Help with thermal Paste,vegetable oil mixed :O
Discussion in 'Overclocking & Cooling' started by techjunkie, Apr 15, 2009.
  1. techjunkie
    techjunkie New Member
    Jul 31, 2008
    173 (0.07/day)
    17
    So I took off my heatsink to clean it and after the clean, I was a little short on thermal paste. The thermal paste I've been using was really crappy and was kind of solid when applying. As I was short of some, I mixed the remaining with a drop of vegetable oil and put it all back together. Now the system boots up fine and everything seems normal, including the temps. Temps are a little less now about 3-4 C less.
    Am I safe with this vegetable oil mix? I am using it right now
  2. Mussels
    Mussels Moderprator Staff Member
    Oct 6, 2004
    43,532 (10.94/day)
    10,716
    Australalalalalaia.
    oh lol.
    well techinically it would work, but what i'd be worried about is it evaporating over time or even worse - leaking out and making stuff go boom.
    I suggest you buy some arcticlean and MX2 thermal paste, and go do it right. No rush... you should be ok for a few days.
    techjunkie says thanks.
  3. techjunkie
    Jul 31, 2008
    173 (0.07/day)
    17
    thanks a lot for the post :) I was scared like hell
  4. Mussels
    Oct 6, 2004
    43,532 (10.94/day)
    10,716
    Australalalalalaia.
    the reason i think its not so bad is because there have been several succesful attempts at submerging PC's in oil.
    Vegetable oil causes corrosion eventually, but since its only a small amount and on a CPU heatspreader, i dont think theres much to get corroded,
  5. gstyle99 New Member
    Apr 14, 2009
    11 (0.00/day)
    0
    You r crazy dude, does your computer smell like french fries?
Share This Page
