Help needed: algae in my WC system?
Discussion in 'Overclocking & Cooling' started by Kaynar, Jun 16, 2013.
  1. Wrigleyvillain
    Wrigleyvillain PTFO or GTFO
    Oct 13, 2007
    7,703 (2.53/day)
    1,791
    Chicago
    I don't like PTNuke. Well, I thought it might be responsible for some blackish gunk build up inside my last block which was kinda sorta corroborated on another forum, but I can't be sure and couldn't prove anyway. It would probably be more common knowledge and could have been some other contaminant(s). But just been just using a kill coil since and try to change my water every six months at the most and so far no visible problems. I should actually open up my new block soon though which has been running almost a year for a look-see though.
  2. drdeathx
    drdeathx
    May 14, 2009
    2,132 (0.86/day)
    479
    Chicago burbs
    Hey Wrigley! I have used a few systems with PTNuke and no gunk. PT Nuke is clear and would not be the culprit here bro.... The black was probably some kind of junk from the new rad, it is a common problem with some rad manufacturers.
  3. james888
    james888
    Jun 27, 2011
    5,458 (3.22/day)
    2,828
    I used pt nuke and got some weird copper deposits from it on my barbs. At least that is the explanation from smarter persons than I am.
  4. drdeathx
    drdeathx
    May 14, 2009
    2,132 (0.86/day)
    479
    Chicago burbs
    It is from the Rad. Did you get that Thermochill Rad James? Thermochill has a reputation for this....
  5. james888
    james888
    Jun 27, 2011
    5,458 (3.22/day)
    2,828
    Check my specs. I wasn't sure what it was when I saw it. I knew it was some kinda deposition. I had a thread at OCN where I was told it was from PTnuke. They quoted some chemistry stuff too that made sense.
  6. drdeathx
    drdeathx
    May 14, 2009
    2,132 (0.86/day)
    479
    Chicago burbs
    I will look at it
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
