Help! New Parts.
Discussion in 'General Hardware' started by Takumi866, May 9, 2009.
  1. Takumi866 New Member
    May 9, 2009
    3 (0.00/day)
    0
    Hello I'm new and I need your feedback please. Heres my parts I'm getting. Thanks.
    Here they are....
    Case: NZXT Tempest [​IMG]
    CPU : AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core
    CPU Socket Type Socket AM3
    Tech Spec
    Core Deneb
    Multi-Core Quad-Core
    Name Phenom II X4 955 Black Edition
    Operating Frequency 3.2GHz
    L2 Cache 4 x 512KB
    L3 Cache 6MB
    Manufacturing Tech 45 nm
    64 bit Support Yes
    Hyper-Transport Support Yes
    Virtualization Technology Support Yes
    Voltage 0.875V - 1.5V
    Thermal Power 125W
    Cooling Device Heatsink and Fan included
    CPU Cooler : Vigor Monsoon III LT Dual 120mm Fan CPU Cooler.
    Type Fan&Heatsinks
    Fan Size 120mm
    Compatibility Intel Core i7 / Core 2 Extreme / Core 2 Quad /Core 2 Duo / Pentium D / Pentium 4 / Celeron / Celeron D
    AMD Phenom x4 / Phenom x3/ Athlon 64 x2 / Athlon 64 / Sempron
    Bearing Type Sleeve
    RPM 2000 RPM ± 10%
    Air Flow 69.69 CFM
    Noise Level 20 dBA
    Power Connector 4-pin PWM
    LED Blue
    Heatsink Material Polished Cu base, AI base, 4 Cu heat pipes
    Physical Spec
    Fan Dimensions 120 x 120 x 25mm
    Weight 855g
    Motherboard: ASUS M4A79T Deluxe AM3 DDR3 AMD 790FX ATX AMD
    # CPU Type: Phenom II / Athlon X4 / Athlon X3 / Athlon X2
    # FSB: 2600MHz Hyper Transport (5200 MT/s)
    # South Bridge: AMD SB750
    # Number of Memory Slots: 4×240pin
    # Memory Standard: DDR3 1600
    # Maximum Memory Supported: 16GB
    # PCI Express 2.0 x16: 4 x PCI Express 2.0 x16 (dual X16, triple X16/X8/X8, or Quad X8)
    # SATA 3Gb/s: 5
    Memory: Patriot Viper 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit
    Type 240-Pin DDR3 SDRAM
    Tech Spec
    Capacity: 4 GB (2 x 2GB)
    Speed DDR3 1600 (PC3 12800)
    Cas Latency 7
    Timing 7-7-7-20
    Voltage 1.9V
    Heat Spreader Yes
    Recommend Use High Performance or Gaming Memory
    Video Card: SAPPHIRE Radeon HD 4870 X2 2GB 512-bit (256-bit x 2) GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
    Hard Drive: Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
    # Cache: 32MB
    # Form Factor: 3.5"
    # Features: High Performance Electronics Architecture Dual processor - Twice the processing power to maximize performance. 32 MB cache - Bigger, faster cache means faster performance. Rock Solid Mechanical Architecture StableTrac - The motor shaft is secured at both ends to reduce system-induced vibration and stabilize platters for accurate tracking, during read and write operations. NoTouch
    Power Supply: NZXT Performance Power PP800 800W ATX 12V 2.2V SLI Ready CrossFire Ready Power Supply
    # Fans: 120mm Fan @ 1900 RPM
    # Main Connector: 20+4Pin
    # +12V Rails: 4
    # PCI-E Connectors: 2 x 6Pin, 2 x 6+2Pin
    # Power Good Signal: 100-500ms
    # Hold-up Time: 16ms min.
    # Efficiency: Up to 85 %
    # Over Voltage Protection: Yes
    OS: Microsoft Windows Vista Ultimate SP1 64-bit for System Builders
  2. Kweku
    Kweku
    Apr 14, 2008
    229 (0.08/day)
    3
    South Africa
    Nice, you might wanna look at water cooling.
  3. sneekypeet
    Apr 12, 2006
    22,831 (6.36/day)
    7,395
    Either way if you cool with water or air, there are better coolers on the market for what the Vigor cost.
  4. Takumi866 New Member
    May 9, 2009
    3 (0.00/day)
    0
    Ok, Can you tell me what's better than Vigor? Thanks.
  5. sneekypeet
    Apr 12, 2006
    22,831 (6.36/day)
    7,395
    Most of the Xigmatek 1283/1284 lineup, the Scythe Mugen 2, a bunch of others really.
    The Vigor is a descent cooler dont get me wrong, but as I say for the price of $55 the Xigs can do a bit better as well as the mugen in the $30-40 range depending on where you get them.
