Help choosing motherboard and features
Discussion in 'Motherboards & Memory' started by michael, May 4, 2013.
Thread Status:
Not open for further replies.
  1. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    I might just buy Extreme motherboard if I have to pay only $100 than that of V Formula/Thunderfx.
    As Extreme also do support Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
    and only thing extreme MB misses is Sound Card for which I will my one of High End Asus Xonar.
    By the way which Xeon processor can carry 20 VMs. would someone please comment on this, the name of processor?
    Thanks,
    :D
  2. puma99dk|
    puma99dk|
    Aug 29, 2005
    3,641 (1.03/day)
    850
    the ThunderFX version about 35USD more expensive then the Extreme in my country.
    but why not buy LGA2011 with Xeon processor if u wanna run VM?
    michael says thanks.
  3. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    Guys,
    I just came across Intel Xeon E3-1245 V2 processor which also has all i7 3770k features, mote over it also has integrated graphics and Intel® Virtualization Technology for Directed I/O (VT-d).
    Does anyone know more about this Xeon Processor ?
    :confused:
  4. MxPhenom 216
    MxPhenom 216 Corsair Fanboy
    Aug 31, 2010
    10,596 (6.20/day)
    2,651
    Seattle, WA
    Nope, But You Can Simply Research It A Bit If You Go To Intel Website
    Crunching for Team TPU
  5. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    What is difference between
    Corsair Vengeance DDR3 8 GB (1 x 8 GB) PC RAM (CMZ8GX3M1A1600C10)
    Key Features of Corsair Vengeance DDR3 8 GB (1 x 8 GB) PC RAM (CMZ8GX3M1A1600C10)
    240-pin Configuration
    10-10-10-27 CAS Latency
    DIMM Memory Module
    DDR3 1600/PC3 12800
    1 x 8 GB DRAM Structure
    http://www.flipkart.com/corsair-ven...18f48&srno=t_2&otracker=from-search&query=ram
    AND
    Corsair Vengeance DDR3 16 GB (2 x 8 GB) PC RAM (CMZ16GX3M2A1600C10R)
    Key Features of Corsair Vengeance DDR3 16 GB (2 x 8 GB) PC RAM (CMZ16GX3M2A1600C10R)
    DIMM Memory Module
    2 x 8 GB DRAM Structure
    DDR3-1600/PC3-12800
    1.5 V Specified Voltage
    10-11-10-30 CAS Latency
    Dual Channel Memory Configuration
    http://www.flipkart.com/corsair-ven...8f48&srno=t_17&otracker=from-search&query=ram
    Can these both RAM type support i7 3770k and Asus Maximus V Formula Motherbord?
    Please suggest me which one to buy?
    Whose latency is better?
    Please guide...:respect::respect::respect:
  6. erocker
    Jul 19, 2006
    40,411 (12.58/day)
    15,058
    1 x 8gb
    2 x 8gb (looser timings due to one more stick)
    Difference is obvious? They're the same thing.
  7. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    What ??:confused::confused::confused::confused:
    Then why CAs Latency is different ?
  8. cadaveca
    cadaveca My name is Dave
    Apr 10, 2006
    14,227 (4.29/day)
    7,514
    Edmonton, Alberta
    Different quality of memory IC, or even completely different IC itself.
    Probably completely different sticks
    C10R at the end is hints that that kit is kind of designed to overclock. All the red vengeance kis should offer some clocking that the black/white/blue ones do not. Note that the new 3000 MHz sticks from Corsair are Red Vengeance sticks...red = overclocking.
    Differences between those sticks, when run at XMP settings, will be pretty similar.
  9. erocker
    Jul 19, 2006
    40,411 (12.58/day)
    15,058
    Not necessarily. It's possible the cas latency is a little lower due to it being a single stick and less load on the IMC. I'd like to see a 2 stick set of that red stuff to know for sure.
    *Found a 16gb kit (2 sticks) of the red stuff and timings are a bit lower, so yeah possible different IC's.
    Either way, don't just buy a single stick.
  10. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    thanks.:toast::toast::respect::rockout::rockout::rockout::rockout:
  11. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    I will buy Red one 16 GB for my i7 3770k and Formula V ThundeerFX.
