Help. New power supply problem
Discussion in 'Graphics Cards' started by mrsemi, Nov 16, 2007.
  1. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    Just got this...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817703009
    and I can't figure out if the 12v connectors that work for my 8800 work for the mainboard. The 8 slot pin connector fits on my 650i board with half being unused and the right half of the 6 pin connectors that are the same as what plug into the ultra fit into that slot.
    There's a 4 pin white plug that doesn't fit. I'm fairly certain either the 6 or 8 pin connectors that fit will do the job but I'm so tired of messing up I don't dare plug it in.
    Anyone know for sure?
  2. kwchang007
    kwchang007 New Member
    Jan 27, 2007
    3,979 (1.33/day)
    185
    Severn, MD, USA.
    Ok....so what don't you have plugged in right, the mobo or the gfx? You should either have one 4 pin or one 8 pin into the mobo, not 6 pin, and 2 6 pins in the gfx. Can you link the mobo?
    mrsemi says thanks.
  3. panchoman
    panchoman Sold my stars!
    Jul 16, 2007
    9,595 (3.41/day)
    1,200
    first off, congrats on the great psu purchase.
    secondly, the 8pin connector on the mainboard is fine, provided that there wasn't a 4 pin that was avaliable right? the white plastic plug is known as the molex connector, dont mess with that. what you need is this cable plugged into your video card: [​IMG]
    & one of these in your mobo's cpu power connector:
    [​IMG]
    use that provided that you dont have this one:
    [​IMG]
    mrsemi says thanks.
  4. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    I've got the 24 pin connector connected the item in the lower left hand corner that's is the plug that I'm concerned about connecting.
    http://www.newegg.com/Product/ShowImage.aspx?CurImage=13-188-017-03.jpg&Image=13-188-017-02.jpg%2c13-188-017-03.jpg%2c13-188-017-04.jpg%2c13-188-017-05.jpg%2c13-188-017-06.jpg%2c13-188-017-07.jpg%2c13-188-017-08.jpg&S7ImageFlag=0&Depa=0&Description=EVGA+122-CK-NF66-T1+ATX+Intel+Motherboard
  5. kwchang007
    Jan 27, 2007
    3,979 (1.33/day)
    185
    Severn, MD, USA.
    Alright, so you can't get the 24 pin in right? Cause that's just one piece and can only go in one way. Then you also need the 4 pin connector into the mobo in the corner by the cpu. That will only go in one way to. 6 pins into the 8800s....and then all the peripherals then boom ready to go.
  6. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    Ok I have an 8 pin connector that looks like your picture but is white as well, but it's the only one that is solid, the only 8 pin connector on the psu. There's 2 extra pcie 6 pin plugs like the one you showed for the video card that fit with 2 pins hanging out. Which one would you suggest?
  7. panchoman
    Jul 16, 2007
    9,595 (3.41/day)
    1,200
    either plug will be good.
    everything's made so that with regular force, you cant really shove things in the wrong way, so you'll know if you're using a connector that doesn't work, but either of the pci e ones will work.
    mrsemi says thanks.
  8. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    Sorry, the 24 pin connector (not 20 +4) is in *no option*no brainer. It's the 4 pin connector in that lower left corner of the pic I'm trying to connect.
  9. mrsemi
    May 22, 2007
    659 (0.23/day)
    67
    Thanks Pancho, & Kwchang007, time to get this baby running.
  10. kwchang007
    Jan 27, 2007
    3,979 (1.33/day)
    185
    Severn, MD, USA.
    Use the 4 pin it SHOULD work.
  11. panchoman
    Jul 16, 2007
    9,595 (3.41/day)
    1,200
    good luck :toast:
  12. panchoman
    Jul 16, 2007
    9,595 (3.41/day)
    1,200
    err chang, i think you're not getting what hes saying. he has the 24pin connector in the 24pin socket, he was asking about the 4 pin connector cpu connecter that he has on his mobo, and he only has a 8 pin connection from the cpu..
  13. kwchang007
    Jan 27, 2007
    3,979 (1.33/day)
    185
    Severn, MD, USA.
    Oh I feel like a durh di durh now. 8 pin should fit then and work. Good luck getting the comp running.
  14. panchoman
    Jul 16, 2007
    9,595 (3.41/day)
    1,200
    sorry for the little jack, but chang, why not join us at the teen club?
  15. kwchang007
    Jan 27, 2007
    3,979 (1.33/day)
    185
    Severn, MD, USA.
    Getting late and shiz...but I might come and pop by for like 10 minutes lol.
Share This Page
