Help with water cooled system
Discussion in 'Overclocking & Cooling' started by allen337, Mar 20, 2008.
  1. allen337
    allen337
    Aug 29, 2004
    959 (0.25/day)
    113
    Danville IL
    Ok I just broke off a nipple on my water cooled machine and I need a new pump and resivoir. Ive got 6mm lines to everything with 2 radiators in the loop. Whats a good pump and resivoir or both togather solution? Are their adapters to make the 6mm fittings bigger? they are barbed fittings. Any help appreciated.
    desk ~~ http://img150.imageshack.us/my.php?image=dsc00475mx9.jpg .
    top radiator ~~ http://img150.imageshack.us/my.php?image=dsc00473ar1.jpg .
    side radiator ~~ http://img150.imageshack.us/my.php?i...sc00471fq3.jpg .
    case ~~ http://img150.imageshack.us/my.php?image=dsc00466gm7.jpg .
  2. warhammer New Member
    Jan 10, 2008
    204 (0.08/day)
    25
    Code:
    [Upload your own video]"; document.getElementById('forum_code_1').value = "[URL=http://imageshack.us][IMG]http://img150.imageshack.us/img150/1671/[/IMG][/URL]"; document.getElementById('forum_code_2').value = "[URL=http://imageshack.us][IMG=http://img150.imageshack.us/img150/1671/][/URL]"; } } function page_init() { is_image = 0; has_thumb = 0; if (has_thumb == 0) { document.getElementById('thumb_title').innerHTML = 'No Thumb Available'; document.getElementById('ibl_radio').style.display = 'none'; swap_links(2); } if (is_image == 0) { document.getElementById('forum_code_1_row').style.display = 'none'; document.getElementById('forum_code_2_row').style.display = 'none'; } document.getElementById('ibl_block').style.display = 'block'; }
    Your image files are not working
    allen337 says thanks.
  3. allen337
    allen337
    Aug 29, 2004
    959 (0.25/day)
    113
    Danville IL
    fixed
  4. allen337
    allen337
    Aug 29, 2004
    959 (0.25/day)
    113
    Danville IL
    wow wrong forum I guess. ALLEN
  5. intel igent
    intel igent New Member
    Jun 5, 2005
    4,641 (1.29/day)
    434
    Toronto, Canada
    the barbs in the rest of your system are fixed right? you could go for a DDC style pump with a restop and opt for 1/4" fittings :confused:
    might get more help posting in the watercooling club or watercooling FAQ threads ;)
    :toast:
  6. allen337
    allen337
    Aug 29, 2004
    959 (0.25/day)
    113
    Danville IL
    Left this exact post in the watercooling club post for a day with no responces so moved it here. Im wondering if the radiators will flow better if I get some kind of adapter to make them 3/8 . With the 1/4 (6mm) lines it kept my quad @ 22-28c.
  7. intel igent
    Jun 5, 2005
    4,641 (1.29/day)
    434
    Toronto, Canada
    short answer no
    :toast:
Share This Page
