help with compaq mv520(monitor)
Discussion in 'General Hardware' started by baoluvboa, Jun 20, 2006.
  1. baoluvboa New Member
    Jun 7, 2006
    5 (0.00/day)
    0
    my "dell 2400" computer using window xp doesnt recognize my "compaq mv520" monitor
    it is displayed as "plug and play monitor" so i cant use 1024 x 768 resolution so i cant play games like "empire earth"
    do i have to install a monitor drive in order for window to recognize the monitor?
    the monitor worked fine on my old compaq computer that came with it
    i figure that i have to find a driver for the monitor because i didnt install any driver for this monitor
    i been searching A LOT on google ( around 20 pages, every single sites)
    is there a solution to this problem or can u guys plz find a link to the driver for it? plz help im still a noob when it comes to computer stuff and i gave up on finding the driver since i dled and installed like 4 and they dont work
    Computer : dell 2400
    Monitor: Compaq MV 520 ( but displayed as "plug and play" in the computer hardware)
  2. AceFactor New Member
    Aug 9, 2005
    234 (0.07/day)
    0
    Suffolk, UK
    how old is your monitor by chance? and did it capably run your resolution 1024 x 798 before you got your dell PC? because it should run fine as a plug nd play monitor afaik :confused:
    -Adam
  3. Jimmy 2004
    Jimmy 2004 New Member
    Jan 15, 2005
    5,491 (1.58/day)
    267
    England
    My monitor is plug and play and it works fine at higher resolutions... no reason why this shouldn't work anyway - give it a go and post how you get on.
  4. baoluvboa New Member
    Jun 7, 2006
    5 (0.00/day)
    0
    thx guys i got it to work with the driver that jimmy posted
  5. Jimmy 2004
    Jan 15, 2005
    5,491 (1.58/day)
    267
    England
    Glad it worked, I recommend you back it up just in case you need it again when if you reformat.
Share This Page
