- Mar 16, 2015
- 218 (0.07/day)
- Virginia, United States
Processor | Intel i7 4790K |
Motherboard | Gigabyte Z97X-UD5H-BK |
Cooling | LEPA AquaChanger 240 |
Memory | G.Skill Ares Series 16GB (2 x 8GB) DDR3-2133 |
Video Card(s) | EVGA GTX 980 Superclocked ACX 2.0 |
Storage | Seagate St1000dx001 |
Case | Cooler Master HAF X ATX Full Tower |
Audio Device(s) | Onboard |
Power Supply | EVGA 850W ATX12V / EPS12V |
TL;DR at the bottom
Before anything, I'd like to say thanks to everyone here on the TPU forums! No matter where I go I always get help, and knowledgeable replies! I have learned so much over the month or so I've been here from reading and asking questions.
(Not that I'm brown-nosing, I won't be upset if no-one helps me here, I know I'm probably asking a lot)
No onto the purpose of this post...
So I've come to the realization that I am one of "those" people, I'm honestly overclocking for the fun of it. I guess the idea just fascinates me. That being said, I'm trying to overclock what I can without significantly reducing my components lifespans.
So far I'm pretty happy with my CPU core overclock to 4.8 Ghz.
Specs(Important stuff)
Processor: Intel i7 4790K
Motherboard: Gigabyte Z97X-UD5H-BK
Cooling: LEPA AquaChanger 240
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-2133
My hottest core temperature is 79, using Prime version 26.6 or whatever
(the one that doesn't absolutely murder Haswell)
My personal max acceptable temperature is 85 on any one core. Reason being, I have one core that runs ~5 degrees higher than the rest, no amount of re-applying thermal paste changes it, I also have another core that always sits 6-8 degrees lower than the rest.
So my focus at the moment is overclocking my CPU cache. I'm at 4.4 with a vRING of 1.05. Right now I'm not sure where to go, searching around has made me slightly confused, I think I know what I need to do...but as I said before, I'm trying to be as cautious as possible with this.
What is a safe max vRING? I keep seeing 1.3, is that the generally accepted number? Or should I stay lower?
Will there be a purpose to getting my Cache speed higher than my CPU clock? (If I am able to do so and be stable at a safe voltage)
I was at a stock uncore of 4.0, and was foolishly jumping 200 Mhz at a time without increase my voltage...I actually went to 4.6, and almost had to switch to one of my 3 back-up BIOS.
7 restarts later and it finally went long enough without freezing for me to put it back to 4.4
Scared me enough to both post here, and save my current BIOS to a flash drive so I don't have to remember all my settings.
TL;DR
Current settings:
CPU Core Clock Ratio: 48 (4.8 Ghz)
CPU Vcore Voltage: 1.265
CPU Uncore Ratio: 44 (4.4 Ghz)
CPU Vring Voltage: 1.050
Q's
1. Safe max Vring Voltage?
2. Any reason to push Uncore frequency higher than Core?
Thanks ahead of time for any help/support!
Stock Timings: 11-13-13-31
Current Timings: 10-12-12-30
Video Card(s): EVGA GTX 980 Superclocked w/ ACX 2.0 coolingCurrent Timings: 10-12-12-30
TL;DR
Current settings:
Q's
