Help: HT speed won't go beyond 200 MHz!
Discussion in 'Motherboards & Memory' started by Fenhasan, Feb 11, 2009.
  1. Fenhasan New Member
    Feb 10, 2009
    5 (0.00/day)
    1
    Chile
    Hi:
    I'm using the PC on the signature. It's new, a month old or so. Every game i tried ran faster than my previous PC (P4 2.4 GHz, ATI 9550). But when i tried 3DMark2006, and COD4:MW, i noticed it's running slower than it should: Barely above 6000 points on 3dMark, and the FPS on COD4 drop to 18-20.
    With this machine, i should be getting over 9000 points, and around 100 FPS in COD4... so something is capping my performance.
    I found a post in this forum that gave me a clue: The HyperTransport Link speed:
    http://forums.techpowerup.com/showthread.php?t=61664
    However, when i try to put a value differrent from 200 MHz in the BIOS, the PC boots Windows alright, but around a minute later, it freezes. I even tried the AUTO setting, no luck, just 200 MHz works.
    My mobo is a GF8200A, with the factory firmware. The AMI Winflash doesn't recognize the BIOS, so I haven't upgraded it yet. The CPU temp is around 30ºC, and the GPU 40ºC when idle, so i think no thermical problems are involved. My PSU isn't generic, so i don't think it's a shortage of power.
    What could be the problem? I really have no idea what's the problem. Could anyone give me a hand? Thanks in advance!
    Best regards,
    Fenhasan
  2. 3dsage
    3dsage New Member
    Nov 8, 2008
    1,797 (0.72/day)
    330
    NW Burbs of Chicago
    IDK but that score seems right to me.
    Also what driver are you running for the card?
  3. spearman914
    spearman914 New Member
    Apr 14, 2008
    3,339 (1.24/day)
    502
    Brooklyn, New York 11223
    Yea score is right, if u oc that 6000+ good, the score will go up a ton, because bottlenecking will be gone.
  4. Fenhasan New Member
    Feb 10, 2009
    5 (0.00/day)
    1
    Chile
    Currently, I'm running the Forceware 175.16 drivers.
  5. 3dsage
    3dsage New Member
    Nov 8, 2008
    1,797 (0.72/day)
    330
    NW Burbs of Chicago
    Overclock your CPU like he said. Score will jump.
    Try running 180.22.
  6. Fenhasan New Member
    Feb 10, 2009
    5 (0.00/day)
    1
    Chile
    BTW, my 3DMark06 CPU Score is 2678. From what I read this is fine. It's the SM2.0 and 3.0 that are really low...
  7. 3dsage
    3dsage New Member
    Nov 8, 2008
    1,797 (0.72/day)
    330
    NW Burbs of Chicago
    Compare your rig to others on ORB.
  8. Fenhasan New Member
    Feb 10, 2009
    5 (0.00/day)
    1
    Chile
    I'll take a look!
Share This Page
