to do so, and provides that function via my DVR, but only in 720p. I did stream 1080p flash videos to the ASUS Maximus V formula using that Wifi card in that picture, but not from it to other devices.
Bluetooth isn't something I use. Ease of use is not good enough yet for the desktop environment unless you are talking about keyboards and mice. My only experience with Bluetooth phone stuff required software which I did not like.
7,083 (1.04/day)
Asked my ISP.... 0.0
System Name Lynni PS \ Lenowo TwinkPad T480
Processor AMD Ryzen 7 7700 Raphael \ i7-8550U Kaby Lake-R
Motherboard ASRock B650M PG Riptide Bios v. 2.02 AMD AGESA 1.1.0.0 \ Lenowo 20L60036MX Bios 1.47
Cooling Noctua NH-D15 Chromax.Black (Only middle fan) \ Lenowo WN-2
Video Card(s) Asus GeForce RTX™ 4070 Dual OC GPU: 2325-2355 MEM: 1462| Nvidia GeForce MX™ 150 2GB GDDR5 Micron
Storage Gigabyte M30 1TB|Sabrent Rocket 2TB| HDD: 10TB|1TB \ SKHynix 256GB 2242 3x2 | WD SN700 1TB
Display(s) LG UltraGear 27GP850-B 1440p@165Hz | LG 48CX OLED 4K HDR | AUO 14" 1440p IPS
Case Asus Prime AP201 White Mesh | Lenowo T480 chassis
Keyboard Akko 3108 DS Horizon V2 Cream Yellow | T480 UK Lumi
Software Win11 Pro 23H2 UK
cadaveca now when u talk about the Wifi is the card a Intel or what is it?
i forgot to check and i am too lazy to open the box again :roll:
696 (0.17/day)
India
Processor i7 3770k
I think I should go for V Formula:D:D
7,083 (1.04/day)
696 (0.17/day)
India
Processor i7 3770k
the formula is a nice board, with a fine build-in audio even it's a Realtek chip.
Who produces better sound V gene or V formula ?:rolleyes::rolleyes:
Aquinus
Resident Wat-man
13,147 (2.94/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
If the wi-fi module is the same one as the one that came with my P9X79 Deluxe, it's an Atheros based wi-fi card. Works out of the box in Ubuntu as well. My machine says it is an Atheros AR9002WB-1NG.
7,083 (1.04/day)
the V Gene uses a Realtek ALC892 and V Formula uses a Realtek ALC898 chip if i am not wrong ^^;
hmm i would personally change that out with a Intel, bcs they r just better :cool:
Aquinus
Resident Wat-man
13,147 (2.94/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
If that much bandwidth makes a difference, than you can keep arguing that Ethernet is better and if speed is truly important you wouldn't be using wi-fi to begin with. :)
7,083 (1.04/day)
Intel is just using less cpu and memory then other brands and gives a better connection overall that has been proven before, but yes i am using wire, would be a shame not to on a 30/30mbit connection :roll:
696 (0.17/day)
India
Processor i7 3770k
Is V Formula ThunderFX is really worth buying it over V Formula ?
What else ThunderFx provides extra over V Formula?
How much extra do I have to pay for ThunderFX?
7,083 (1.04/day)
maybe this quote will help u michael:
ThunderFX box is good, but lacks volume, IMHO. BEing USB powered, I'm not surprised about that, though.
cadaveca told me that some days ago, but why not if u don't think onboard is enough buy a dedicated audio card?
696 (0.17/day)
India
Processor i7 3770k
Yes, I am gonna buy sound card, But what is this IMHO mean ? And what do you really mean by "lacks Volume", not Clear, or less Volume ?
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Keyboard Razer Huntsman Tournament Edition
I'm Not Exactly Sure It Was Necessary To Make Another Thread On Motherboards.
696 (0.17/day)
India
Processor i7 3770k
Yes, Actually I have many queries, so had opened 2 threads.:p
After watching many videos from youtube and all your opinions from this site, I have decided to buy Asus Maximus V Formula/ThunderFX. for my i7 3770k
I have few questions though:-
1.Can I use Corsair RAM 2400MHZ right from the start without doing any overclocking?:confused:
2. I think i7 3770k with V Formula will easily carry around 10 Virtual Sytems with 32Gb Ram, is Overclocking also helps in running Virtual Machines more smoothly?:confused:
3. is 750W PSU enough or 850W ?:confused:
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
You opened two threads, one got closed, because they talk about the same things. I don't get what you mean many queries. All your questions can be answered in one thread, as they are pertain to motherboards.
The 2400mhz memory will not run at that speed right away. Its not plug in and play. 3770k/ Ivy Bridge memory controller native/default memory speed is 1600mhz. You are going to have to "Overclock" that to run 2400. You can also try the XMP Profiles to set it for you, but that wont work sometimes. Overclocking the CPU will make the VMs run just a they would on a normal system, it wont allow you to run more VMs. VMs need the resources. 750w would be fine. even a 650w would be.
696 (0.17/day)
India
Processor i7 3770k
Well Said........:rockout::rockout::rockout::rockout:
I just like you all guys. you are all talented people out here.:):)
Status
