[help] how to read/understand monitor size
Discussion in 'General Hardware' started by lZKoce, Apr 4, 2014.
  1. lZKoce
    lZKoce
    Jan 31, 2012
    790 (0.70/day)
    121
    Bulgaria
    Hi all,
    it may sound really stupid, but I can't understand how to convert sceen size from inches to centimeters. My mom wants to buy a 14 inch laptop and she asked me if I could show it with a ruler. However, when I multiply 14 inches by 2.54 cm- I get 35.56- which is HUGE compared to the physical size of the laptop. It's smaller than my 15.6 inch one. So apparently I don't know how to read monitor sizes. How do I transfer 14 inch to my ruler? I looked around, but my string is not good enough and the search results I get are incosistent. This thing bugs me really.
  2. Aquinus
    Aquinus Resident Wat-man
    Jan 28, 2012
    7,135 (6.31/day)
    2,667
    Concord, NH
    Monitors are measured from opposite corners. So just measure the two corners of the screen that are furthest apart and that will give you display size.
    To the edges of the panel is the viewable size. To the very edge of the monitor is the full size.
    lZKoce says thanks.
  3. lilhasselhoffer
    lilhasselhoffer
    Apr 2, 2011
    1,696 (1.19/day)
    1,060
    East Coast, USA
    That answer is correct. You're probably thinking that the dimension that they provide is either the width or the height, but that is not accurate. Check out the following chart:
    http://en.wikipedia.org/wiki/File:LCD_screen_sizes.svg
    That monitor is about 28 cm wide by 21 cm high (11" by 8.25").
    lZKoce says thanks.
  4. patrico
    patrico
    Jul 6, 2006
    336 (0.11/day)
    129
    ireland, galway
    yeah its a diagonal measurement to get screen size, and its not always whats advertised btw eg 24inch could really be 23.5inch
    lZKoce says thanks.
  5. MxPhenom 216
    MxPhenom 216 Corsair Fanboy
    Aug 31, 2010
    10,417 (6.33/day)
    2,537
    Seattle, WA
    This. Measure diagonally.
    Also if you need to convert units, just put it into google. For example,
    "24 inches to cm"
    Google will do the calculation for you.
    lZKoce says thanks.
  6. lZKoce
    lZKoce
    Jan 31, 2012
    790 (0.70/day)
    121
    Bulgaria
    Thanks guys. I tried and it's better. I knew about diagonal, but I thought I should go from plastic end to plastic end. It's enough though.
    patrico says thanks.
Share This Page
