MxPhenom 216
ASIC Engineer
- Aug 31, 2010
- 12,944 (2.62/day)
- Loveland, CO
System Name | Ryzen Reflection |
Processor | AMD Ryzen 9 5900x |
Motherboard | Gigabyte X570S Aorus Master |
Cooling | 2x EK PE360 | TechN AM4 AMD Block Black | EK Quantum Vector Trinity GPU Nickel + Plexi |
Memory | Teamgroup T-Force Xtreem 2x16GB B-Die 3600 @ 14-14-14-28-42-288-2T 1.45v |
Video Card(s) | Zotac AMP HoloBlack RTX 3080Ti 12G | 950mV 1950Mhz |
Storage | WD SN850 500GB (OS) | Samsung 980 Pro 1TB (Games_1) | Samsung 970 Evo 1TB (Games_2) |
Display(s) | Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode) |
Case | Lian Li PC-011D XL | Custom cables by Cablemodz |
Audio Device(s) | FiiO K7 | Sennheiser HD650 + Beyerdynamic FOX Mic |
Power Supply | Seasonic Prime Ultra Platinum 850 |
Mouse | Razer Viper v2 Pro |
Keyboard | Razer Huntsman Tournament Edition |
Software | Windows 11 Pro 64-Bit |
I thought most people usually put the res after the component it's supposed to cool, for example:
pump/res>CPU>120mm rad>gpu>240mm rad>pump/res
Which xspc pump/rad combo do you have? is it the dual 5.25 bay one or the single?
Make sure to check the CPU and GPU block inside to make sure there's no gunk or contamination making the fluid too heavy or clogging up any fitting.
I have never used a pump/res combo, so i cant tell you if the pump is powerful enough or not.
I'll have to do a little research.
It doesn't really matter. Try to go for the shortest tubing routes and make sure its pump and reservoir are one after another. Main reason I like bay pump and reservoirs combos its just one less route to worry about, and the reservoir can act as a low end performance top.
