Help with AsRock 990FX Extreme3?
Discussion in 'Motherboards & Memory' started by rubenclavs, Jan 31, 2014.
  1. rubenclavs
    Nov 7, 2013
    205 (0.25/day)
    39
  2. ne6togadno
    ne6togadno
    Mar 15, 2013
    2,058 (1.94/day)
    1,290
    GMT +2
    most likely yes as soon as it comes with bios p1.40 or later
    rubenclavs, Law-II and RCoon say thanks.
  3. rubenclavs
    Nov 7, 2013
    205 (0.25/day)
    39
    if not? how will I do it? where can I check the BIOS version? in the box or in the mobo?
  4. micropage7
    micropage7
    Mar 26, 2010
    7,080 (3.30/day)
    1,756
    Jakarta, Indonesia
    in mobo and you can update your bios through asrock website
    rubenclavs says thanks.
  5. rubenclavs
    Nov 7, 2013
    205 (0.25/day)
    39
    for an outdated bios, it can't read the chip right? how can I update the bios for it?
  6. micropage7
    micropage7
    Mar 26, 2010
    7,080 (3.30/day)
    1,756
    Jakarta, Indonesia
  7. Devon68
    Devon68
    Jan 25, 2014
    1,389 (1.87/day)
    834
    Well it seems the FX-8320 isn't on the CPU support list
    http://www.asrock.com/support/CPU.asp
    but if you already have the board contact customer support and ask them, they should know.
  8. de.das.dude
    de.das.dude Pro Indian Modder
    Jun 13, 2010
    8,063 (3.90/day)
    2,185
    Pune
    err this is the support list
    http://www.asrock.com/mb/AMD/990FX Extreme3/?cat=CPU
    and its probably a typo. if it supports 8350,8300 it will support 8320 too.
    ask your seller to make sure he is giving the latest product with latest bios.
  9. rubenclavs
    Nov 7, 2013
    205 (0.25/day)
    39
    I don't have the board yet but I will buy this combo but I'm not sure on this board as in the CPU support list it doesn't have the 8320. This makes things more complicated.
    Help!
  10. Devon68
    Devon68
    Jan 25, 2014
    1,389 (1.87/day)
    834
  11. Norton
    Norton WCG-TPU Team Captain
    Dec 21, 2011
    10,723 (7.11/day)
    28,910
    Suggest going with this Gigabyte 970 UD3 board unless you're specifically looking for the Crossfire/SLI support of a 990FX board:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128651
    Much better power setup than that Asrock and at a pretty good price too!
    *Note- this will be my next board if I build another FX-8350 rig :)
    rubenclavs and de.das.dude say thanks.
    Crunching for Team TPU
  12. Nortrop
    Nortrop
    Jan 2, 2012
    27 (0.02/day)
    4
  13. de.das.dude
    Jun 13, 2010
    8,063 (3.90/day)
    2,185
    Pune
    this is a good board! and that price is unbeatable!
    8+2 phase for a 100$ board is unheard off!!!! OMGGG
    Vario and rubenclavs say thanks.
  14. rubenclavs
    Nov 7, 2013
    205 (0.25/day)
    39
    I have read all the reviews on this link and this board is just not that great for my future build. Thanks
  15. rubenclavs
    Nov 7, 2013
    205 (0.25/day)
    39
    I wanted a 990FX chipset for my upgrade build.
    How about these? Just really depends on the price and availability here in my place.
    http://www.gigabyte.com/products/product-page.aspx?pid=4658#ov
    http://www.gigabyte.com/products/product-page.aspx?pid=4455#ov
    http://www.gigabyte.com/products/product-page.aspx?pid=4672#sp
  16. de.das.dude
    Jun 13, 2010
    8,063 (3.90/day)
    2,185
    Pune
    if can go for the 990fx extreme 4. its a good board. i have it. overclocks well. can do 4.7GHz on 8350s!
  17. rubenclavs
    Nov 7, 2013
    205 (0.25/day)
    39
    Is it compatible for 8320/8350 out of the box?
    I have messaged my retailer here for those gigabyte mobos.
  18. de.das.dude
    Jun 13, 2010
    8,063 (3.90/day)
    2,185
    Pune
    yes it is. as long as you get current product. if you get any old mobo no one will support out of the box.
    if you buy check import date.
  19. eidairaman1
    Jul 2, 2007
    14,398 (4.58/day)
    2,133
  20. ne6togadno
    ne6togadno
    Mar 15, 2013
    2,058 (1.94/day)
    1,290
    GMT +2
  21. rubenclavs
    Nov 7, 2013
    205 (0.25/day)
    39
    Thanks for a very great idea for the import date. I will print hard copies for listings on all the boards.
  22. rubenclavs
    Nov 7, 2013
    205 (0.25/day)
    39
  23. rubenclavs
    Nov 7, 2013
    205 (0.25/day)
    39
  24. de.das.dude
    Jun 13, 2010
    8,063 (3.90/day)
    2,185
    Pune
    no
    the 970 chipsets support x8 x8
    the 990fx support x16 x16 x8
  25. rubenclavs
    Nov 7, 2013
    205 (0.25/day)
    39
    so i'll get full x16/x16 for crossfire? this will be amazing soon!
