Help! I think i screwed up!!
Discussion in 'Motherboards & Memory' started by stevednmc, Mar 26, 2011.
  1. 95Viper
    95Viper
    Oct 12, 2008
    4,287 (2.04/day)
    1,531
    στο άλφα έως ωμέγα
    Well, from reading the op's opening, he was not cleaning the socket, but the bracket.
    However, he should have, either had the CPU in it or the little plastic protector that it came with.
    Should have or would have is a mute point at this stage in the game, I guess.:ohwell:
    @stevednmc> update us when you get back and all.
    Goodluck!:)
    stevednmc says thanks.
  2. stevednmc
    stevednmc New Member
    Jun 28, 2009
    916 (0.50/day)
    83
    nebraska
    Yeah...this is my first build without help, (Other than TPUers), So im goin to the school of hard knocks here. So i have updated pictures, let me know what you guys think, maybe I saved my bacon after all?
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    In the left side of the second image, it looks like there might be another bent pin, i am unsure. Damn magnifiying glass is only 3X, best i could find for some reason.
    What do you think?
  3. trickson
    trickson OH, I have such a headache
    Dec 5, 2004
    6,494 (1.85/day)
    956
    Planet Earth.
    Looks good . Hit it with the AIR again looks like there is a hair in there .
    95Viper says thanks.
  4. stevednmc
    Jun 28, 2009
    916 (0.50/day)
    83
    nebraska
    LOL, yeah i saw that! I havent even hit it with the air yet. Pulled the tim with a needle and the fuzz...VERY nerve racking...But it came out pretty easy. That pin on the right was a bitch! But it finally went as you can see. The other wasnt so bad it went over pretty easy. I think ther is still some of the TIM in there, but its a TINY amount, i dont think itll hurt anything.:cool:
  5. 95Viper
    95Viper
    Oct 12, 2008
    4,287 (2.04/day)
    1,531
    στο άλφα έως ωμέγα
    Looks a lot better.
    Get that hair outta there and test it.
    Fingers crossed for you.:)
  6. rickss69
    Aug 23, 2009
    2,431 (1.36/day)
    604
    Rockvale TN (Not Australia)
    Something else that works well for pc parts cleaning is brake cleaner in a spray can...cuts most anything and evaporates quickly...compressed air and cleaner all in one.
  7. stevednmc
    Jun 28, 2009
    916 (0.50/day)
    83
    nebraska
    I thought about that, but if it get on plastic its over, or paint for that matter. Was unsure if i should risk it...i think i risked enuff already by bein stupid!
    @Viper, ittl be a while before i can test it. Unfortunately...But if it doesnt boot ill know why. Im still mid build...I?ve torn this thing apart and rebuilt it a bunch of times!!
  8. 95Viper
    95Viper
    Oct 12, 2008
    4,287 (2.04/day)
    1,531
    στο άλφα έως ωμέγα
    I keep this around, for use on my radios, computers, and other electronic cleaning needs.
    Quote from CRC
    "A petroleum distillate / alcohol based precision cleaner designed as an alternative to CFC based cleaners. Ideal for apps where lower flashpoint materials can be tolerated. Cost effective, plastic safe & residue free."
    And, you can pick it up at, just about, any auto parts that carries CRC.
    Ex. Autozone
  9. I see SPY!
    I see SPY! New Member
    Sep 29, 2009
    334 (0.19/day)
    73
    Porto, Portugal
    That reminded me of when I got a bent pin on my motherboard after disassembling the case for cleanup. Man, I was SWEATING all over the place! Thankfully, using a sewing needle and being very careful I managed to put it back in place. From the lastest pics, seems you have done the same :)
  10. stevednmc
    Jun 28, 2009
    916 (0.50/day)
    83
    nebraska
    Im Feelin pretty good about it...not bad for a fat guy on asthma meds!! (Very shaky!)
  11. Laurijan New Member
    Feb 10, 2007
    2,228 (0.82/day)
    343
    Oulu, Finland
    I too would have used some high % alcohol for removing the TIM, some dry electronics spray for example and cotton-tipped swabs as aid but using them only the right way so that the pins woundn´t have gotten covered in more cotton fuss that would have to be removed or pins getting bend.
    For the fuss removal I would have used a sewer needle, going with it between the pins and carefully lift the fuss up with it.
  12. micropage7
    micropage7
    Mar 26, 2010
    5,563 (3.55/day)
    1,270
    Jakarta, Indonesia
    yep sewing needle and steady hand and patient
    thats all you need, and one more pray it works well
  13. Goodman
    Goodman
    Jun 13, 2009
    1,519 (0.82/day)
    324
    Canada/Québec/Montreal
    Great job on cleaning & putting the pins back in place :toast:
    It is not an easy thing to do when it's that small...:respect:
  14. stevednmc
    Jun 28, 2009
    916 (0.50/day)
    83
    nebraska
    Wow! Learn something new everyday! I work with the stuff everyday and didnt know that!
    Thats Finally what i ended up doing, not the cotton swabs though. Thats what caused the fuzz in the firstplace, cheap crappy swab. The needle did the trick to remove all the tim and the fuzz.
    Thanks much!! It was not fun, and i wish to avoid that situation in the future. Maybe someone can learn from my mistake...I hope!
  15. Laurijan New Member
    Feb 10, 2007
    2,228 (0.82/day)
    343
    Oulu, Finland
    Stevednmc - I still think that a cotton swab wet from high alcohol would not fuss easily if used in the right direction and pressing power.
    I the case of you first post pic the direction is from the top left to the bottom right direction - otherwise the pins would "bite" into the cotton swab and it would create more fuss 100%.
    Good think you got the thing cleaned!
  16. Goodman
    Goodman
    Jun 13, 2009
    1,519 (0.82/day)
    324
    I will remember this if i ever go the Intel way one day , thanks! for the heads up :D ;)
Share This Page