  12. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    I am going to buy
    Samsung 840 Series 250 GB SSD Internal Hard Drive (MZ-7TD250BW) than
    Samsung 840 Pro Series 256 GB SSD
    I don't see there is noticeable difference in speed among these two drives.
  13. MxPhenom 216
    Aug 31, 2010
    10,596 (6.20/day)
    2,651
    Seattle, WA
    the pro is much faster, especially in write speeds. also has MLC nand rather then TLC.
  14. erocker
    Jul 19, 2006
    40,411 (12.58/day)
    15,058
    All depends on if you want a drive for your O/S or something to store games, etc. on.
  15. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    Guys,
    I have one question please answer me,
    Suppose If I have installed one of the best (dual band) Advanced Wireless N PCI Adapter , then will I be able to stream HD 1080P videos from my CPU to my (Samasung Galaxy Note) mobile wirelessly WITHOUT INTERNET CONNETION ? or it depends on how much MBPS internet speed I have?
    I am really don't know about this.
    Will this card help me achieve this "TP-Link 300Mbps Advanced Wireless N PCI Adapter [TL-WN951N]"
    http://www.aria.co.uk/Products/Netw...ss N PCI Adapter [TL-WN951N] ?productId=44408
    Would you please suggest me any other better card than this?
    Please please advise me.:respect::respect:
  16. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    No one replying......?:cool::cool::cool::cool::cool::respect::respect:
  17. RCoon
    Apr 19, 2012
    8,969 (8.06/day)
    5,253
    Gypsyland, UK
    If both pc and mobile are connected to your home router wirelessly, then yeah, i dont see why not.
  18. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    that means I would require internet to stream :confused::confused::confused::confused:
    But then how come Segate satellite 500Gb stream HD videos to mobiles and tabs?::twitch::twitch:
  19. theoneandonlymrk
    theoneandonlymrk
    Mar 10, 2010
    3,476 (1.85/day)
    610
    Manchester uk
    Wireless n standard has enough bandwidth for that so it should work fine, mine works ok but I can't actually remember the highest quality ive watched.
    More than 25k PPD
  20. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    Ok, but thats why I have asked particularly about 1080P, i dont wanna watch 480p or 580p videos.
    so my question still remains can we stream 1080p video without internet connection in home from PC to Mobile/tablets ??
    what is best cpu fan speed controller device which i can put in drive rack ? please name some
  21. MxPhenom 216
    Aug 31, 2010
    10,596 (6.20/day)
    2,651
    Seattle, WA
    there is not a single best fan controller. just search for a few that function how you want with enough Watts per channel to control your fans. Lamptron controllers are solid.
  22. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    Hi Guys,
    Please tell me which board has best Audio Vgene or V formula, I am reading in some review that V gene has better sound output than V formula.
      File size:
      84.3 KB
      45
  23. Aquinus
    Aquinus Resident Wat-man
    Jan 28, 2012
    7,358 (6.16/day)
    2,802
    Concord, NH
    Don't choose the board based on audio. If you really care that much you should get a separate audio card anyways. The Gene is a micro-atx board, so it's small. The Formula is a full ATX board with more expansion opportunities. I would personally go with the Formula and if the audio bothers you, then upgrade. The difference between the two shouldn't be a deciding factor on which motherboard you want to get.
    Also according to your picture they both have the same thing, so are you really asking a question? :p
    Choose the smaller one if you need a small board, or the Formula if you need a big board. Done.
  24. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    Thanks a lot for your replies , I am really gaining a whole lot of information from you guys.
    Yes there is difference in V gene it has Creative sound software.:)
    But Yes I agree that separate sound card is better.:rockout::rockout::rockout:
  25. michael
    michael
    May 2, 2013
    570 (0.78/day)
    14
    India
    My other question is:-
    I am going to buy Samsung 840 Pro Series 256 GB SSD Internal Hard Drive (MZ-7PD256BW), so should I buy another say 60GB mstat drive for caching SSD,
    First of all, will 60GB msata drive work as cache memory to my 256 GB SSD ?
Thread Status:
Share This Page
