help with setting up Amd Crossfire with an llano a6-3650 and amd radeon hd 6670
4,355 (0.94/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
http://www.asrock.com/mb/faq.asp?Model=A55M-HVS
Question (Q&A-88):When I install ATI HD6670, HD6570, and HD6450 on A75/A55 series motherboards, there is no display output from VGA card. What can I do? (9/1/2011)
Answer:please update latest BIOS form our website.
Download link: http://www.asrock.com/support/download.asp
Or, enter BIOS > North Bridge Configuration, and set [Dual Graphics] to [Disabled].
Have you updated your BIOS and check if the mentioned option is set to "Enable"?
flipzro
25 (0.01/day)
Like i originally stated its due to hardware restriction on your motherboard not software try contacting motherboard manufacture to see if they can shed some light it to why this is not possible.....
Hope this helps
Ok i'll do that. I got this motherboard because it claimed to be dual graphics ready. I guess I'm going motherboard shopping soon if not.
98 (0.02/day)
WIGAN, UK
System Name BlackDragon
Processor Ryzen 5 2600
Motherboard MSI Gaming Pro Carbon
Cooling Silverstone RGB 240 AIO
Memory 32 gb 3200 Corsair vengence pro DDR4
Video Card(s) Asus Vega 56 OC edition 8gb
Storage 2x 512gb NVME m.2 plus 4x SSD's
Display(s) 29WK600 Ultrawide screen DP to DP
Case NZXT 630 phantom case
Audio Device(s) Onboard 1220 Realtek with Nahimic support
Power Supply 700Watt Cooler master
Mouse Generic gaming mouse
Keyboard Logitech G19s gaming keyboard
Software Win 10 (20H2)
252 (0.05/day)
Malaysia
Processor Intel Core i3-2100 @ 3.1 GHz
Motherboard Asus P8H61-M LX (B3)
Cooling Intel stock HSF
Memory 2x 4GB Kingston DDR3 @ 1333 MHz
Video Card(s) Gigabyte Radeon HD 6750 OC
Storage Western Digital Caviar Blue 500GB SATA 3
Display(s) HP W2072a 20"
Case Cooler Master Elite 430 Black
Audio Device(s) Integrated (Realtek ALC887)
Power Supply Cooler Master eXtreme Power Plus 500W
Every APU has GPU in its chip.
98 (0.02/day)
WIGAN, UK
I know that's what i meant was which APU model has hes got and with what GPU model incorporated, as this may have some bearing on his problem.
252 (0.05/day)
Malaysia
Also does you APU have gpu installed on chip ????
Your question just confusing me. And I don't mean to offend anyone.
flipzro
25 (0.01/day)
2,417 (0.42/day)
Whitby, Ontario
Processor AMD Ryzen 5 2600
Motherboard MSI B450 Gaming Plus
Memory GSkill 8GB Dual Channel DDR4-2800
Video Card(s) MSI GamingX RX580 4GB
Storage Kingston V300 240GB SSD + WD Green 2TB
Display(s) ACER K212HL 27" + Haier 55" + Lenovo Explorer Mixed Reality Headset
Case Enermax Ostrog (Red)
Power Supply EVGA SuperNOVA B2 750W
Software Win10 64bit
flipzro
25 (0.01/day)
just installed the new bios update. no change when it comes to the dual graphics function. thanks anyway dude
4,355 (0.94/day)
Mexico
Could it be that the 6670 needs to be CF compatible? Does your HD6670 have a CF conector? :confused:
Have you contacted Asrock orAMD about your problem?
4,884 (0.76/day)
Hong Kong
Processor Core i7-12700k
Motherboard Z690 Aero G D4
Storage Plextor M10P 2TB
Display(s) InnoCN 27M2V
Case Thermaltake Level 20 XT
6670 runs CF through the motherboard, so none of them have a CF connector.
turkmauser
1 (0.00/day)
Berea, Ky
Be sure that within your bios you have the "initialized display First" set to onboard. that might not be what its called on your board but it something similar.
flipzro
25 (0.01/day)
yeh. my motherboard is only suppose to be able to process crossfire through my onboard initializing first so having it set as my default graphics adapter was one of the first things I did. Thanks anyway!
flipzro
25 (0.01/day)
dam.. It's so hard to accept the fact that my hardware is capable of dishing out almost twice the visual performance power and some little thing that I just don't see if preventing me from doing so.. ahhhh
flipzro
25 (0.01/day)
whack.. seems like the amd support guys are even less knowledgeable! wtf...
4,355 (0.94/day)
Mexico
Have you asked Asrock? Could this issue be enough cause for an RMA?
flipzro
25 (0.01/day)
yeh im beginning to suspect its my motherboard. I'll contact them next. Whats an RMA by the way?
4,015 (0.80/day)
UK
System Name PC
Processor AMD Ryzen 3600
Motherboard MSI B450 Mortar Max
Cooling Phanteks PH-TC12DX, 3 x NZXT FN 140mm, 1x NZXT FV V2 120mm
Memory 32gb DDR4 3200mhz
Video Card(s) ASUS R9 290 DCII-OC 4GB
Storage corsair mp600 1TB
Display(s) LG 27MB85Z 27" 1440p
Case NZXT Source 340
Power Supply Thermaltake 675w
Mouse Logitech G500S
Keyboard Logitech G510S
Software Windows 8.1 64 bit
RMA is the process by which you send the motherboard back to the manufacture
Mussels
Freshwater Moderator
58,413 (8.19/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
return (to) manufacturer authorisation, commonly known as warranty.
syntaxx
9 (0.00/day)
from the OP. Have you fixed this? We almost have the same specs. I wonder when I checked using GPU-Z and select my onboard on the dropdown. It shows Crossfire enabled. How can I verify if its really working as hybrid crossfire? I read above that it shud be HD 6990D2 I guess? Thanks!:)
flipzro
25 (0.01/day)
sup man, no i pretty much gave up. i've been told it was my motherboard so im waiting till i have enough cash to buy a new one along with maybe a faster processor. do we have to same motherboard as well??
syntaxx
9 (0.00/day)
Yeah we have the same specs except for the 8gb ram. I managed it to work but then again i am not sure. I put the graphics to pci express then insert the monitor to the onboard slot. Run the catalyst and check the game performance. Amd crOssfire then the check box is enabled. Running gpu-z it shows the onboard crossfire enabled but the 6670 shows disabled.
syntaxx
9 (0.00/day)
By the way i think i managed it to work. Now my 6670 shows crossfire enabled on gpu z and on the manager dual graphics is checked. What i did was I remove the display adapter on device manager both of them. Then insert the hdmi on the 6670 download the latest driver then it shows.
flipzro
25 (0.01/day)
ok wait, i'm not sure I understand. On your first reply you said you had your hdmi plugged into your onboard, but then you said in the other one that you plugged it into the 6670 after uninstalling both the onboard and the 6670 driver in the device manager. which one should i do? haha
edit: and by manager do you mean the bios set up?
