Help choosing Power supply.. How many 12v rails?
Discussion in 'General Hardware' started by bud951, Dec 29, 2009.
  1. bud951
    bud951 New Member
    Dec 24, 2007
    218 (0.07/day)
    7
    San Antonio, TX
    I am looking for a new PS to replace my very good but noisy PCP&C 510SLI. This will be powering a media PC so I need it to be quiet. Its an older cpu and board, FX-60, DFI SLI-DR, 8800GT. Not really a gamer machine, its going to be a down loader, storage PC and media player. It will have about 6-8 drives though so I figure why not get a 750w? Should I get one with a single 12v rail? I don't know that much about power supplies. I just need it to be quiet reliable and modular cabling. Any suggestions? Thanks.
  2. crazyeyesreaper
    crazyeyesreaper Chief Broken Rig
    Mar 25, 2009
    8,449 (3.36/day)
    3,222
    04578
    i suggest a corsair 400watt seems to be the best psu for that job honestly i actually like the PCP&C but if its to loud the corsair might be a better option installed one the other day thanks to kurosagis prodding to use it in a customers rig and it was silent and delievered plenty of power a nicely loaded quadcore rig
  3. King Wookie
    King Wookie New Member
    Jan 1, 2008
    1,197 (0.40/day)
    277
    Johannesburg, South Africa
  4. crazyeyesreaper
    Mar 25, 2009
    8,449 (3.36/day)
    3,222
    04578
    seems 4 corsairs are on that list the vx450 and the tx650 and the HX 520/620
  5. King Wookie
    Jan 1, 2008
    1,197 (0.40/day)
    277
    My HX 620 is seriously quiet. Can't hear it over my Noctua case fans. Always a good buy.
  6. crazyeyesreaper
    Mar 25, 2009
    8,449 (3.36/day)
    3,222
    04578
    i would think the 450 better fits the needs of the rig tho 510 vs 450 both top notch brands if he was more of a modder id say change out the fan in the PCP&C and call it a day but yea most corsairs are quiet and the HX are modular to boot
  7. bud951
    bud951 New Member
    Dec 24, 2007
    218 (0.07/day)
    7
    San Antonio, TX
    I can handle that. What fan should I go with? It looks to be an 80mm.
  8. crazyeyesreaper
    Mar 25, 2009
    8,449 (3.36/day)
    3,222
    04578
    hmm ive got 2 80mm fans laying around there masscools still work as well let me look at the specs on them and ill get back to you ill send them for cost of shipping basically $2 ;)
    bud951 says thanks.
  9. pantherx12
    pantherx12 New Member
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    Amount of rails doesn't matter really, you just want a shit ton of available amps : ]
    My PSU has 6 12v rails, its my preference to use a multi rail PSU but at the end of the day just buy what suits you best : ]
    ( And don't buy cheapy tat, I spend 4 weeks researching PSUS, then 4 days searching for the right one at the right price, I suggest at least doing a bit of research on the PSUs your already looking at.)
  10. crazyeyesreaper
    Mar 25, 2009
    8,449 (3.36/day)
    3,222
    04578
    well panther hes already running a PC power and cooling unit and there top of line as is just a little lound sometimes and corsairs are rock solid as well
    but i figure a fan swap might work better for him i just have to look up the specs on the 2 fans i got to make sure they would fit the bill so to speak
    why spend $70ish when u can spend $2 ish lol
  11. crazyeyesreaper
    Mar 25, 2009
    8,449 (3.36/day)
    3,222
    04578
    this is what i have on hand needs a bit of retouch with the wiring and i have to test it to make sure theres no issues but
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835150044
    id make sure that psu takes an 80mm fan first tho just to be on the safe side
    the wires will have to redone on mine but thats a given anyway if u want it to fit properly
  12. pantherx12
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    I'd normally say go for a fan swap too, but I tend to only do such things on older or cheaper PSUs.
    I wouldn't touch this PSU til the waranty is void XD
    To expensive to replace if it guffs up!
    Not like monkeying around with a motherboard where the manufacturer can't really tell if you have or not, psus have a stick over one of the screws.
    So OP bare that in mind : ]
  13. crazyeyesreaper
    Mar 25, 2009
    8,449 (3.36/day)
    3,222
    04578
    good point but i dont get why the PCP&C is loud ive got the silencer 750 that uses and 80mm fan and its silent so it makes me wonder a bit
  14. pantherx12
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    Could be fan is faulty or OP is just sound sensitive *shrugs*
    Or everything else in his setup is quiet as hell and the PSU is just the loudest.
    Can make it seem louder then it is.
    ( for example loudest thing in my system is chipset fan that's rated for 21db, probably only a db or two louder but its very noticeable to me, could be the high pitch mind you.
  15. RejZoR
    RejZoR
    Oct 2, 2004
    7,351 (1.77/day)
    2,222
    Europe/Slovenia
    You can't go wrong with any Corsair PSU. Corsair CX400 should be enough for you.
    10 Year Member at TPU Crunching for Team TPU
  16. bud951
    bud951 New Member
    Dec 24, 2007
    218 (0.07/day)
    7
    San Antonio, TX
    I don't remember it being this loud when it was new but that was 5 years ago. I just built a pc form my nephew with a 750w silencer and it is pretty quiet. PCP&C just use smaller fans than Corsair and others. I think I have an 80mm case fan around here somewhere but If I need it I will PM you. Thanks for the offer.
  17. cdawall
    cdawall where the hell are my stars
    Jul 23, 2006
    21,728 (6.22/day)
    3,574
    Houston
    your PCP&C is more than enough for you i would just keep that and mayb pop the case and throw some silent fans in it
  18. crazyeyesreaper
    Mar 25, 2009
    8,449 (3.36/day)
    3,222
    04578
    the issue for him seems to be PSU fan noise nothing else
  19. Error 404
    Error 404
    Apr 14, 2008
    1,777 (0.62/day)
    169
    South Australia
    Have you recently dusted the PSU? They really do get quite clogged up over the years. Only yesterday I had to take out the family PC's PSU, blast out the dust, and put some machine oil in the fan to make it stop grinding. After that, it went back to being a silent little OEM POS. :)
