Help with choosing power supply
Discussion in 'General Hardware' started by target7, Jun 19, 2007.
  1. target7 New Member
    Jun 19, 2007
    3 (0.00/day)
    0
    The stock PSU that came with my case went suicidal and took my video card with it. I guess it was obvious that it wasnt up for the oc'ing and graphic card consumption. so now, I need some quick info to know what to look for in a power supply. I hear it has a lot to do with 12V rails for modern day computers.
    so... here's the "upgraded PSU that I bought: COOLMAX CX-400B ATX v2.01 400W
    http://www.newegg.com/Product/Produc...82E16817159023
    is that good enuff for... my future core 2 duo setup with a 8800gts?
    If not, I was thinking about buying this: Antec Truepower 2.0 550 Watts
    cuz I saw it in the F/S thread.
  2. Pinchy New Member
    Apr 29, 2006
    5,109 (1.43/day)
    284
    Sydney, Australia
    I wouldnt recommend using that 400W PSU. That Antec 550W should be fine though.
  3. Widjaja
    Widjaja
    Jun 12, 2007
    4,819 (1.52/day)
    640
    Wangas, New Zealand
    From my research a safe bet will be a 550W PSU with a +12v26a rail although the recommended PSU is 400W.
    Make sure it's of a reputable brand:-Enermax, Silverstone, Antec tpo name a few.
    Just search:- 8800GTS recommended PSU.
    Although the reason for the 26a on the +12V rail is just incase you have a fully loaded system.
    I was running my X1950pro on a 450W +12V15a rail just asking for trouble but then again the vendor did not ask what system I had.
    But to be safe I have upgraded to a Enermax Noisetaker 600W 2x +12V18a rail although the recommended PSU is a little bit more than that but then again I don't have a fully loaded system.
  4. hat
    hat Enthusiast
    Nov 20, 2006
    17,699 (5.25/day)
    2,516
    Ohio
    That antec power supply is definately better quality then a power supply that no longer has a spot on newegg anyway...
    Crunching for Team TPU
  5. Shima New Member
    May 7, 2006
    6 (0.00/day)
    0
    Vote antec true power
  6. bruins004 New Member
    Sep 27, 2005
    2,480 (0.65/day)
    75
    Y dont u read the recommended Power Supply wattage that is recommended to be used with the card?
    Can you not read?
    10 Year Member at TPU
  7. hat
    hat Enthusiast
    Nov 20, 2006
    17,699 (5.25/day)
    2,516
    Ohio
    You won't be running a C2D with an 8800GTS on any 400W power supply. For a set-up like that, I reccomend a 600W with 30A on the 12V rail, or if it's dual rail, 20A and 20A
