Help getting surround sound from xbox 360 to 5.1 speaker kit
Discussion in 'Audio, Video & Home Theater' started by jonathan1107, Nov 9, 2011.
  1. jonathan1107
    jonathan1107
    Dec 30, 2010
    1,116 (0.67/day)
    41
    Canada
    Hey guys, just a technical question about surround sound for xbox 360...
    I think I've found my solution, but I just wanted to post it here to make sure it's gonna work before goin ahead and buyin the optical cable...
    My xbox 360 is connected to my PC monitor thru an HDMI cable... The monitor in question has built-in speakers but they suck (and they are not 5.1 of course...)
    I have my own 5.1 speaker kit that I use with my PC... and I got this right: My sound card has an SPDIF in and another SPDIF out hole...
    Logically, I figured... maybe I can buy an optical cable to link the Xbox 360 surround sound to my PC's soundcard which in turn should play the sound thru my 5.1 speakers like anything else my PC plays right???
  2. KingPing
    KingPing
    Aug 17, 2009
    844 (0.39/day)
    286
    Argentina (South America)
    I do that but with my Ps3, video trough HDMI and Audio trough optical cable to opt in in my Soundcard then to the 5.1.
    I guess you can do the same with the 360, not sure cause i donĀ“t own one though.
  3. jonathan1107
    jonathan1107
    Dec 30, 2010
    1,116 (0.67/day)
    41
    Canada
    I got the wires I need... got the optical cable and I'm trying to send it into my sound card... but I can't seem to find the SPDIF "in" at the back of my PC... what do I do? There seems to be a hole for the SPDIF in... but it looks like an analog hole...
    Or is there a way to connect an optical cable on the sound card itself? inside the pc...
  4. KingPing
    KingPing
    Aug 17, 2009
    844 (0.39/day)
    286
  5. jonathan1107
    jonathan1107
    Dec 30, 2010
    1,116 (0.67/day)
    41
    Canada
    Yes it is... and yes ... I just came to realize I don't have an opt in with this sound card... Is there another solution ?
    Like using a receiver?... and if I do use a receiver, how will that receiver send it's "decoded audio" (or whatever U wanna call that) to the 5.1 speakers?
    Will I have to unplug the analog wires from the sound card and plug em into the receiver? And if so, is there a way to avoid having to do that?
  6. KingPing
    KingPing
    Aug 17, 2009
    844 (0.39/day)
    286
    No idea, i have never used a receiver. But wouldn't be cheaper to buy another sound card (no idea how much a receiver would cost:confused:). The only receiver i have is from the 70s, so up to 1970 i know how they work:(
  7. slyfox2151
    slyfox2151
    Jan 14, 2009
    2,620 (1.10/day)
    526
    Brisbane, Australia
    what speakers do you have?
  8. jonathan1107
    jonathan1107
    Dec 30, 2010
    1,116 (0.67/day)
    41
    Canada
    Cyber acoustic CA-5001 (5.1 speakers)
    PLS u guys, I NEED help... If you can't help me with this, pls find me someone who can, or refer me to a person or place who will Rescue me from this Complicated situation :O(
  9. slyfox2151
    slyfox2151
    Jan 14, 2009
    2,620 (1.10/day)
    526
    Brisbane, Australia
    you have 2 options.... buy a new sound card... or buy new speakers that support HDMI or Optical.
  10. CJCerny
    CJCerny
    Nov 25, 2008
    889 (0.36/day)
    263
    Akron, OH
    If I had a 360 and a PC and I wanted both to have 5.1 sound via speakers, I would buy a receiver, connect both the 360 and the PC to the receiver via HDMI and then connect the monitor to the HDMI out of the receiver and use the receiver for all audio decoding and video switching. Receiver will set you back at least $200. Regular speakers (ones that are not amplified and don't have RCA cables on them) will set you back a few hundred more. In your PC, you can ditch your soundcard and go with a modern video card that has both video and audio output on the HDMI.
  11. Dent1
    May 18, 2010
    3,368 (1.77/day)
    1,035
    Very few soundcards will retain the bitstream audio via SPDIF-IN. Either way your PC speakers don't have built in receiver the Dolby Digital/DTS will be loss.
    You need to invest in a homecinema system with receiver and connect the 360 to it directly via HDMI or SPDIF.
  12. CJCerny
    CJCerny
    Nov 25, 2008
    889 (0.36/day)
    263
    Akron, OH
    Another option might be to track down a different speaker system that has multiple inputs, like more than one digital input, either optical or coax, or one digital input and one analog input. The speaker system would likely also need to have DD/DTS decoding, especially if your soundcard has a DD Live encoding capability.
  13. jonathan1107
    jonathan1107
    Dec 30, 2010
    1,116 (0.67/day)
    41
    Canada
    wow... so basically Xbox 360 surround sound is for RICH people right?...
    Isn't there an external sound card or a cheap receiver which can take the surround sound from the xbox 360, decode it into analog?...
    I can see how someone installing his Xbox 360 can get surround sound when he's got his xbox 360 in the lounge with his big Speaker + receiver system... but how about people wanting to play with their 5.1 speakers in their office...
    And when you say there might be 5.1 PC speaker kits out there that have an opt input, can you link me one of those... and if I do can one of those, will it be able to interprete the sound coming from the optical cable and output it to the speakers properly???
  14. CJCerny
    CJCerny
    Nov 25, 2008
    889 (0.36/day)
    263
    Akron, OH
    You don't have to be rich to get surround sound from a 360. You just need to find a speaker system that can accept surround sound from 2 sources (360 and PC) using the connectors you have available for each. Start at the Logitech site. They make stuff like that.
  15. jonathan1107
    jonathan1107
    Dec 30, 2010
    1,116 (0.67/day)
    41
    Canada
    Thx CJcerny, I'll be looking into that, altho a link would be greatly appreciated...
    Kinda helps to prove your point...
  16. Dent1
    May 18, 2010
    3,368 (1.77/day)
    1,035
    lol. Educated people.
    1st things first. You need to be educated on a few things before we can advise you correctly.
    When you say surround sound. You mean Dolby Digital or DTS sound.
    Dolby Digital and DTS can only be passed through a digital cable. Coaxial, fibre (SPDIF), or HDMI.
    Analogue cable can not carry Dolby Digital or DTS, hence whether it's on a Xbox, PS3, or PC. The surround sound on your PC is not true surround sound, its more of a emulated upmix.
    Just because all 5.1 speakers make doesnt mean its Dolby Digital or DTS.
    Office environment isnt the best for gaming. You have to decide whether surround sound is important to you when you should be at work!
    Forget about the optical input stuff. You need a receiver. Maybe new speakers too.
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16882115339
Share This Page
