HELP: Spraying Case Inside
Discussion in 'Cases, Modding & Electronics' started by twicksisted, Nov 6, 2009.
  1. twicksisted
    twicksisted
    Oct 4, 2007
    2,438 (0.88/day)
    350
    Ok as with most of my posts... the title says all...
    I have a case, I want the inside black... what paint ot use?... spray, brush
    (im not going to send it into a shop to get anodised lol)
    My case (look at my specs) is a Coolermaster Cosmos S..... its wicked but will be nicer in black.
    I dont want to spray something on that will flake off or sit badly and look crap...
    Chances are any homemade recipe for painting it at home will look bad... i just want to know if perhaps theres a miracle product out there that will do the job well ;)
  2. sneekypeet
    Apr 12, 2006
    22,017 (6.65/day)
    6,562
    twicksisted says thanks.
  3. twicksisted
    twicksisted
    Oct 4, 2007
    2,438 (0.88/day)
    350
    thanks pete... though i was kinda hoping for a more all in one answer like... this paint... this tin, this brush (google it, buy it...sorted hehehe)... then that physical application (homemade of course)....
    im not looking for a shit finish , more like a slick glossy finished look...
    anyways ill check out those posts tomorrow, im in need of sleep here in the smelly UK ;)
  4. sneekypeet
    Apr 12, 2006
    22,017 (6.65/day)
    6,562
    hit em up in that clubhousee, I'm sure you will get better replies from those who do it all the time.
  5. 1933 Poker
    1933 Poker New Member
    Oct 30, 2009
    93 (0.05/day)
    8
    Australasia
    I used to spray cars for a living and I was trained to layer the "coats" rather than chuck on a couple thick one's. Basically this means to a n00B that if you want to do a "good" job you will get a sore hand and aching wrist and your thumb and forefinger will not let you smoke for about a week, but you'll have a shinier mirror finish to look at!
  6. twicksisted
    twicksisted
    Oct 4, 2007
    2,438 (0.88/day)
    350
    wrist action im good at :D :laugh:
  7. wojo New Member
    Feb 27, 2009
    69 (0.03/day)
    2
    Omaha, Ne
    I just bought a can of black and took my time spaying it it I think it looks good. There was also a removable plate for the mobo that I took out and painted yellow.
    Bob
  8. brandonwh64
    brandonwh64 Addicted to Bacon and StarCrunches!!!
    Sep 6, 2009
    18,942 (9.17/day)
    6,414
    Chatsworth, GA
    I know you dont want to send it off but a good powder coat job would look great!
    Crunching for Team TPU
Share This Page
